* compilers/gcc-no_bsp.cfg: Remove (Unused).
* Makefile.am: Reflect change above.
* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg,
custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg,
custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate
START_BASE and START_FILE.
* compilers/gcc-no_bsp.cfg: Eliminate some obsolete junk.
* compilers/gcc-no_bsp.cfg: There are no longer any required managers.
Plus some cleanup
PR 321:
* leaf.cfg: Remove support for profile-variant.
* main.cfg: Ditto.
* compilers/gcc-no_bsp.cfg: Ditto.
* compilers/gcc-portsw.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS.
* custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272
support.
* custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V.
* compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags,
remove unused flags, remove -ansi from CPP.
* custom/eth_comm.cfg: Remove CPU_DEFINES.
* custom/sim68000.cfg: Remove CPU_DEFINES.
* compilers/gcc-no_bsp.cfg: Remove -ansi -fasm.
* compilers/gcc-default.cfg: Dito.
* compilers/gcc-portsw.cfg: Remove -Hansi.
* custom/posix.cfg: Remove inclusion of target.cfg.
* custom/simhppa.cfg: Remove -ansi -fasm.
> 2) rtems-rc-19990131-1.diff
> Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt
> the flags/makefile variables to automake and make standards (cf.
> make.info - implicit rules/variables).
> This patch is rather risky and may probably break things, but is an
> essential step towards automake.
> FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong,
> as I had to experience ;-.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
CFLAGS_$(TARGET_VARIANTS). This makes sure that -Wall appears
before any individual warnings are disabled during "debug" builds.
