* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 1 | -19/+0 |
| | | | | | | | | | | | | | | | | | | * configure.in: New, Cygnus/GNU style configuration. * Makefile.am: Add macros/, reflect new configure.in, ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros * automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION. * automake/lib.am: Remove RTEMS_CANONICALIZATION. * macros/tool-prefix.m4: Remove. * macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS. * macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting RTEMS_ROOT. * macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode- * macros/multilib.m4: Various minor fixes. * macros/project-root.m4: Remove setting PROJECT_TOPdir, PROJECT_ROOT, RTEMS_ROOT. * macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS; Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT. | ||||
* | 2000-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-18 | 1 | -0/+47 |
* macros: New directory. * macros/bsp-alias.m4: new file. * macros/canonical-host.m4: new file. * macros/canonical-target-name.m4: new file. * macros/canonicalize-tools.m4: new file. * macros/check-bsp-cache.m4: new file. * macros/check-bsps.m4: new file. * macros/check-cpu.m4: new file. * macros/rtems-debug.m4: new file. * macros/check-cxx.m4: new file. * macros/check-itron.m4: new file. * macros/check-multiprocessing.m4: new file. * macros/check-networking.m4: new file. * macros/check-newlib.m4: new file. * macros/check-posix.m4: new file. * macros/check-rdbg.m4: new file. * macros/enable-bare.m4: new file. * macros/enable-cxx.m4: new file. * macros/enable-gcc28.m4: new file. * macros/enable-inlines.m4: new file. * macros/enable-itron.m4: new file. * macros/enable-libcdir.m4: new file. * macros/enable-multiprocessing.m4: new file. * macros/enable-networking.m4: new file. * macros/enable-posix.m4: new file. * macros/enable-rdbg.m4: new file. * macros/enable-rtemsbsp.m4: new file. * macros/enable-tests.m4: new file. * macros/gcc-pipe.m4: new file. * macros/gcc-specs.m4: new file. * macros/i386-gas-code16.m4: new file. * macros/path-ksh.m4: new file. * macros/path-perl.m4: new file. * macros/prog-cc.m4: new file. * macros/prog-cxx.m4: new file. * macros/project-root.m4: new file. * macros/rtems-top.m4: new file. * macros/sysv-ipc.m4: new file. * macros/target.m4: new file. * macros/rtems-test-no-pause.m4: new file. * macros/multilib.m4: new file. * macros/tool-paths.m4: new file. * macros/tool-prefix.m4: new file. |
