* Makefile.am: Add qemuppc.cfg.
* custom/qemuppc.cfg: New file.
* custom/gen83xx.cfg: Remove -funit-at-a-time.
* custom/leon2.cfg, custom/leon3.cfg: Fix typo.
* Makefile.am: New Gumstix BSP.
* custom/gumstix.cfg: New file.
* custom/csb637.cfg: New file.
* custom/simsh2e.cfg: New file.
PR 1371/bsps
* custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF.
* custom/uC5282.cfg: Add cvs Id.
* custom/h8sxsim.cfg: Small H8SX should be optimized for size.
* Makefile.am: Regenerate list of custom/*.cfg.
* Makefile.am: Remove custom/HPUX9-posix.cfg.
* custom/HPUX9-posix.cfg: Remove.
* custom/pck6.cfg: Remove.
* Makefile.am: Add Lattice Mico32 support.
* custom/lm32_evr.cfg: New file.
* custom/avrtest.cfg: New file.
PR 1337/bsps
* custom/pc386.cfg: Stripping .rodata section produces unusable
executables for the i386-rtems target.
* Makefile.am: Add h8sxsim BSP variant.
* custom/h8sxsim.cfg: New file.
* custom/m32rsim.cfg: New file.
* custom/m32csim.cfg: New file.
* custom/virtex.cfg: Remove -Dvirtex.
* custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Remove RTEMS_TQM_MODEL.
* custom/mpc5566evb.cfg, custom/mpc55xx.cfg: Remove
RTEMS_BOARD_MODEL.
* custom/pgh360.cfg: Remove RTEMS_BOARD_MODEL.
* custom/m5484FireEngine.cfg: Remove RTEMS_BOARD_MODEL.
Remove RTEMS_54XX_DERIVATE (Unused).
* custom/genmcf548x.cfg: Remove RTEMS_BOARD_MODEL.
* custom/brs5l.cfg, custom/gen5200.cfg, custom/icecube.cfg,
custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL.
* custom/gen83xx.cfg, custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg: Remove RTEMS_BOARD_MODEL,
RTEMS_83XX_DERIVATE.
* custom/erc32.cfg: Revert accidental commit.
* custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg,
custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg,
custom/pgh360.cfg, custom/pghplus.cfg, custom/pm520_cr825.cfg,
custom/pm520_ze30.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Back out parts of yesterdays changes.
* custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags.
* custom/score603e.cfg: Modifications required to run on hardware. Some
cleanup.
Eliminate RTEMS_54XX_DERIVATE (Unused).
Eliminate RTEMS_TQM_MODEL (Unused).
custom/lpc2478.cfg, custom/m5484FireEngine.cfg,
custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg, custom/pgh360.cfg, custom/pm520_cr825.cfg
* custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use
RTEMS_BSP_FAMILY.
* custom/simsh1.cfg, custom/simsh2.cfg: Remove Author notice.
* Makefile.am, custom/simsh4.cfg: Recognize the the GDB SuperH
simulator is just an architectural simulator and does not include
devices. Rename existing simulator BSP configurations to simsh1 and
simsh2 and add simsh4.
* custom/simsh1.cfg, custom/simsh2.cfg: New files.
* custom/shsim.cfg, custom/simsh7032.cfg, custom/simsh7045.cfg: Removed.
* custom/bf537skyeye.cfg: Removed.
* custom/bf537Stamp.cfg, custom/erc32.cfg: Add skyeye alias for
bf537stamp.
* custom/bf537skyeye.cfg: New file.
* custom/lpc2478.cfg: Comment out use of U-Boot specific mkimage since
we do not reliably know it is installed.
* custom/ep1a.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg,
custom/psim.cfg, custom/score603e.cfg: Eliminate vestiges of mpc603e
define.
* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg,
custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg,
custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate
START_BASE and START_FILE.
PR 1314/bsps
* custom/mvme3100.cfg: Remove old stuff.
* compilers/gcc-no_bsp.cfg: Eliminate some obsolete junk.
* leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in
make-exe and make-cxx-exe definitions. This was resulting in the
linker script being processed twice and breaking some BSPs.
* leaf.cfg, compilers/gcc-target-default.cfg, custom/bf537Stamp.cfg,
custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg,
custom/mbx8xx.cfg, custom/mpc55xx.cfg, custom/nds.cfg,
custom/pc386.cfg, custom/tqm8xx.cfg: Remove use of AM_LDFLAGS. Ensure
LDFLAGS works all the time. Clean up BSPs which defined their own
make-exe rules inappropriately.
* custom/bf537Stamp.cfg: New file.
updated haleakala BSP
added MPC55xx BSP
