* custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS.
* custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272
support.
* custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* custom/Cygwin-posix.cfg: Remove -DMALLOC_PROVIDED.
* custom/FreeBSD-posix.cfg: Ditto.
* custom/HPUX9-posix.cfg: Ditto.
* custom/Linux-posix.cfg: Ditto.
* custom/Solaris-posix.cfg: Ditto.
* custom/erc32.cfg: Remove erc32nfp support, GCC272.
* custom/erc32nfp.cfg: Merge in portions from erc32.cfg.
* custom/armulator.cfg: Remove make-target-options.
* custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE
(now in erc32/configure.ac).
* custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS,
SIMSPARC_FAST_IDLE (now in leon2/configure.ac).
Remove CONSOLE_USE_POLLED (Unused).
* custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE,
CD2401_USE_TERMIOS (now in mvme167/configure.ac).
* custom/mvme162.cfg: Remove references to mvme162lx.
Abandon gcc272. Remove make-target-options.
* custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
* custom/efi332.cfg: Remove make-target-options.
* custom/idp.cfg: Ditto.
* custom/jmr3904.cfg: Ditto.
* ChangeLog: Deleted bogus entry.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
* custom/ods68302.cfg: Eliminated required definition of macros in this
file for the BSP to compile. The ROM and ROM address and size settings
* custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG;
* custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG;
* custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/papyrus.cfg: Removed.
* custom/Makefile.am, custom/helas403.cfg: Removed reference to above.
* custom/mvme2307.cfg: Reflect changes to motorola_powerpc/configure.ac.
* custom/mcp750.cfg: Ditto.
* custom/dmv177.cfg: Reflect changes to dmv177/configure.ac.
* custom/ppcn_60x.cfg: Refect changes to ppcn_60x/configure.ac.
* custom/psim.cfg: Refect changes to psim/configure.ac.
* custom/score603e.cfg: Reflect changes to score603e/configure.ac,
remove SCORE603E_GENERATION.
* custom/eth_comm.cfg: Reflect changes to eth_comm/configure.ac.
* custom/mbx8xx.cfg: Reflect changes to mbx8xx/configure.ac.
* custom/mbx860_005b.cfg: Ditto.
* custom/mpc8620ads.cfg: Reflect changes to mpc8620/configure.ac.
* custom/gensh1.cfg: remove make-target-options.
* custom/gensh2.cfg: remove make-target-options.
* custom/dmv152: Remove USE_CONSOLE_A, Remove USE_CONSOLE_B,
remove make-target-options, remove BSP_CPPFLAGS.
* custom/simhppa.cfg: Remove SIMHPPA_FAST_IDLE, make-target-options.
* custom/eth_comm.cfg, custom/mbx860_005b.cfg, custom/mbx8xx.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mvme2307.cfg:
These are new exception processing model BSPs and thus do not
need to define PPC_USE_SPRG.
* ChangeLog: Added missing lines about simcpu32.cfg and sim68000.cfg.
* custom/ts_386ex.cfg: Remove make-target-options.
* custom/shsim.cfg: Remove HZ, BSP_CPPFLAGS, make-target-options.
* custom/mvme2307.cfg: Fix PPC_USE_SPRG in make-target-options,
re-adopt mcp750.cfg's make-exe.
* custom/helas403.cfg, custom/gen405.cfg: Removed dependency on
the --srec-len argument to objcopy only supported in binutils 2.11
or newer.
process was captured as PR50.
* custom/gen405.cfg: New file.
* custom/helas403.cfg: Modified to generate Srecords.
* custom/sim68000.cfg: Generate symbols off executable not Srecords.
* custom/mcf5206elite.cfg: New file.
* custom/mpc8260ads.cfg: New file.
* custom/gensh4.cfg: Remove START_HW_INIT.
* custom/simsh4.cfg: Remove START_HW_INIT, RTEMS_CPU_MODEL=sh7750.
* custom/gensh4.cfg: Remove HZ.
* custom/simsh4.cfg: Remove HZ.
* custom/gensh4.cfg, custom/simsh4.cfg: New files in support
of Hitachi SH4 BSPs of the same name. Reviewed and some
cleanup by Joel Sherrill <joel@OARcorp.com>.
* custom/gensh2.cfg: Remove -lstdc++ from make-exe.
* custom/mbx8xx.cfg, custom/mvme167.cfg: Rewrote use of strip command
to avoid using the apparently broken or deprecated -o argument.
* custom/ods68302.cfg: Add custom make-cxx-exe rule to account
for MC68302_BASE.
* custom/bare.cfg: Define dummy make-cxx-exe.
* ChangeLog: Formatting cleanup.
custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options.
custom/FreeBSD-posix.cfg: Remove make-target-options.
custom/HPUX9-posix.cfg: Dito.
custom/Linux-posix.cfg: Dito.
custom/Solaris-posix.cfg: Dito.
custom/arm_bare_bsp.cfg: Dito.
custom/armulator.cfg: Dito.
custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/i386ex.cfg: Remove make-target-options.
custom/i960sim.cfg: Remove make-target-options.
custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/rxgen960.cfg: Remove make-target-options, cleanup comments.
custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/vegaplus.cfg: Remove make-target-options.
* custom/mrm332.cfg: Switched $(SED) to sed.
* custom/mrm332.cfg: New file.
* custom/dmv177.cfg: Remove CONSOLE_USE_INTERRUPTS,
CONSOLE_USE_POLLED, HAS_RTC.
* custom/gensh1.cfg: Remove HZ, BSP_CPPFLAGS.
* custom/gensh2.cfg: Dito.
* leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V.
* compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags,
remove unused flags, remove -ansi from CPP.
* custom/eth_comm.cfg: Remove CPU_DEFINES.
* custom/sim68000.cfg: Remove CPU_DEFINES.
* compilers/gcc-no_bsp.cfg: Remove -ansi -fasm.
* compilers/gcc-default.cfg: Dito.
* compilers/gcc-portsw.cfg: Remove -Hansi.
* custom/posix.cfg: Remove inclusion of target.cfg.
* custom/simhppa.cfg: Remove -ansi -fasm.
* custom/eth_comm.cfg: Switch the eth_comm BSP to use the
"new exception processing model."
* custom/default.cfg: Switch to using exec_prefix to reflect new
organization of install point from Ralf Corsepius.
* custom/mbx860_005b.cfg: This switches the MBX8xx BSP to the
use the "new exception processing model."
* custom/genmongossev.cfg: New file.
* custom/pc386dx.cfg: New bsp.
* custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg,
custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg
* main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP).
* host.cfg.in: Remove RM, make-script.
* ChangeLog: Remove bogus 2001-01-22 entry.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and
simsh7045.
