path: root/make/compilers (follow)
* 2002-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-131-77/+2
| | | | | | | | * Part of addressing PR281. * main.cfg: Added recognition of VARIANT=DEBUG on command line. * compilers/gcc-target-default.cfg: Removed remaining support for RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug as one of the LDFLAGS when the debug variant is specified.
| | | | | | | * Templates/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * compilers/Makefile.am: Remove AUTOMAKE_OPTIONS. * custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-1/+1
| | | | | * compilers/gcc-target-default.cfg: Add missing \. Reported by Ilya Alexeev <ilya@continuum.ru>.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-062-2/+4
| | | | | | | * custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS. * custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272 support. * custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* 2001-05-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-083-17/+3
| | | | | | | | | | * leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V. * compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags, remove unused flags, remove -ansi from CPP. * custom/eth_comm.cfg: Remove CPU_DEFINES. * custom/sim68000.cfg: Remove CPU_DEFINES.
* 2001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-04-263-3/+3
| | | | | | | | * compilers/gcc-no_bsp.cfg: Remove -ansi -fasm. * compilers/gcc-default.cfg: Dito. * compilers/gcc-portsw.cfg: Remove -Hansi. * custom/posix.cfg: Remove inclusion of target.cfg. * custom/simhppa.cfg: Remove -ansi -fasm.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-1/+2
| | | | * compilers/gcc-portsw.cfg: Use gcc style flags.
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-121-2/+12
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-124-24/+19
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-16/+0
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-2/+3
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-7/+7
* Patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-161-14/+9
| | | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which does the following: This is the configuration cleanup patch: Main changes: * TARGET_ARCH removed * target.cfg.in moved to c/make/target.cfg.in (Only configured once for all BSPs of a target) * BARE_XXX variables appended to bsp.cfg.in * autogen renamed to bootstrap * removed stray variables from make/custom/*.cfg To apply: cd <source-tree> rm c/src/make/target.cfg.in cp autogen bootstrap mkdir c/make cp make/target.cfg.in c/make/target.cfg.in rm make/target.cfg.in rm autogen patch -p1 < rtems-rc-19991105-1.diff
* Removed all references to HOST_ARCH including the file gcc.cfg.in. AllJoel Sherrill1999-10-262-205/+1
| | | | | host programs are now compiled with automake generated rules. This was done after discussions with Ralf Corsepius and Eric Norum.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-4/+4
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-041-216/+0
* Regenerated.Joel Sherrill1999-10-041-5/+6
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-1/+1
* Removed need for use of separate include/networking directory.Joel Sherrill1999-08-231-7/+3
* Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-08-061-6/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-261-12/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is an addition to "The big-patch" CHANGES: * FIX: c/Makefile.am: bogus comment which changed the behavior of c/Makefile.am removed * FIX: make/custom/ts_i386ex.cfg did not set HAS_NETWORKING correctly (Me thinks it might have been me who added this bogus setting :-). * NEW: removing make targets get, protos, debug_install, profile_install * NEW: replacing clobber with distclean * NEW: Reimplement distclean and clean as reverse depth first make targets (adaptation to automake's behavior) * NEW: removing RCS_CLEAN from make distclean (tools/build/rcs_clean is still in - remove it?) * NEW: "$(RM) Makefile" added to make distclean (adaptation to automake's behavior) * NEW: "$(RM) config.cache config.log" to CLOBBER_ADDITIONS in [lib|exec|tests]/Makefile.in (adaptation to automake's behavior) * NEW: "$(CLEAN_PROTOS)" removed (Not used anywhere) * NEW: binpatch.c moved from i386 bsp tools to tools/build (AFAIS, binpatch is not specific to the pc386 BSP at all) * NEW: AC_EXEEXT added to all configure scripts which contain AC_PROG_CC (Cygwin support) * NEW/Experimental: An experimental implementation of temporary installation tree support in libbsp/i386/pc386/tools/Makefile.am, based on dependency tracking with make, instead of applying INSTALL_CHANGE. REMARK: * This patch is small in size, but changes the behavior of "make clean|distclean|clobber" basically. * This patch does not alter building/compiling RTEMS, ie. there should be no need to rerun all "make all" building tests. KNOWN BUGS: * make RTEMS_BSP="..." distclean in c/ runs "make distclean" in BSPs subdirectories passed through RTEMS_BSP and in "c/." only, but does not descend into other BSP subdirectories previously configured with different settings of make RTEMS_BSP="...". => Workaround: always use the same setting of RTEMS_BSP when working inside the build-tree. * "make [distclean|clean]" do not clean subdirectories, which have been configured at configuration time, but which are not used due to make-time configuration (e.g. macros/networking/rdgb subdirectories). This will problem will vanish by itself when migrating from make-time to configuration-time configuration APPLYING THE PATCH mv c/src/lib/libbsp/i386/pc386/tools/binpatch.c tools/build patch -p1 < rtems-rc-19990709-2.diff autogen
* This is part of a major patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-07-262-0/+241
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | to move RTEMS more to automake/autoconf and GNU compliance. Finally, here they are: the "big-patch" patches - merged into one big patch (~1.5MB). Sorry for the delay, but testing took much more time than I had expected - esp. reworking the acpolish script triggered many more tiny issues than I had expected (cf. below). At least, now you've got something to spend your weekend with :-. WARNINGS: * I've gone a little (??) further than I had announced before. * Several directories have been moved. * Several files have been added and removed * I have tested it with many BSPs/CPUs and a variety of permutiations of configuration flags, but not with all. * Most parts of the patch are automatically generated, however there are many tiny manual modifications. APPLYING THE PATCH: ./autogen -c mkdir tools mv c/src/exec/score/tools tools/cpu mv c/build-tools tools/build mv c/update-tools tools/update patch -p1 -E < rtems-rc-19990709-0.diff ./autogen If the patch doesn't apply to rtems-cvs, I would suggest that you should try to apply it brute-force and then to run tools/update/rtems-polish.sh -ac -am afterwards. A recursive diff between rtems-19990709 + patch and rtems-cvs + patch then should report only a few dozen significant changes to configuration files which need to be merged manually (IIRC, I did not change any source files). *** Attention: There are files to be removed, moved, copied and added in/to CVS! NEWS/CHANGES: 1. Configuration takes place in 3 stages: 1. per host (toplevel configure script), 2. per target (c/configure), 3. per bsp c/src/configure automatically triggered from ./configure and c/Makefile.am. 2. Building of subdirectory c/ takes place in c/$(target_alias) for cross-targets in c/ for native targets 3. Building of subdirectory c/src takes place in c/${target_alias}/<bsp> for cross-targets, c/<bsp> for native targets 4. c/build-tools moved to tools/build 5. c/src/exec/score/cpu/tools moved to tools/cpu (=cpu-tools split out) 6. c/update-tools moved to tools/update 7. New subdirectory c/src/make, handles files from make/ on a per BSP basis 8. Maintainer mode support: Ie. if configuring with --enable-maintainer-mode disabled (the default), then tracking of many dependencies will be disabled in Makefiles. Esp. many dependencies for auto* generated files will be switched off in Makefiles. Ie. if not using "--enable-maintainer-mode" many auto* generated files will not be updated automatically, i.e. normal users should not be required to have auto* tools anymore (untested). 9. Independent configuration scripts for / (toplevel), tools/build, tools/cpu, tools/update, c/, c/src/, c/src/exec, c/src/lib, c/src/tests, c/src/make 10. Automake support for all directories above and besides c/src 11. "preinstall" now is implemented as depth-first recursive make target 12. host compiled tools (exception bsp-tools) are accessed in location in the build tree instead of inside the build-tree when building RTEMS. 13. RTEMS_ROOT and PROJECT_ROOT now point to directories inside the build-tree - many tiny changes as consequence from this. 14. --with-cross-host support removed (offically announced obsolete by cygnus) 15. Changing the order of building libraries below c/src/lib/ 16. Former toplevel configure script broken into aclocal/*.m4 macros 17. Newlib now detected by configure macros, RTEMS_HAS_NEWLIB removed from *cfg. 18. sptables.h now generated by autoconf 19. Rules for "mkinstalldirs temporary installation tree" moved from c/Makefile to subdirectories. 20. Cpu-tools do not get installed. 21. FIX: Use ACLOCAL_AMFLAGS instead of ACLOCAL = -I ... in Makefile.ams which are in directories with own configure scripts. 22. Hardcoding BSP names into libbsp/.../tools to avoid RTEMS_BSP get overridden from the environment. 22. FIX: Handling of MP_PIECES in various Makefiles 23. FIX: Removing "::" rules from some Makefile.ins 24. FIX: File permission chaos: (-m 444 and -m 555 vs. -m 644 and -m 755) - Now all include files use -m 644. 25. Removed many gnumake-conditionals in Makefile.ins - Partially replaced with automake-conditional, partially replaced with conditionalized Makefile variables (... _yes_V) 26. Massively reworked acpolish: acpolish now parses Makefile.ins and interprets parts of the Makefile.ins. 27. FIX: Some $(wildcard $(srcdir)/*.h) macros removed / replaced with explicit lists of files in Makefile.ins. 28. FIX: Replacing MKLIB with RANLIB in Makefile.ins 29. HACK: Add preinstallation for pc386 specific $(PROJECT_RELEASE)/BootImgs directory ... many more details, I can't recall KNOWN BUGS: 1. make [debug|profile]_install do not do what they are promissing. "make [debug|profile] install" does what "make [debug|profile]_install" has been doing. Proposal: remove [debug|profile]_install 2. Dependencies between temporary installation tree and source tree are not yet handled correctly. 3. Dependencies between temporary installation tree and source tree are handled ineffencently (Using INSTALL_CHANGE instead of make dependencies) 4. RTEMS_ROOT, PROJECT_ROOT, top_builddir, RTEMS_TOPdir now are redundant. 5. The new configure scripts still are in their infancy. They contain redundant checks and might still contain bugs, too. 6. RTEMS autoconf Makefile.ins use a mixture of configuration information gathered in c/$(target_alias)/<bsp>/make and of information collected from their configure scripts. 7. make dist is not fully functional 8. Subdirectory host-/build-/target- configure options (--target, --host, --build) do not conform to Cygnus/GNU conventions. 9. Some RTEMS autoconf Makefile.in's makefile targets are not supported in automake Makefile.ams/ins (e.g. get, clobber). 10. Some automake standard targets are not propagated from toplevel and c/Makefile.am to autoconf subdirectories (eg. make dist). 11. rpcgen generated files are not part of the source-tree (Automake conventions favor supplying generated files inside the source-tree, however there is no support for rpcgen generated files in automake, cf. yacc/lex support in automake). 12. RTEMS_HAS_RDBG handling is flaky. make/*.cfg use RTEMS_HAS_RDBG per CPU, while librdb's sources can only be built per BSP. Raises the more general question whether librdbg located correctly in the source-tree. 13. All make/*cfg files are configured per cpu, currently there is no location to store per-bsp configuration information --> bsp.cfg, per aconfig.h? 14. "make install" without having run "make all" beforehand does not work. 15. handling of --enable-multiprocessing seems to be broken in make/custom/* 16. Makefile.ins still exploit many gmake features. 17. File permisson chaos on libraries (no explict -m for libraries/rels/etc). 18. mcp750 Makefiles are broken (Note: I *do* mean buggy - I am not talking about "not-conforming to conventions", here :-). 19. Dependencies between configure scripts are not handled, eg. aborting "make RTEMS_BSP=<bsp>" can leave the build-tree in an unusable state. 20. "make clean" does not delete <build-tree>/<bsp>. This is intentional for now, because rerunning "make" after "make clean" requires an explicit "make preinstall" afterwards now. This should be done automatically, but doesn't work in this case for now. To work around this problem <build-tree>/<bsp> is kept during "make clean" for now (HACK). TODO: 1. split out host-compiled bsp-tools 2. Use Cygnus/GNU standards for cross-compiling target-subdir (CC=CC_FOR_TARGET .. configure --host=${target_alias} --build=`config.guess'}), to be added to toplevel configure script after splitting out bsp-tools. 3. Exploit per cpu support directory (c/src/<cpu>)- Splitting out per-cpu libraries - Are there any? 4. Further automake support 5. Converting subdirectories into standalone / self-contained subdirectories (Esp. moving their headers to the same common root as their sources, eg. mv lib/include/rtems++ lib/librtems++/include/rtems++) - This is the main obstacle which prevents moving further towards automake. 6. Propagating values from *.cfg into Makefiles instead of propagating them at make time via Makefile-fragments (i.e. try to avoid using *.cfg). 7. Testing on cygwin host (I *do* expect cygwin specific problems). 8. The ARCH in o-$(ARCH)-$(VARIANT) build-subdirectories is not needed anymore. GENERAL ISSUES: 1. Temporary installation tree -- Ian and I seem to disagree basically. Though I think that I understand his argumentation, I do not share it. IMO, his way of using the buildtree is mis-using the build-tree, relying on an inofficial feature of RTEMS's current implementation, which doesn't even work correctly in the current build-tree, though it attempts hard to do so. From my very POV, it unnecessarily complicates the structures of the source- and build-trees. It is not supported by automake (No automatic generation for the necessary rules) and complicates the transition to automake significantly (Generating the rules with an enhanced version of acpolish could be possible). As Ian correctly pointed out, here a management decision is needed - though I don't see the need to draw this decision in short terms. 2. preinstallation generally is a sure means to spoil the structure of the source tree, IMHO (No ranting intended, I am completly serious about this one). eg. through tree dependencies. The worst problem related to this I have found in the meantime is bsp_specs. bsp_specs is part of libbsp, ie. there is *no* way to build *any* part of the source tree *without* having a BSP *preinstalled*. Note: This issue is related to issue 1., but is not identical - The difference is the change of the order make rules have to be triggered. While preinstallation triggers rules spread all over the source tree before a "make all" can be run, a temporary installation tree could also be installed by post "make all" hooks (all-local:, to be run after make all in a directory is completed) if the directories' dependencies would be a tree, 3. Stuctural dependencies between subdirectories. 4. Depth of the source tree (Prevents multilibbing and introduces many unnecessary configure scripts). 5. per cpu vs. per bsp configuration (There are no real per-cpu parts yets :-). 6. automake does not support $makefiles in AC_OUTPUT. Unlike before, we now should try to avoid RTEMS_CHECK_MAKEFILE and to hard-code as much paths to Makefiles as possible. 7. General redesign of the source tree 8. Main installation point - Changing it to ${prefix}/${target_alias}. ? Besides item 8. (which is a must, IMHO), as far as I see most of them can not be solved soon and will remain issues in the mid- to long-term :-. REMARKS: * You (as the maintainer) should always use --enable-maintainer-mode when building RTEMS to ensure that maintainer mode generated files (esp. those in c/src/make) will be updated when make/* files have changed. * Use @RTEMS_BSP@ in Makefile.ins and Makefile.ams below c/src/, $(RTEMS_BSP) or ${RTEMS_BSP} will be overridden from environment variables when using make RTEMS_BSP="....". * c/src/make is a temporary cludge until configuration issues are solved. At the moment it is configured per bsp, but contains per-target/cpu info only. Its main purpose now is to circumvent modifying make/*.cfg files, because I consider make/* to be frozen for backward compatibilty. * This patch should only affect configuration files. At least I do not remember having touched any source files. * To build the bare bsp you now need to mention it in --enable-rtemsbsp. Example: building gensh1 and sh1/bare simultaneously: ../rtems-rc-19990709-1/configure --target=sh-rtems \ --enable-rtemsbsp="bare gensh1" \ --prefix=/tmp/rtems \ --enable-bare-cpu-cflags='-DMHZ=20 -m1 -DCPU_CONSOLE_DEVNAME=\"/dev/null\"' \ --enable-bare-cpu-model=sh7032 \ --enable-maintainer-mode \ --enable-cxx make make install * The next steps in development would be to split out bsp-tools and then to change to Cygnus/GNU canonicalization conventions for building the c/ subdirectory afterwards (i.e. many standard AC_*.m4 macros could be used instead of customized versions) FINAL REMARK: The issues mentioned in the lists above sound much worser than the situation actually is. Most of them are not specific to this patch, but are also valid for the snapshot. I just wrote down what I came across when working on the patch over the last few weeks. I wouldn't be too surprised if you don't like the patch at the current point in development. I am willing to discuss details and problems, I also have no problem if you would post-pone applying this patch to times after 4.1, but rejecting it as a whole for all times would be a false management decision, IMHO. Therefore I would suggest that you, if your time constaints allow it, should at least play a little while with this patch to understand what is going on and before drawing a decision on how to handle this proposal. I know this patch is neither perfect nor complete, but I consider it to be a major breakthrough. Don't be anxious because of the size of the patch, the core of the patch is rather small, the size is mainly the side effect of some systematic cleanups inside the Makefiles (result of acpolish). Feel free to ask if you encounter problems, if you don't understand something or if you meet bugs - I am far from being perfect and am prepared to answer them. Ralf. -- Ralf Corsepius Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW) Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690 mailto:corsepiu@faw.uni-ulm.de FAX: +49/731/501-999 http://www.faw.uni-ulm.de
* Added rules to handle alternate suffixes for C++ files.Joel Sherrill1999-05-071-0/+9
* Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows:Joel Sherrill1999-03-171-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The following emailJoel Sherrill1999-02-241-8/+19
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | is long but I hate to lose the information so I am including it here. > I am still fixing and recompiling but this is the issue that was not the > result of another patch. This is a fundamental build issue that I value > your opinion on. This is difficult issue (I.e. I have no destinct solution for it) Background: (gnu-) make's implicit rules apply CFLAGS, CPPFLAGS, CXXFLAGS, ASFLAGS and LDFLAGS (cf. make.info/Implicit Rules/Catalogue of Rules), only. In brief: CPPFLAGS .. passed to the c-preprocessor CFLAGS ... passed to the c-compiler CXXFLAGS ... equivalent to CFLAGS but passed to the c++ compiler (Attention: CFLAGS is not passed to the c++ compiler) ASFLAGS .. equivalent to CFLAGS, but passed to the assembler LDFLAGS .. equivalent to CFLAGS, but passed to the linker A bit oversimplifying, these make rules are as follows .c.o: $(CC) $(CPPFLAGS) $(CFLAGS) -c .cc.o: $(CXX) $(CPPFLAGS) $(CXXFLAGS) -c .S.s: $(CPP) $(CPPFLAGS) .s.o: $(AS) $(ASFLAGS) My reading of the documentation (make.info) is that {AS|AR|CC|CXX|CPP}FLAGS are ment to be passed to the related tools directly, however examinating the rule set of gmake (gmake -p -f /dev/null") shows that many rules use $(CC) instead of the related tools (eg. linker rules) etc. I.e. these flags should not rely on being passed through cpp or gcc. With gcc being the common frontend for all of these tools of a gnu-toolchain the situation becomes difficult (Which option is passed to whom and which tool really uses it?), because these variable can also contain the toolchain's frontend (eg. AS=gcc, LD=gcc, CPP=gcc -E). For some commonly used options the situation is quite clear: * -g -> CFLAGS * -OX -> CFLAGS * -D -> CPPFLAGS * -A -> CPPFLAGS But where to add -m, -B, -specs, -qrtems_XXX ? * -B, -specs, -qrtems_XXX are gcc-frontend options * -m is a combinations of flags to go to different destinations, in many (all?) cases, the following is valid -m is expanded by gcc into a set of -D and -A options -m is interpreted by cc1 as a machine flag to generate a specific instruction set. -m is interpreted by gcc as an implicit linker search path for multilibs to set up calls to LD. >From my point of view this indicates we can either destingush between these different usages (= separately add -m to CFLAGS, LDFLAGS etc) or to add it to CPPFLAGS and use gcc (the frontend) instead of calling each tool directly (less error prone) -- I vote for CPPFLAGS, but I am not sure. ----------------- Now, where to add CPU_CFLAGS? AFAIS, in probably all cases CPU_CFLAGS contain -D -A, and -m options, only. * -D and -A are supposed to go to CPPFLAGS * -mXXX options can have multiple meanings (It can be gcc, collect2/ld and cc1/cc1plus option simultaneously) Here, I made a mistake - I destinguished between CPU_DEFINES to be added to CPPFLAGS and CPU_CFLAGS to be added to CFLAGS and CXXFLAGS (cf. gcc-target-default.cfg), generally assuming CPU_CFLAGS are CFLAGS. This breaks preprocessing *.S into *.i files because CPU_CFLAGS flags were not added to CPPFLAGS. Hence *all* *.S were compiled without taking -mXX-flags into account. The i960/cvme BSP was the only one which explicitly checked for a specific -m flag (-mca) and refused to compile without it -- all other CPUs/BSPs silently swallowed this. IMO, we can either 1) add CPU_CFLAGS and CPU_DEFINES to CPPFLAGS, thus silently convert CPU_CFLAGS's meaning into CPU_DEFINES (Alternative solution: rename CPU_CFLAGS to CPU_DEFINES and merge CPU_FLAGS with CPU_DEFINES). or 2) destinguish between CPU_DEFINES and CPU_CFLAGS. In this case we would need to check the contents of each CPU_CFLAGS in custom/*.cfg and move the some parts of the contents to CPU_DEFINES and keep other parts in CPU_CFLAGS (CFLAGS must contain options for the c/c++-compiler only!). Though Solution 2) is the clearer one, I implemented 1) which is the simplier one (the patch below). ATTENTION: This patch is small in size, but affects almost everything. ------------ Additional complications araise with linking: Some BSPs call LD and AS directly (esp. gcc-2.7 make-exe rules). If LD=gcc then LDFLAGS are supposed to be gcc-options, but if LD=ld then LDFLAGS is supposed to contain ld-options. An analog thought is valid for AS, but luckily enough ASFLAGS is not used of inside the whole source tree. Most RTEMS' custom/*.cfg use $(CC) $(CFLAGS) to link with gcc-2.8 make-exe rules. With the patch below (CPU_CFLAGS added to CPPFLAGS) this means CPU_CFLAGS will not be passed to the linker, which is incorrect for multilibbed CPU's. gmake's default rule set contains a variety of rules for linking, all ending up in calling $(CC) $(LDFLAGS) for linking at their very end. IMO, this means we should use something like LINK.o = $(CC) $(LDFLAGS) in gcc-target-default.cfg + modify all gcc-2.8 make-exe rules to use $(LINK.o) ....... + setup LDFLAGS according to the requirements of the above. I.e. we should use $(CC) for linking instead of calling the linker (LD) directly and set LDFLAGS = $(CPPFLAGS) $(CFLAGS) or similar.
* Added rejected patch from automake VI from Ralf Corsepius.Joel Sherrill1999-02-181-6/+9
* Part of automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-183-52/+27
| | | | | | | | | | | | | | > 2) rtems-rc-19990131-1.diff > > Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt > the flags/makefile variables to automake and make standards (cf. > make.info - implicit rules/variables). > > This patch is rather risky and may probably break things, but is an > essential step towards automake. > > FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong, > as I had to experience ;-.
* Changed definition of ASMFLAGS since as does not recognize -B optionJoel Sherrill1999-01-191-1/+1
| | | | used in gcc.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename allJoel Sherrill1998-12-141-8/+1
| | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-141-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 2. "make profile" doesn't work. It aborts when building host-tools for embedded targets. I didn't yet have enough time to fix this problem. AFAIS this problem is related to handling of LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use gcc for linking host applications, too. With profiling enabled CFLAGS_PROFILE_V contains -pg and is used to compile, but LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the linker causing gcc to fail to link, because it can't resolve some symbols introduced by compiling with -pg. I am not sure if I can provide a patch for this - Ether it is trivial to fix or requires basic work on host configuration ;- Fixing this one was trivial - But hard to trace. LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V, if gcc is used for linking (What else should have been expected ?, :-). The same problem was present for *_DEBUG_V, but apparently wasn't noticed by anybody, because things didn't break, but were silently ignored. I fixed these problems by setting these flags in configure.in whenever gcc is reported to be the host-compiler. For non-gcc host compilers "make debug" and "make profile" now becomes the same as an ordinary "make". This is a hack and addressing this problen could be more sophisticated, but I don't think it gives much sense to support compile variants for any host program (Who will ever try to profile/debug host tools?). Therefore I don't think it's useful to invest more effort into this problem.
* Patch from Chris Johns <ccj@acm.org>:Joel Sherrill1998-09-101-1/+1
| | | | | | | | | | | I have managed to build the bsp ods68302 and the rtti test case I made with egcs-1.1b and binutils-2.9.1. I have built our C++ application and got no link errors so it looks like this is now working. I am yet to test the code but getting the thing to link was the problem. Please find a patch attached which removes the -fno-rtti option.
* A patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-08-211-0/+203
| | | | | | | | | | | | | | | | | | | | | | | | | | Here is another patch to hopefully enhance rtems' configuration. Motivation: Try to support other c-compilers besides gcc (I tried to build rtems under Solaris using sun's WSPro c-compiler). Here is a couple of small patches concerning the host compiler configuration, which fix/work-around the worst problems when using sun's WSPro c-compiler. Changes: * Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie. gcc.cfg is generated by configure now. * Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix). * Add -g to host compiler flags only if configure reported -g to work * Add -Wall to host compiler flags only if configure reported that the host compiler is gcc (WSPro's cc chokes on -Wall). * Some modifications to make/Makefile.in * Adapted make/custom/default.cfg to the new location of gcc.cfg BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS etc.) which deserves to be cleaned up, IMO. IMO, a similar patch should be applied to gcc-target-default.cfg
* Patches from Eric NorumJoel Sherrill1998-08-201-7/+1
* FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1998-08-201-1/+7
* Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to make ASFLAGS include theJoel Sherrill1998-08-011-1/+1
| | | | CPU_ASFLAGS.
* Added missing parts of patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-07-281-4/+16
* Yet another EXEEXT patch. This one is from Ralf CorsepiusJoel Sherrill1998-07-111-2/+2
| | | | | | | | <corsepiu@faw.uni-ulm.de> and his comments are below: Joel, obviously you did apply my previous patch to gcc-target-default.cfg -- This should have been gcc.cfg (gcc-target-default.cfg should NOT contain any EXEEXT).
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. Comments:Joel Sherrill1998-07-101-2/+2
| | | | | | | | | | | | | | | | | | > It seems that rules for %{EXEEXT} don't exist in gcc-target-default.cfg No, gcc-target-default.cfg is used to compile executables for the target only, not for the host. EXEEXT may only be used for programs to be run on the host. > What should I add please? This was a bug in my initial configuration patch to rtems-980616. A correction to this patch I had sent to Joel at 26.06.98 doesn't seem to have made it into the snapshot. Please find attached the patch I had sent to Joel, hopefully this patch fixes this problem.
* Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1998-06-273-31/+43
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
* Added rule for .cxx and .cpp per suggestion from Geoffroy MontelJoel Sherrill1998-06-091-0/+6
| | | | <g_montel@yahoo.com>.
* Added names for C++ compilers.Joel Sherrill1998-05-271-0/+7
* Changed CPP rule per patch from Ralf Corsepius.Joel Sherrill1998-05-201-1/+1
* Added C++ rule.Joel Sherrill1998-05-181-1/+22
| | | | Added CROSS_TARGET conditionals so unix port can share this file.
* Purged references to STACK_CHECKER_REPORT_USAGEJoel Sherrill1998-04-062-6/+1
* Reordered CFLAGS definition so CFLAGS_DEFAULT is beforeJoel Sherrill1998-04-062-4/+2
| | | | | CFLAGS_$(TARGET_VARIANTS). This makes sure that -Wall appears before any individual warnings are disabled during "debug" builds.
* added -Wno-unused to debug flagsJoel Sherrill1998-02-171-1/+1
* Added unused warning per discussion on rtems-snapshots list.Joel Sherrill1998-02-171-2/+2
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-02-172-32/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Yep, I have a bunch of bug-fixes and additions pending (Yet another monster patch, ... I can hear you scream :-). 1) configure.in : one AC_CONFIG_HEADER(...) line too much. 2) configure.in: gcc28 support is enabled by default, i.e. if no --enable-gcc28 option is passed on the command line. I am not sure if this is intentional. IMO, AC_ARG_ENABLE for --enable-gcc28 should look like: AC_ARG_ENABLE(gcc28, \ [ --enable-gcc28 enable use of gcc 2.8.x features], \ [case "${enableval}" in yes) RTEMS_USE_GCC272=no ;; no) RTEMS_USE_GCC272=yes ;; *) AC_MSG_ERROR(bad value ${enableval} for gcc-28 option) ;; esac],[RTEMS_USE_GCC272=yes]) 3) At the end of c/src/exec/score/cpu/m68k/m68k.h > #ifdef __cplusplus > } > #endif > > #endif /* !ASM */ in my opinion these two statements should be swapped: > #endif /* !ASM */ > > #ifdef __cplusplus > } > #endif I didn't try to compile for m68k, but does't this give an error? Is it compensated somewhere else - or didn't I look carefully enough? 5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as gnu-programs use "cxx" to specify C++ specific configure options, while cpp is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf internally uses $CXX), 6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I submitted the contents of an old aclocal-directory last time. - Sorry. 7) For sh-rtems, we currently need to add additional managers to MANAGERS_REQUIRED (from inside of custom/*.cfg). Currently MANAGERS_REQUIRED is defined in make/compilers/*.cfg. This seems to prevent overriding MANAGERS_REQUIRED from custom/*.cfg files - Obviously the files are included in such a way that the settings from compilers/*cfg always override settings from custom/*.cfg files. Furthermore, I think, defining MANAGERS_* inside gcc-<target>.cfg files is not correct - MANAGERS are not gcc-variant-dependent, but depend on targets/bsps and therefore should be defined in a bsp/target dependent file, e.g. in custom/*.cfg or target.cfg.in. I think defining default settings for MANAGERS* in custom/default.cfg could be an appropriate location. But this requires all custom/*.cfg files to include default.cfg, which *-posix.cfg files don't seem to do. Therefore I would like propose to move MANAGERS* to target.cfg.in - they are included by all custom/*.cfg files. Perhaps we/you should use this opportunity to merge parts from custom/default.cfg into target.cfg.in. This ensures to have the setting included once per target makefile and will open the opportunity to have autoconf doing additional work on bsp-configurations. Peanuts sofar, ... but here it comes ... (:-) 8) I am preparing a major enhancement to autoconf support for gnutools/compilers. It is not yet finished, but usable and I'll therefore attach a preliminary version to this mail. Motivation: * Fix problems with --enable-gcc28, if target-cc is not gcc28 compatible * Fix -pipe problems * Fix problems with hard-coded paths in configuration files (esp. posix) * Fix consistency problems with explictly given gnutools and gcc's gnutools Currently included: * detection and checking of host and target compiler (gcc/g++) * checking if target gnutools are in path * checking if <target>-gcc -specs works (autodisabling gcc28 if not) * checking if <target>-gcc -pipe works Todo : * *posix.cfg files are not yet adapted => The hard-coded paths for these systems are still in use. * Check if the host compiler $CC is properly propagated to the Makefiles (I doubt it, but this should not matter) * Check if rtems' generic tools still work properly (It looks like, but who knows) * Integrate CXX support into default.cfg or gcc-target-default.cfg (It looks like C++ support is only used by posix BSPs) * Automatically handle RANLIB/MKLIB for targets * Plenty ... (:-) Open problems: * Untested for non-gcc compatible host and target compilers. This should be no problem if the tools are named follow gnutool's naming convention and are included in $PATH while running configure. * Intentionally using different tools than that gcc has been configured for, e.g. use a different assembler ? This should be still possible if XX_FOR_TARGET is hard-coded into custom/*.cfg. I don't see why anybody should want to do this, but who knows? I have tested this version on linux and solaris hosts, with gcc's directories mounted at weird non-standard mount points, using egcs (linux/sh-rtemscoff), gcc-2.7.2.2 using native tools (solaris), gcc-2.7.2.3 w/ gnutools (solaris/linux). I don't expect it to break anything, but of cause I can't promise it. It will break most/all *-posix.cfg configuration almost for certain, but not more as rtems' current *posix.cfg configurations already do (hard-coded configurations). I am not sure if this is ready to be included into the next snapshot or not. Perhaps you might try this on your systems and if it you don't notice serious bugs you might put it into the snapshot for public testing (I don't like this, but I don't see another possiblity to test generality). I enclose a patch for configure.in and some configuration files which comprizes fixes for all items mentioned except of #3 . Don't forget to run "aclocal -I aclocal; autoconf;" after applying the patch (:-).
* Incorporated Ralf Corsepius' idea for new -q flags to properly supportJoel Sherrill1998-02-111-0/+4
| | | | "gmake debug".
