path: root/make/ChangeLog (follow)
* 2004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-131-0/+5
| | | | | * Makefile.am: dist_rtems_make_DATA = main.cfg leaf.cfg. dist_rtems_make_custom_DATA = custom/default.cfg.
* 2004-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-051-0/+5
| | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Re-added these -- copied from the 4.6 branch.
* 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-041-0/+5
| | | | | PR 553/bsps * custom/mrm332.cfg: Comment out objdump.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-211-0/+4
| | | | * Makefile.am: Remove obsolete custom/*.cfg.
* 2004-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-201-0/+6
| | | | | | PR 553/bsps * custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a comment.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-0/+5
| | | | | * Makefile.am: Remove efi68k and efi332 references as they are no longer in the tree.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-0/+6
| | | | | | Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any users of these boards so we are removing them. * custom/efi332.cfg, custom/efi68k.cfg: Removed.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-0/+4
| | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Removed.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | * Makefile.am: EXTRA_DIST +=.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-0/+5
| | | | | * custom/Makefile.am: Remove. * Makefile.am: Merge-in former custom/Makefile.am
* 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-241-0/+5
| | | | | * custom/HPUX9-posix.cfg: Remove INLINE, INLINE_UPCASE. * custom/default.cfg: Remove INLINE,INLINE_UPCASE.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-261-0/+4
| | | | * custom/simhppa.cfg: Removed.
* 2003-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-091-0/+4
| | | | | | | PR 470/bsps * custom/mcp750.cfg, custom/mtx603e.cfg, custem/mvme2307.cfg (make-exe): Rearrange arguments in calls to OBJCOPY to $(OBJCOPY) options infile outfile. (Reported for mcp750.cfg by Andrew Harris <Andrew.Harris@jhuapl.edu>).
* 2003-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-241-0/+7
* 2003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-201-0/+6
| | | | | | * custom/mvme167.cfg: Remove PRINTK_MINOR, CONSOLE_MINOR (move to the BSP's configure-script). Remove BSP_CPPFLAGS (Obsolete).
* Changed format so script will see PR number.Joel Sherrill2003-06-131-1/+1
* 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-061-0/+9
| | | | | | | | | PR 321: * leaf.cfg: Remove support for profile-variant. * main.cfg: Ditto. * compilers/gcc-no_bsp.cfg: Ditto. * compilers/gcc-portsw.cfg: Ditto. * compilers/gcc-target-default.cfg: Ditto.
* 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-271-0/+4
| | | | * custom/mvme2307.cfg: Remove CFLAGS_PROFILE_V.
* 2003-03-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill2003-03-251-0/+6
| | | | | | PR 368/filesystems * custom/mbx821_002.cfg, custom/mbx821_002b.cfg: New files included with this PR for alias BSPs.
* 2003-03-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-03-181-0/+6
| | | | | | PR 356/bsps * custom/mvme2307.cfg: This patch makes RTEMS/PowerPC eabi compliant. Enable EABI by adding -meabi -msdata=eabi CFLAGS.
* Merger from rtems-4-6-branchRalf Corsepius2003-03-101-0/+11
* 2003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-141-0/+5
| | | | | AMD a29k obsolete. * custom/portsw.cfg: Removed.
* 2003-01-20 Duane Gustavus <duane@unt.edu>Joel Sherrill2003-01-201-0/+4
| | | | * custom/m2m332.cfg: Fix path to linkcmds_ROM.
* 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-151-0/+11
| | | | | | | | | | | * custom/Cygwin-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. * custom/FreeBSD-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. * custom/HPUX9-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. * custom/Linux-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. Move -D_BSD_SOURCE to CPU_CFLAGS. * custom/Solaris-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. Move -Dsolaris2 to CPU_CFLAGS. Remove -D__EXTENSIONS__.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+4
| | | | * custom/posix.cfg: Remove comment referring to host.cfg.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-291-0/+4
| | | | * custom/default.cfg: Pickup target.cfg from BSP directory.
* 2002-11-17 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-11-181-0/+4
| | | | * custom/mtx603e.cfg: New file.
* 2002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-181-0/+5
| | | | | * leaf.cfg, main.cfg, compilers/gcc-target-default.cfg: Make build variants work for user applications post install.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-0/+8
| | | | | | | | * custom/Cygwin-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/Linux-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/Solaris-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/FreeBSD-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/HPUX9-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-131-0/+4
| | | | * custom/edb7312.cfg: New file.
* 2002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-121-0/+7
| | | | | | | * custom/default.cfg: Remove RTEMS_BSP_SPECS. Remove reference to obsolete Makefile. * leaf.cfg: Various changes to LIBVARIANT processing. * main.cfg: Ditto.
* 2002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-121-0/+8
| | | | | | | | * Makefile.am: Add compilers/*. * compilers/Makefile.am: Remove. * lib.cfg: Remove. * directory.cfg: Remove. * README: Remove.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-071-0/+5
| | | | | * Makefile.am: Add Templates/*. * Templates/Makefile.am: Remove.
* 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-291-0/+4
| | | | * custom/Cygwin-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* 2002-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-261-0/+6
| | | | | | * custom/FreeBSD-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR. * custom/HPUX9-posix.cfg: Ditto. * custom/Linux-posix.cfg: Ditto.
* 2002-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-021-0/+4
| | | | * custom/armulator.cfg: Remove reference to PowerPC arguments.
* 2002-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-131-0/+8
| | | | | | | | * Part of addressing PR281. * main.cfg: Added recognition of VARIANT=DEBUG on command line. * compilers/gcc-target-default.cfg: Removed remaining support for RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug as one of the LDFLAGS when the debug variant is specified.
* 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-121-0/+4
| | | | * custom/posix.cfg: Don't include host.cfg.
* 2002-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-091-0/+4
| | | | * custom/gen405.cfg: Corrected make-cxx-exe rule to use LINK.cc.
* 2002-08-07 Ivan Guzvinec <ivang@opencores.org>Joel Sherrill2002-08-071-0/+4
| | | | * orp.cfg: Bender BSP renamed to OpenRisc Reference Platform or ORP.
* 2002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-071-0/+4
| | | | * custom/vegaplus.cfg: Fix bogus and corrupted make-exe.
* 2002-08-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-061-0/+5
| | | | | * custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* 2002-08-06 Chris Ziomkowski <chris@asics.ws>Joel Sherrill2002-08-061-0/+5
| | | | | * custom/or32sim.cfg: New file added as part of merge from OpenCores repository.
* 2002-08-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-051-0/+8
| | | | | | | | * Per PR260 eliminate use of make-target-options. This impacted RTEMS allowing a distinction between the CPU32 and CPU32+ in the SuperCore and required that the m68k optimized memcpy be moved to libcpu. * custom/gen68360.cfg: Remove make-target-options.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+6
| | | | | * eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg, mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-011-0/+4
| | | | * custom/mvme136.cfg: Per PR260 removed make-target-options.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-311-0/+5
| | | | | * custom/vegaplus.cfg: Generate the Mapfile into $(ARCH) so it will disappear when make clean is performed.
* 2002-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-241-0/+5
| | | | | * custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg: Updated to use gcc 3.1 arguments.
* 2002-07-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-221-0/+4
| | | | * Templates/Makefile.leaf: Clarify the MANAGERS example.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-0/+4
| | | | * custom/p4650.cfg: Update arguments to gcc3.
