path: root/make/Templates (follow)
* Incorporated Ralf Corsepius' idea for new -q flags to properly supportJoel Sherrill1998-02-111-0/+7
| | | | "gmake debug".
* Fixed so installed Makefile structure work.Joel Sherrill1998-02-021-3/+4
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-304-3/+6
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-204-0/+183
