* user/preface.texi: Remove UNIX and update port list.
* HELP.html, bsp_howto/support.t, relnotes/status.texi,
started_ada/buildada.t: Remove references to posix/Unix port.
* user/conf.t, user/userext.t: Eliminate use of deprecated
rtems_extension.
* cpu_supplement/arm.t: Update.
* cpu_supplement/preface.texi: Typo.
* cpu_supplement/general.t: Expanded abbreviation.
* user/conf.t: Change stack allocator signature.
* bsp_howto/framebuffer.t: documented the improvements made to
read/write
* bsp_howto/framebuffer.t: Updated the frame buffer documentation.
* user/conf.t: Add configuration of posix message queue file
descriptors as separate entity. Also add documentation on posix
configuration elements not previously covered.
* bsp_howto/framebuffer.t: added documentation
* bsp_howto/.cvsignore, bsp_howto/Makefile.am,
bsp_howto/bsp_howto.texi: Add Frame Buffer Device Driver shell.
* bsp_howto/framebuffer.t: New file.
* user/conf.t: Add CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER.
* user/region.t: Fix typos where semaphore referenced instead of region
or segment.
* user/preface.texi: Correct list of supported CPU architectures.
* user/conf.t: Change work_space_size to uintptr_t since it cannot be
negative.
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Add shell for Atmel AVR chapter.
* cpu_supplement/avr.t: New file.
* shell/confinit.t: New argument sequence for rtems_shell_init().
* user/.cvsignore: Add Object ID PDF files.
* posix_users/preface.texi, shell/preface.texi: Add stock
acknowledgement paragraphs that are required when excerpting and
reusing text from POSIX standards per the agreement at
* common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New files.
PR 1387/doc
* user/intr.t: Add Interrupt Manager services to list of services
callable from ISR.
* shell/rtems.t: Add halt command.
* porting/idlethread.t: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* bsp_howto/console.t: Clarify interrupt transmit process.
* user/concepts.t: Typo.
* index.html.in: Remove manuals that are dead.
* user/cpuuse.t: Reflect change in CPU Usage report format.
* user/init.t: Eliminate pointers to API configuration tables in the
main configuration table. Reference the main configuration table and
the API configuration tables directly using the confdefs.h version
rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* user/conf.t, user/region.t: Change sizes of heap/region and allocated
objects in heap to intptr_t so they can be larger than a single
allocatable object (e.g. size_t).
* user/region.t: Malloc Family is not implemented in termios of Region
Manager after 4.7. Correct documentation.
* bsp_howto/console.t: Remove size constraints on image. Fix a
sentence.
Joel Sherrrill <joel.sherrill@oarcorp.com>
* bsp_howto/Makefile.am, bsp_howto/console.t: Sebastian improved
documentation for termios device drivers.
* bsp_howto/TERMIOSFlow.eps, bsp_howto/TERMIOSFlow.png: New files.
Joel added Termios Flow figure from RTEMS Open Class material.
cpu_supplement/cpu_supplement.texi: Add Lattice Mico32 support.
* cpu_supplement/lm32.t: New file.
* ada_user/Makefile.am: Fix typo.
* ada_user/Makefile.am, user/Makefile.am, user/concepts.t: Add 16 bit
object Id format information.
* user/ObjectId-16Bits.eps, user/ObjectId-16Bits.png: New files.
* user/datatypes.t: Add C99 uint types.
PR 1340/cpukit
* user/chains.t: Add rtems_chain_initialize to public chain API.
PR 1339/Ada
* user/io.t: Re-add IO Manager to Ada binding.
PR 1336/cpukit
* user/chains.t, user/dirstat.texi: Add rtems_chain_prepend_unprotected
and rtems_chain_append_unprotected.
* user/concepts.t: Use 32 bit version centered.
* ada_user/Makefile.am: Make Ada manual build again after adding
figure.
PR 1334/doc
* user/Makefile.am, user/concepts.t, user/init.t, user/overview.t,
user/part.t, user/task.t: Correct typos and correctly document 4
parts of 32-bit object id.
* user/ObjectId-32Bits.eps, user/ObjectId-32Bits.png: New files.
* user/conf.t: Fix typo.
* user/region.t: Change size_t to ssize_t.
* shell/preface.texi: Bump version to 4.9.99.0
* bsp_howto/timer.t: Eliminate uses of old benchmark timer names.
* setup.def, started/buildc.t: Update.
* bsp_howto/BSPInitFlowchart-49.png: Update figure.
* user/conf.t: Add CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM and
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* shell/rtems.t, user/conf.t, user/stackchk.t: Rename STACK_CHECKER_ON
to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* user/conf.t: Add support for optionally having a unified work area.
In other words, the RTEMS Workspace and C Program Heap are the same
pool of memory.
* bsp_howto/Developer-User-Timeline.png: Correct figure.
* user/chains.t, user/conf.t, user/object.t, user/userext.t:
More "bool" cleanup.
