path: root/make/Makefile.in (unfollow)
1999-02-18Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-9/+11
> 5) rtems-rc-19990202-1.diff/reorg-install.sh > > reorg-install.sh fixes a Makefile variable name clash of RTEMS > configuration files and automake/autoconf standards. > Until now, RTEMS used $(INSTALL) for install-if-change. Automake and > autoconf use $(INSTALL) for a bsd-compatible install. As > install-if-change and bsd-install are not compatible, I renamed all > references to install-if-changed to $(INSTALL_CHANGED) and used > $(INSTALL) for bsd-install (==automake/autoconf standard). When > automake will be introduced install-if-change will probably be replaced > by $(INSTALL) and therefore will slowly vanish. For the moment, this > patch fixes a very nasty problem which prevents adding any automake file > until now (There are still more).
1998-08-24Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-9/+15
The patch (rtems-rc-980821.diff) I had sent recently to fix the "make install" problem in rtems-980821/make/ still contained a bug (Thanks to Eric N. for reporting it). The patch enclosed to this mail is a corrected version of this patch, which finally should fix this problem.
1998-08-21A patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-32/+31
Here is another patch to hopefully enhance rtems' configuration. Motivation: Try to support other c-compilers besides gcc (I tried to build rtems under Solaris using sun's WSPro c-compiler). Here is a couple of small patches concerning the host compiler configuration, which fix/work-around the worst problems when using sun's WSPro c-compiler. Changes: * Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie. gcc.cfg is generated by configure now. * Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix). * Add -g to host compiler flags only if configure reported -g to work * Add -Wall to host compiler flags only if configure reported that the host compiler is gcc (WSPro's cc chokes on -Wall). * Some modifications to make/Makefile.in * Adapted make/custom/default.cfg to the new location of gcc.cfg BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS etc.) which deserves to be cleaned up, IMO. IMO, a similar patch should be applied to gcc-target-default.cfg
1998-03-31Fixed CUSTOM_FILES rule so it properly picked up files included fromJoel Sherrill1-2/+11
make/custom files.
1998-01-30Big patch form Ralf Corsepius described in this email:Joel Sherrill1-4/+2
Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in
1998-01-20Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1-0/+85
