PR 365/rtems
* supplements/arm/cpumodel.t: Removed unused ARM_HAS_CLZ macro
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi,
FAQ/concepts.texi, FAQ/debug.texi, FAQ/endoftime.texi,
FAQ/freesw.texi, FAQ/hwdebugaids.texi, FAQ/projects.texi,
FAQ/tools.texi: Remove (Generated files).
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
* user/region.t: Add documentation on region_resize_segment.
* bsp_howto/rtc.t: Rewritten to account for removal of dmv177.
* networking/decdriver.t: Make PCI initialize function part of the
unified PCI API as pci_initialize().
PR 706/doc
* user/task.t: Remove not that changes explanation.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* intro.texi, status.texi: i960 obsoleted.
* supplements/Makefile.am: i960 obsoleted.
* supplements/i960/.cvsignore, supplements/i960/CVME961_TIMES,
supplements/i960/ChangeLog, supplements/i960/Makefile.am,
supplements/i960/bsp.t, supplements/i960/callconv.t,
supplements/i960/cpumodel.t, supplements/i960/cputable.t,
supplements/i960/fatalerr.t, supplements/i960/i960.texi,
supplements/i960/intr_NOTIMES.t, supplements/i960/memmodel.t,
supplements/i960/preface.texi, supplements/i960/timeCVME961.t: Removed.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
* FAQ/build45.t: Misc. corrections.
* rgdb_specs/layers.txt, rgdb_specs/process.txt,
rgdb_specs/seqbreak.txt, rgdb_specs/seqdetach.txt,
rgdb_specs/seqinit.txt: New.
* rgdb_specs/comm.t, rgdb_specs/conclusion.t,
rgdb_specs/gdbinternals.t: Use @image for
ASCII figures (Reflect changes above).
* common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS,
RTEMSSNAPSHOTSSUBSCRIBE.
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/tools.texi,
FAQ/version.texi, FAQ/stamp-vti: New.
FAQ/version.texi: New.
* networking/networkflow.txt, networking/PCIreg.txt,
networking/recvbd.txt: New.
* networking/decdriver.t, networking/networktasks.t: Use @image for
PR rtems/652
* user/signal.t: Return RTEMS_INVALID_NUMBER when sending an empty
signal set.
PR 631/rtems
* user/msg.t: Document the return status from message_queue_create when
unable to allocate message buffer memory.
PR 627/doc
* user/task.t: Behavior documented for an rtems_task_create with
stacksize < minimum was not the implemented behavior.
PR 618/rtems
* user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t,
user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL
checks.
* started/buildc.t: Use tar xjf for bzip'ed files.
* started/buildrt.t: Use tar xjf to unzip rtems.
PR 576/doc
* FAQ/FAQ.texi, FAQ/Makefile.am: Remove embedded information as it was
out of date and frequently duplicated information available from
other public sources like the CrossGCC Wiki.
* FAQ/embeddedinfo.t: Removed.
* develenv/Makefile.am: Put *.texi into the builddir.
* started/tversions.texi: Remove (Bogus).
* ChangeLog: Merge-in supplements/ChangeLog.
* supplements/ChangeLog: Remove.
* ChangeLog: Merge-in ada_user/ChangeLog.
* ChangeLog: Merge-in started_ada/ChangeLog.
* ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* ChangeLog: Merge-in bsp_howto/ChangeLog.
* ChangeLog: Merge-in porting/ChangeLog.
* ChangeLog: Merge-in rgdb_specs/ChangeLog.
* ChangeLog: Merge-in rtems_gdb/ChangeLog.
* bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog,
rtems_gdb/ChangeLog: Remove.
* ChangeLog: Merge-in filesystem/ChangeLog.
* ChangeLog: Merge-in networking/ChangeLog.
* filesystem/ChangeLog, networking/ChangeLog: Remove.
* ChangeLog: Merge-in posix_users/ChangeLog.
* ChangeLog: Merge-in posix1003.1/ChangeLog.
* ChangeLog: Merge-in itron3.0/ChangeLog.
* posix_users/ChangeLog, posix1003.1/ChangeLog, itron3.0/ChangeLog:
Remove.
* ChangeLog: Merge-in FAQ/ChangeLog.
* FAQ/ChangeLog: Remove.
* ChangeLog: Merge-in user/ChangeLog.
* user/ChangeLog: Remove.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html,
gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html,
started/binaries.t, started/buildc.t, started/buildrt.t,
started/intro.t, started/require.t, started/sample.t,
started/tversions.texi.in: Incorporating changes from pre-4.6.0
review.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* ChangeLog: Merge-in started/ChangeLog.
* started/ChangeLog: Remove.
