* custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj.
* custom/dmv152.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg:
Use .srec for files containing SRECs.
* custom/gp32.cfg: Replace .gxb with .elf.
* custom/i386ex.cfg, custom/ts_386ex.cfg: Replace .coff with .elf.
* custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use
-mcpu=750 instead.
* custom/orp.cfg: Remove (abandoned).
* custom/av5282.cfg: Remove obsolete vars.
* custom/gba.cfg: Remove PROFILE* (abandoned).
Remove -static (bogus).
PR 822/bsps
* custom/mbx860_001b.cfg, custom/mbx860_1b.cfg: New files.
* custom/av5282.cfg: New file.
* Makefile.am: Adding GameBoy Advance BSP.
* custom/gba.cfg: New file.
* custom/mcf5235.cfg: New file.
* custom/gp32.cfg: Add make-cxx-exe.
* custom/mbx860_005b.cfg, custom/mcp750.cfg, custom/mtx603e.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg:
Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete).
* Makefile.am: Remove dmv177 and ppcn_60x.
* custom/dmv177.cfg: Removed.
* custom/ppcn_60x.cfg: Remove (Gone from libbsp).
* Makefile.am: Initial release of ep1a bsp
* custom/ep1a.cfg: New file.
* custom/score603e.cfg: Update score603e to new exception model
NOTE: These modifications have not been tested on hardware.
* custom/vegaplus.cfg: Removed.
* custom/gp32.cfg: New file.
* custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI.
* custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V.
Remove -Wa,-m7450.
* custom/jmr3904.cfg: arm_bare_bsp obsoleted.
* custom/arm_bare_bsp.cfg: Removed.
* custom/csb350.cfg: New BSP.
-m528x as an order to load the -m5200 multilib variants) are widely available.
* custom/uC5282.cfg: Cleanup.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg,
custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg,
custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg,
custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for
gcc 4.x. Hopefully they are still OK for gcc 3.3.5.
* compilers/gcc-portsw.cfg: Remove.
* Makefile.am: Reflect change above.
* Makefile.am: Remove eth_comm.
* custom/eth_comm.cfg: Removed.
PR 581/bsps
* custom/psim.cfg: Convert PSIM to new exception model.
* custom/mvme2100.cfg: Add make-cxx-exe rule.
* Makefile.am: Add MVME2100 BSP.
* custom/mvme2100.cfg: New file.
* custom/csb336.cfg, custom/csb337.cfg: RTEMS_CPU must match an
architecture name for RTEMS. Since this was used as the -mcpu
argument to GCC, that also had to be changed.
* custom/c3xsim.cfg, custom/c4xsim.cfg: Expand files.
* custom/h8sim.cfg: i960 obsoleted.
* custom/cvme961.cfg, custom/i960sim.cfg, custom/rxgen960.cfg: Removed.
* custom/csb360.cfg: New file.
* custom/csb336.cfg, custom/csb337.cfg: New files.
* custom/FreeBSD-posix.cfg: Remove LIBC_DEFINES (Meaningless
with FreeBSD and now unused).
* custom/Solaris-posix.cfg: Add -D__EXTENSIONS__ to CPU_CFLAGS.
* custom/ss555.cfg: New file.
* make/Cygwin-posix.cfg: Remove DEFINES + LIBC_DEFINES (Meaningless
with Cygwin and now unused).
* make/Linux-posix.cfg: Merge LIBC_DEFINES into CPU_CFLAGS.
* custom/p4650.cfg: Remove obsolete variables and get closer to gcc 3.x
support.
PR 570/bsps
* custom/mvme2307.cfg: Do not use -msdata=eabi since
it breaks the linking of the vectors.
* Makefile.am: Cosmetics.
* Makefile.am: dist_rtems_make_DATA = main.cfg leaf.cfg.
dist_rtems_make_custom_DATA = custom/default.cfg.
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Re-added
these -- copied from the 4.6 branch.
PR 553/bsps
* custom/mrm332.cfg: Comment out objdump.
* Makefile.am: Remove obsolete custom/*.cfg.
PR 553/bsps
* custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a
comment.
* Makefile.am: Remove efi68k and efi332 references as they are no
longer in the tree.
