* configure.in: New, Cygnus/GNU style configuration.
* Makefile.am: Add macros/, reflect new configure.in,
ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros
* automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION.
* automake/lib.am: Remove RTEMS_CANONICALIZATION.
* macros/tool-prefix.m4: Remove.
* macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS.
* macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting
RTEMS_ROOT.
* macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode-
* macros/multilib.m4: Various minor fixes.
* macros/project-root.m4: Remove setting PROJECT_TOPdir,
PROJECT_ROOT, RTEMS_ROOT.
* macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS;
Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* macros: New directory.
* macros/bsp-alias.m4: new file.
* macros/canonical-host.m4: new file.
* macros/canonical-target-name.m4: new file.
* macros/canonicalize-tools.m4: new file.
* macros/check-bsp-cache.m4: new file.
* macros/check-bsps.m4: new file.
* macros/check-cpu.m4: new file.
* macros/rtems-debug.m4: new file.
* macros/check-cxx.m4: new file.
* macros/check-itron.m4: new file.
* macros/check-multiprocessing.m4: new file.
* macros/check-networking.m4: new file.
* macros/check-newlib.m4: new file.
* macros/check-posix.m4: new file.
* macros/check-rdbg.m4: new file.
* macros/enable-bare.m4: new file.
* macros/enable-cxx.m4: new file.
* macros/enable-gcc28.m4: new file.
* macros/enable-inlines.m4: new file.
* macros/enable-itron.m4: new file.
* macros/enable-libcdir.m4: new file.
* macros/enable-multiprocessing.m4: new file.
* macros/enable-networking.m4: new file.
* macros/enable-posix.m4: new file.
* macros/enable-rdbg.m4: new file.
* macros/enable-rtemsbsp.m4: new file.
* macros/enable-tests.m4: new file.
* macros/gcc-pipe.m4: new file.
* macros/gcc-specs.m4: new file.
* macros/i386-gas-code16.m4: new file.
* macros/path-ksh.m4: new file.
* macros/path-perl.m4: new file.
* macros/prog-cc.m4: new file.
* macros/prog-cxx.m4: new file.
* macros/project-root.m4: new file.
* macros/rtems-top.m4: new file.
* macros/sysv-ipc.m4: new file.
* macros/target.m4: new file.
* macros/rtems-test-no-pause.m4: new file.
* macros/multilib.m4: new file.
* macros/tool-paths.m4: new file.
* macros/tool-prefix.m4: new file.
that makes --disable-multilib the default.
that is part of the multilib/gnu-canonicalization movement:
* New m4-macro: aclocal/multilib.am
* Suppress multiprocessing if --enable-multilib is given to
configure
For now this patch only suppresses multiprocessing if
--enable-multilib is given to configure and should not have any
other side-effects, ie. it works around a minor issue which prevents
introduction of multilibs in general.
The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build
real multilibs, but can not be applied before other multilib related
issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs,
Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing
the installation point/tooldir support, etc.).
