* .gitignore: Remove config.guess, config.sub, missing, install-sh.
* config.guess, config.sub, missing, install-sh: New.
* bootstrap: remove/add automake added files.
* .cvsignore: reflect changes to bootstrap.
enclose.
be resolved.
