path: root/macros/check-posix.m4 (follow)
* 2000-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-181-0/+37
* macros: New directory. * macros/bsp-alias.m4: new file. * macros/canonical-host.m4: new file. * macros/canonical-target-name.m4: new file. * macros/canonicalize-tools.m4: new file. * macros/check-bsp-cache.m4: new file. * macros/check-bsps.m4: new file. * macros/check-cpu.m4: new file. * macros/rtems-debug.m4: new file. * macros/check-cxx.m4: new file. * macros/check-itron.m4: new file. * macros/check-multiprocessing.m4: new file. * macros/check-networking.m4: new file. * macros/check-newlib.m4: new file. * macros/check-posix.m4: new file. * macros/check-rdbg.m4: new file. * macros/enable-bare.m4: new file. * macros/enable-cxx.m4: new file. * macros/enable-gcc28.m4: new file. * macros/enable-inlines.m4: new file. * macros/enable-itron.m4: new file. * macros/enable-libcdir.m4: new file. * macros/enable-multiprocessing.m4: new file. * macros/enable-networking.m4: new file. * macros/enable-posix.m4: new file. * macros/enable-rdbg.m4: new file. * macros/enable-rtemsbsp.m4: new file. * macros/enable-tests.m4: new file. * macros/gcc-pipe.m4: new file. * macros/gcc-specs.m4: new file. * macros/i386-gas-code16.m4: new file. * macros/path-ksh.m4: new file. * macros/path-perl.m4: new file. * macros/prog-cc.m4: new file. * macros/prog-cxx.m4: new file. * macros/project-root.m4: new file. * macros/rtems-top.m4: new file. * macros/sysv-ipc.m4: new file. * macros/target.m4: new file. * macros/rtems-test-no-pause.m4: new file. * macros/multilib.m4: new file. * macros/tool-paths.m4: new file. * macros/tool-prefix.m4: new file.
