path: root/make/Templates/Makefile.dir (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-1/+3
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-1/+1
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-1/+1
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-201-0/+9
