path: root/make/compilers/gcc.cfg.in (follow)
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-141-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 2. "make profile" doesn't work. It aborts when building host-tools for embedded targets. I didn't yet have enough time to fix this problem. AFAIS this problem is related to handling of LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use gcc for linking host applications, too. With profiling enabled CFLAGS_PROFILE_V contains -pg and is used to compile, but LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the linker causing gcc to fail to link, because it can't resolve some symbols introduced by compiling with -pg. I am not sure if I can provide a patch for this - Ether it is trivial to fix or requires basic work on host configuration ;- Fixing this one was trivial - But hard to trace. LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V, if gcc is used for linking (What else should have been expected ?, :-). The same problem was present for *_DEBUG_V, but apparently wasn't noticed by anybody, because things didn't break, but were silently ignored. I fixed these problems by setting these flags in configure.in whenever gcc is reported to be the host-compiler. For non-gcc host compilers "make debug" and "make profile" now becomes the same as an ordinary "make". This is a hack and addressing this problen could be more sophisticated, but I don't think it gives much sense to support compile variants for any host program (Who will ever try to profile/debug host tools?). Therefore I don't think it's useful to invest more effort into this problem.
* A patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-08-211-0/+203
Here is another patch to hopefully enhance rtems' configuration. Motivation: Try to support other c-compilers besides gcc (I tried to build rtems under Solaris using sun's WSPro c-compiler). Here is a couple of small patches concerning the host compiler configuration, which fix/work-around the worst problems when using sun's WSPro c-compiler. Changes: * Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie. gcc.cfg is generated by configure now. * Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix). * Add -g to host compiler flags only if configure reported -g to work * Add -Wall to host compiler flags only if configure reported that the host compiler is gcc (WSPro's cc chokes on -Wall). * Some modifications to make/Makefile.in * Adapted make/custom/default.cfg to the new location of gcc.cfg BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS etc.) which deserves to be cleaned up, IMO. IMO, a similar patch should be applied to gcc-target-default.cfg
