path: root/make/Templates (follow)
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-182-2/+2
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename allJoel Sherrill1998-12-142-6/+6
| | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake.
* Patches from Eric NorumJoel Sherrill1998-08-201-1/+0
* Incorporated Ralf Corsepius' idea for new -q flags to properly supportJoel Sherrill1998-02-111-0/+7
| | | | "gmake debug".
* Fixed so installed Makefile structure work.Joel Sherrill1998-02-021-3/+4
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-304-3/+6
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-204-0/+183
