path: root/make/ChangeLog (follow)
* 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-291-0/+4
| | | | * custom/Cygwin-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* 2002-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-261-0/+6
| | | | | | * custom/FreeBSD-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR. * custom/HPUX9-posix.cfg: Ditto. * custom/Linux-posix.cfg: Ditto.
* 2002-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-021-0/+4
| | | | * custom/armulator.cfg: Remove reference to PowerPC arguments.
* 2002-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-131-0/+8
| | | | | | | | * Part of addressing PR281. * main.cfg: Added recognition of VARIANT=DEBUG on command line. * compilers/gcc-target-default.cfg: Removed remaining support for RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug as one of the LDFLAGS when the debug variant is specified.
* 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-121-0/+4
| | | | * custom/posix.cfg: Don't include host.cfg.
* 2002-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-091-0/+4
| | | | * custom/gen405.cfg: Corrected make-cxx-exe rule to use LINK.cc.
* 2002-08-07 Ivan Guzvinec <ivang@opencores.org>Joel Sherrill2002-08-071-0/+4
| | | | * orp.cfg: Bender BSP renamed to OpenRisc Reference Platform or ORP.
* 2002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-071-0/+4
| | | | * custom/vegaplus.cfg: Fix bogus and corrupted make-exe.
* 2002-08-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-061-0/+5
| | | | | * custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* 2002-08-06 Chris Ziomkowski <chris@asics.ws>Joel Sherrill2002-08-061-0/+5
| | | | | * custom/or32sim.cfg: New file added as part of merge from OpenCores repository.
* 2002-08-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-051-0/+8
| | | | | | | | * Per PR260 eliminate use of make-target-options. This impacted RTEMS allowing a distinction between the CPU32 and CPU32+ in the SuperCore and required that the m68k optimized memcpy be moved to libcpu. * custom/gen68360.cfg: Remove make-target-options.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+6
| | | | | * eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg, mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-011-0/+4
| | | | * custom/mvme136.cfg: Per PR260 removed make-target-options.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-311-0/+5
| | | | | * custom/vegaplus.cfg: Generate the Mapfile into $(ARCH) so it will disappear when make clean is performed.
* 2002-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-241-0/+5
| | | | | * custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg: Updated to use gcc 3.1 arguments.
* 2002-07-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-221-0/+4
| | | | * Templates/Makefile.leaf: Clarify the MANAGERS example.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-0/+4
| | | | * custom/p4650.cfg: Update arguments to gcc3.
* 2002-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-141-0/+5
| | | | | * custom/jmr3904.cfg, custom/p4650.cfg, custom/p4600.cfg: Switch to gcc 3.1 arguments.
* 2002-05-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-141-0/+10
| | | | | | | | | | * custom/dmv177.cfg: Use -mcpu=603e. * custom/ppcn_60x.cfg: Use -mcpu=603e. * custom/psim.cfg: Use -mcpu=603e. * custom/score603e.cfg: Use -mcpu=603e. * custom/ts_386ex.cfg: Remove obsolete comments. * custom/rxgen960.cfg: Remove obsolete comments. * custom/cvme961.cfg: Remove obsolete comments.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-091-0/+5
| | | | | * custom/jmr3904.cfg, custom/p4650.cfg: Add comments for gcc 3.1 compatable arguments.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-0/+28
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/eth_comm.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS. * custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS. * custom/mbx8xx.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS. Remove obsolete comments. * custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS. Remove obsolete comments. * custom/mpc8260ads.cfg: Remove make-target-options. Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS. Remove obsolete comments. * custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments.
* 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-041-0/+4
| | | | * custom/gen405.cfg: Remove -D__powerpc__.
* 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-031-0/+7
| | | | | | * custom/erc32nfp.cfg: Remove CPU_U32_FIX. * custom/erc32.cfg: Ditto. * custom/leon2.cfg: Ditto.
* 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-291-0/+6
| | | | | | * custom/erc32.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB. * custom/erc32nfp.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB. * custom/leon2.cfg: Remove NO_TABLE_MOVE.
* 2002-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+38
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/cvme961.cfg: Remove GCC272 support. * custom/dmv152.cfg: Remove GCC272 support. * custom/efi332.cfg: Remove GCC272 support. * custom/efi68k.cfg: Remove GCC272 support. * custom/eth_comm.cfg: Remove GCC272 support. * custom/gen405.cfg: Remove GCC272 support. * custom/gen68302.cfg: Remove GCC272 support. * custom/gen68340.cfg: Remove GCC272 support. * custom/gen68360.cfg: Remove GCC272 support. * custom/genmongoosev.cfg: Remove GCC272 support. * custom/helas403.cfg: Remove GCC272 support. * custom/i386ex.cfg: Remove GCC272 support. * custom/i960sim.cfg: Remove GCC272 support. * custom/idp.cfg: Remove GCC272 support. * custom/leon2.cfg: Remove GCC272 support. * custom/mbx8xx.cfg: Remove GCC272 support. * custom/mcf5206elite.cfg: Remove GCC272 support. * custom/mpc8260ads.cfg: Remove GCC272 support. * custom/mrm332.cfg: Remove GCC272 support. * custom/mvme136.cfg: Remove GCC272 support. * custom/mvme147.cfg: Remove GCC272 support. * custom/mvme167.cfg: Remove GCC272 support. * custom/ods68302.cfg: Remove GCC272 support. * custom/p4000.cfg: Remove GCC272 support. * custom/p4600.cfg: Remove GCC272 support. * custom/p4650.cfg: Remove GCC272 support. * custom/pc386.cfg: Remove GCC272 support. * custom/portsw.cfg: Remove GCC272 support. * custom/psim.cfg: Remove GCC272 support. * custom/rxgen960.cfg: Remove GCC272 support. * custom/score603e.cfg: Remove GCC272 support. * custom/sim68000.cfg: Remove GCC272 support. * custom/simhppa.cfg: Remove GCC272 support. * custom/simsh4.cfg: Remove GCC272 support. * custom/ts_386ex.cfg: Remove GCC272 support.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+7
| | | | | | | * Templates/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * compilers/Makefile.am: Remove AUTOMAKE_OPTIONS. * custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-0/+5
| | | | | * compilers/gcc-target-default.cfg: Add missing \. Reported by Ilya Alexeev <ilya@continuum.ru>.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+7
| | | | | | | * custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS. * custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272 support. * custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-0/+8
| | | | | | | | * custom/Cygwin-posix.cfg: Remove -DMALLOC_PROVIDED. * custom/FreeBSD-posix.cfg: Ditto. * custom/HPUX9-posix.cfg: Ditto. * custom/Linux-posix.cfg: Ditto. * custom/Solaris-posix.cfg: Ditto.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-0/+5
| | | | | * custom/erc32.cfg: Remove erc32nfp support, GCC272. * custom/erc32nfp.cfg: Merge in portions from erc32.cfg.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-181-0/+14
| | | | | | | | | | | | | | * custom/armulator.cfg: Remove make-target-options. * custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE (now in erc32/configure.ac). * custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE (now in leon2/configure.ac). Remove CONSOLE_USE_POLLED (Unused). * custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE, CD2401_USE_TERMIOS (now in mvme167/configure.ac). * custom/mvme162.cfg: Remove references to mvme162lx. Abandon gcc272. Remove make-target-options. * custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
* 2001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-071-0/+23
| | | | | | | | | | | | | | | | | | | | | | | * custom/bare.cfg: Remove make-target-options. * custom/c4xsim.cfg: Ditto. * custom/cvme961.cfg: Ditto. * custom/efi68k.cfg: Ditto. * custom/gen68302.cfg: Ditto. * custom/gen68340.cfg: Ditto. * custom/genmongoosev.cfg: Ditto. * custom/gensh4.cfg: Remove make-target-options, remove GCC272 make-exe, remove empty lines. * custom/h8sim.cfg: Remove make-target-options. * custom/mcf5206elite.cfg: Ditto. * custom/mrm332.cfg: Ditto. * custom/mvme147.cfg: Ditto. * custom/ods68302.cfg: Ditto. * custom/p4000.cfg: Ditto. * custom/p4600.cfg: Ditto. * custom/p4650.cfg: Ditto. * custom/pc386.cfg: Ditto. * custom/portsw.cfg: Ditto. * custom/simsh4.cfg: Ditto.
* 2001-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-281-1/+6
| | | | | | * custom/efi332.cfg: Remove make-target-options. * custom/idp.cfg: Ditto. * custom/jmr3904.cfg: Ditto.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-271-5/+1
| | | | * ChangeLog: Deleted bogus entry.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-271-0/+8
| | | | | | | | This was tracked as PR39. * include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger, startup/linkcmds, startup/rom: Eliminated required definition of macros in the custom file for the BSP to compile. The ROM and ROM address and size settings are now linker script items.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-271-0/+6
| | | | | | | This was tracked as PR39. * custom/ods68302.cfg: Eliminated required definition of macros in this file for the BSP to compile. The ROM and ROM address and size settings are now linker script items.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-271-0/+14
| | | | | | | | | | | | | * custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE.
* 2001-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-261-0/+5
| | | | | * custom/papyrus.cfg: Removed. * custom/Makefile.am, custom/helas403.cfg: Removed reference to above.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-211-0/+5
| | | | | * custom/mvme2307.cfg: Reflect changes to motorola_powerpc/configure.ac. * custom/mcp750.cfg: Ditto.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-211-0/+8
| | | | | | | | * custom/dmv177.cfg: Reflect changes to dmv177/configure.ac. * custom/ppcn_60x.cfg: Refect changes to ppcn_60x/configure.ac. * custom/psim.cfg: Refect changes to psim/configure.ac. * custom/score603e.cfg: Reflect changes to score603e/configure.ac, remove SCORE603E_GENERATION.
* 2001-11-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-201-0/+8
| | | | | | | * custom/eth_comm.cfg: Reflect changes to eth_comm/configure.ac. * custom/mbx8xx.cfg: Reflect changes to mbx8xx/configure.ac. * custom/mbx860_005b.cfg: Ditto. * custom/mpc8620ads.cfg: Reflect changes to mpc8620/configure.ac.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-151-0/+5
| | | | | * custom/gensh1.cfg: remove make-target-options. * custom/gensh2.cfg: remove make-target-options.
| | | | | * custom/dmv152: Remove USE_CONSOLE_A, Remove USE_CONSOLE_B, remove make-target-options, remove BSP_CPPFLAGS.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-151-0/+4
| | | | * custom/simhppa.cfg: Remove SIMHPPA_FAST_IDLE, make-target-options.
* 2001-11-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-141-0/+7
| | | | | | | * custom/eth_comm.cfg, custom/mbx860_005b.cfg, custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mvme2307.cfg: These are new exception processing model BSPs and thus do not need to define PPC_USE_SPRG.
| | | | * ChangeLog: Added missing lines about simcpu32.cfg and sim68000.cfg.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-141-0/+4
| | | | * custom/ts_386ex.cfg: Remove make-target-options.
* 2001-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-141-0/+6
| | | | | | * custom/shsim.cfg: Remove HZ, BSP_CPPFLAGS, make-target-options. * custom/mvme2307.cfg: Fix PPC_USE_SPRG in make-target-options, re-adopt mcp750.cfg's make-exe.
* 2001-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-131-0/+6
| | | | | | * custom/helas403.cfg, custom/gen405.cfg: Removed dependency on the --srec-len argument to objcopy only supported in binutils 2.11 or newer.
* 2001-11-08 Dennis Ehlin (ECS) <Dennis.Ehlin@ecs.ericsson.se>Joel Sherrill2001-11-091-0/+10
| | | | | | | | | | This modification is part of the submitted modifications necessary to support the IBM PPC405 family. This submission was reviewed by Thomas Doerfler <Thomas.Doerfler@imd-systems.de> who ensured it did not negatively impact the ppc403 BSPs. The submission and tracking process was captured as PR50. * custom/gen405.cfg: New file. * custom/helas403.cfg: Modified to generate Srecords.
