custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options.
custom/FreeBSD-posix.cfg: Remove make-target-options.
custom/HPUX9-posix.cfg: Dito.
custom/Linux-posix.cfg: Dito.
custom/Solaris-posix.cfg: Dito.
custom/arm_bare_bsp.cfg: Dito.
custom/armulator.cfg: Dito.
custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/i386ex.cfg: Remove make-target-options.
custom/i960sim.cfg: Remove make-target-options.
custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/rxgen960.cfg: Remove make-target-options, cleanup comments.
custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/vegaplus.cfg: Remove make-target-options.
* custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg,
custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
it work.
As mentioned in other mails before, there is are minor inconsistencies in the
posix custom/*cfg files.
Linux-posix.cfg sets RTEMS_BSP=posix
FreeBSD-posix.cfg sets RTEMS_BSP=posix
Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets
RTEMS_BSP=solaris2
1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg
2. The solaris variant of setting RTEMS_BSP is merely non-functional.
The patch attached to this mail should clean up this issue.
The patch was tested by building the posix bsp under
i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any
rtems program, however) The HPUX9 and FreeBSD configuration files
were adapted in analogy to the solaris and linux configurations.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
