* Makefile.am: Add qemuppc.cfg.
* custom/qemuppc.cfg: New file.
* Makefile.am: New Gumstix BSP.
* custom/gumstix.cfg: New file.
* Makefile.am: Remove custom/HPUX9-posix.cfg.
* Makefile.am: Add Lattice Mico32 support.
* custom/lm32_evr.cfg: New file.
* Makefile.am: Add h8sxsim BSP variant.
* custom/h8sxsim.cfg: New file.
* Makefile.am, custom/simsh4.cfg: Recognize the the GDB SuperH
simulator is just an architectural simulator and does not include
devices. Rename existing simulator BSP configurations to simsh1 and
simsh2 and add simsh4.
* custom/simsh1.cfg, custom/simsh2.cfg: New files.
* custom/shsim.cfg, custom/simsh7032.cfg, custom/simsh7045.cfg: Removed.
* Makefile.am: Add smdk2410.
* Makefile.am: Add nds.
* Makefile.am: DMV152 obsoleted.
* custom/dmv152.cfg: Removed.
* Makefile.am: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP
variants.
* custom/erc32nfp.cfg, custom/leon1.cfg: Removed.
* Makefile.am: Add custom/rtl22xx.cfg.
* make/Makefile.am: Cleanup.
* Makefile.am: New port to Altera NIOS II.
* custom/nios2_iss.cfg: New file.
* Makefile.am: Adding GameBoy Advance BSP.
* custom/gba.cfg: New file.
* Makefile.am: Remove dmv177 and ppcn_60x.
* custom/dmv177.cfg: Removed.
* Makefile.am: Initial release of ep1a bsp
* custom/ep1a.cfg: New file.
* compilers/gcc-portsw.cfg: Remove.
* Makefile.am: Reflect change above.
* Makefile.am: Remove eth_comm.
* custom/eth_comm.cfg: Removed.
* Makefile.am: Add MVME2100 BSP.
* custom/mvme2100.cfg: New file.
* Makefile.am: Cosmetics.
* Makefile.am: dist_rtems_make_DATA = main.cfg leaf.cfg.
dist_rtems_make_custom_DATA = custom/default.cfg.
* Makefile.am: Remove obsolete custom/*.cfg.
* Makefile.am: Remove efi68k and efi332 references as they are no
longer in the tree.
* Makefile.am: EXTRA_DIST +=.
* custom/Makefile.am: Remove.
* Makefile.am: Merge-in former custom/Makefile.am
* Makefile.am: Add compilers/*.
* compilers/Makefile.am: Remove.
* lib.cfg: Remove.
* directory.cfg: Remove.
* README: Remove.
* Makefile.am: Add Templates/*.
* Templates/Makefile.am: Remove.
* Templates/Makefile.am: Remove AUTOMAKE_OPTIONS.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
