* custom/m32csim.cfg:
Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/m32rsim.cfg:
* custom/lm32_evr.cfg:
* custom/icecube.cfg, custom/pm520_cr825.cfg, pm520_ze30.cfg:
* custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg:
* custom/bf537Stamp.cfg, custom/eZKit533.cfg:
* custom/brs5l.cfg:
* custom/h8sim.cfg, custom/h8sxsim.cfg:
* custom/c3xsim.cfg, custom/c4xsim.cfg:
* custom/pghplus.cfg:
* custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/haleakala.cfg, custom/mbx821_001.cfg,
custom/mbx821_002.cfg, custom/mbx821_002b.cfg,
custom/mbx860_001b.cfg, custom/mbx860_002.cfg,
custom/mbx860_005b.cfg, custom/mbx860_1b.cfg,
custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg,
custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg,
custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg,
custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg:
* custom/nios2_iss.cfg:
* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg,
custom/erc32.cfg:
* custom/avrtest.cfg:
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg,
custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg,
custom/pc686.cfg:
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg,
custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg,
custom/simsh4.cfg:
* custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg, custom/Solaris-posix.cfg, custom/posix.cfg:
Remove.
* Makefile.am: Add new BSP variants for ARM simulator in GDB.
* custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg,
custom/arm920.cfg, custom/armcortexa9.cfg: New files.
* Makefile.am: Add qemuppc.cfg.
* custom/qemuppc.cfg: New file.
* custom/gen83xx.cfg: Remove -funit-at-a-time.
* custom/leon2.cfg, custom/leon3.cfg: Fix typo.
* Makefile.am: New Gumstix BSP.
* custom/gumstix.cfg: New file.
* custom/csb637.cfg: New file.
* custom/simsh2e.cfg: New file.
PR 1371/bsps
* custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF.
* custom/uC5282.cfg: Add cvs Id.
* custom/h8sxsim.cfg: Small H8SX should be optimized for size.
* Makefile.am: Regenerate list of custom/*.cfg.
* Makefile.am: Remove custom/HPUX9-posix.cfg.
* custom/HPUX9-posix.cfg: Remove.
* custom/pck6.cfg: Remove.
* Makefile.am: Add Lattice Mico32 support.
* custom/lm32_evr.cfg: New file.
* custom/avrtest.cfg: New file.
PR 1337/bsps
* custom/pc386.cfg: Stripping .rodata section produces unusable
executables for the i386-rtems target.
* Makefile.am: Add h8sxsim BSP variant.
* custom/h8sxsim.cfg: New file.
* custom/m32rsim.cfg: New file.
* custom/m32csim.cfg: New file.
* custom/virtex.cfg: Remove -Dvirtex.
* custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Remove RTEMS_TQM_MODEL.
* custom/mpc5566evb.cfg, custom/mpc55xx.cfg: Remove
RTEMS_BOARD_MODEL.
* custom/pgh360.cfg: Remove RTEMS_BOARD_MODEL.
* custom/m5484FireEngine.cfg: Remove RTEMS_BOARD_MODEL.
Remove RTEMS_54XX_DERIVATE (Unused).
* custom/genmcf548x.cfg: Remove RTEMS_BOARD_MODEL.
* custom/brs5l.cfg, custom/gen5200.cfg, custom/icecube.cfg,
custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL.
* custom/gen83xx.cfg, custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg: Remove RTEMS_BOARD_MODEL,
RTEMS_83XX_DERIVATE.
* custom/erc32.cfg: Revert accidental commit.
* custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg,
custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg,
custom/pgh360.cfg, custom/pghplus.cfg, custom/pm520_cr825.cfg,
custom/pm520_ze30.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Back out parts of yesterdays changes.
* custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags.
* custom/score603e.cfg: Modifications required to run on hardware. Some
cleanup.
