* compilers/gcc-no_bsp.cfg: Remove -ansi -fasm.
* compilers/gcc-default.cfg: Dito.
* compilers/gcc-portsw.cfg: Remove -Hansi.
* custom/posix.cfg: Remove inclusion of target.cfg.
* custom/simhppa.cfg: Remove -ansi -fasm.
* custom/eth_comm.cfg: Switch the eth_comm BSP to use the
"new exception processing model."
* custom/default.cfg: Switch to using exec_prefix to reflect new
organization of install point from Ralf Corsepius.
* custom/mbx860_005b.cfg: This switches the MBX8xx BSP to the
use the "new exception processing model."
* custom/genmongossev.cfg: New file.
* custom/pc386dx.cfg: New bsp.
* custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg,
custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg
* main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP).
* host.cfg.in: Remove RM, make-script.
* ChangeLog: Remove bogus 2001-01-22 entry.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and
simsh7045.
* custom/pc386.cfg (make-exe): Removed commented out lines that
were displayed in build longs.
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove
unneeded definitions when compiled for "mips" rather than "mips64orion."
Correct CPU_CFLAGS.
* custom/gensh1.cfg: Removed rest of make-target-options and
moved them to BSP configure options.
* custom/mcp750.cfg (make-exe): Rewrite to avoid writing to
install point or assuming BSP build tree is available.
* custom/psim.cfg: Removed unused variables.
* custom/sim68000.cfg: Corrected CPU model for simcpu32 configuration.
* custom/simcpu32.cfg: Removed MVME162 reference.
* custom/mcp750.cfg: Fix problems in generation of .exe file.
Still need to fix to avoid touching install point on non-install stanza.
* custom/vegaplus.cfg: Fix make-exe rule and eliminate mkdir
and copies that should not be in it.
* custom/jmr3904.cfg: Turn optimization back up to -O2.
* custom/jmr3904.cfg: Use -m3900 not -mips3. TX3904 is actually
a mips1. gcc translates -m3900 into that.
* custom/jmr3904.cfg: Fix incorrect reference to i960.
* custom/shsim.cfg: New file.
* custom/Makefile.am: Modified to reflect addition of shsim.cfg.
The shsim is for the SH simulator in gdb. It should be able
to be used with multiple SH CPU models. This will require
adding BSP variants.
* custom/pc386.cfg: make-exe rule would write into
$(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE)
is generally not writeable after the BSP is installed and you do not
want every application installed there by default. Reported by
Eric Norum <eric.norum@usask.ca>.
* custom/Makefile.am: Updated to add jmr3904.cfg
* custom/jmr3904.cfg: New file.
* custom/leon2.cfg: Removed defines that are now generated
in a non-BSP specific manner.
* custom/Makefile.am: Modified to reflect addition of files.
* custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant.
* custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
* custom/Cygwin-posix.cfg: Add -U__STRICT_ANSI__ to LIBC_DEFINES.
* custom/bare.cfg: Add @ to make-exe, make make-exe more verbose.
* custom/p4600.cfg, custom/p4650.cfg: Commented out RTEMS_CPU
definition since this information can be picked up from
autoconf generated files. These BSPs are shared by the
mips and mips64orion "ports."
* compilers/gcc-portsw.cfg: Use gcc style flags.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg,
custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and
Eric Valette <valette@crf.canon.fr>.
* custom/vegaplus.cfg: New file.
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress.
* custom/gen68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68340.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68360.cfg: Comment out LIBC_LIB[C|M].
* custom/idp.cfg: Comment out LIBC_LIB[C|M].
* custom/mvme162.cfg: Comment out LIBC_LIB[C|M].
* custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gensh2.cfg: Fix comments.
* custom/mvme167.cfg (CPP_CFLAGS): Corrected to only include
compiler arguments that specify CPU model options.
* custom/mbx860_005b.cfg (make-target-options): Add lines to
define PRINTK_MINOR SMC1_MINOR and PRINTK_IO_MODE. The settings
may be incorrect but the BSP now compiles.
* custom/arm_bare_bsp.cfg: Fix comments.
* custom/gensh1.cfg, custom/gensh2.cfg: Abandon gcc-2.7.2's make-exe
* custom/simcpu32.cfg: Set RTEMS_BSVC_MODEL = simcpu32
* ChangeLog: File paths corrected
* custom/armulator.cfg: Corrected make-exe rule to pick up debug flags.
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* custom/mbx8xx.cfg: Add support for configuration parameters in NVRAM
* ChangeLog: File paths corrected.
* mvme167.cfg: Add specification of printk port, console port
and serial I/O mode. Arrange for the stripped executable to
be copied up the build tree.
* mbx8xx.cfg: Support for shared printk and no termios.
2000-08-10 John Cotton <john.cotton@nrc.ca>
* mbx8xx.cfg: Support added for dejagnu test harness.
