* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 2 | -0/+5 |
| | | | | * arm.texi: Merge from branch. | ||||
| | | | | * c4x.texi: Merge from branch. | ||||
| | | | | * hppa1_1.texi: Merge from branch. | ||||
| | | | | * i386.texi: Merge from branch. | ||||
| | | | | * i960.texi: Merge from branch. | ||||
| | | | | * m68k.texi: Merge from branch. | ||||
| | | | | * mips.texi: Merge from branch. | ||||
| | | | | * mips64orion.texi: Merge from branch. | ||||
| | | | | * powerpc.texi: Merge from branch. | ||||
| | | | | * sh.texi: Merge from branch. | ||||
| | | | | * sparc.texi: Merge from branch. | ||||
| | | | | * template.texi: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 3 | -11/+12 |
| | | | | * c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -0/+42 |
| | | | | | PR 466/doc * io.t: Added sync(). | ||||
* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 3 | -4/+8 |
| | | | | * intro.t, nextstep.t: Fix mailing list addresses. | ||||
* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 4 | -147/+153 |
| | | | | | | * buildada.t, gdb.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | ||||
* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 6 | -171/+177 |
| | | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 2 | -4/+34 |
| | | | | | | PR 469/doc * buildc.t: Clarifying text on patch file to account for various ways they could be compressed or not. | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 2 | -6/+10 |
| | | | | * tversions.texi: Correcting version information. | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 3 | -2/+9 |
| | | | | | * cpumodels.t, sourcecode.t: Reconcile differences between CVS trunk and 4.6 branch. | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 4 | -17/+22 |
| | | | | | * adaintr.t, ata.t, target.t: Reconcile differences between CVS trunk and 4.6 branch. | ||||
* | 2003-08-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-13 | 2 | -5/+9 |
| | | | | * ide-ctrl.t: Merger from 4.6-branch. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 4 | -2/+10 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-08-07 | 3 | -13/+11 |
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-08-07 | 3 | -1/+15 |
* | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-22 | 2 | -3/+3 |
| | | | | * fatal.t: Reflect c/src/exec having moved to cpukit. | ||||
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-05-22 | 22 | -12/+56 |
* | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-22 | 1 | -8/+8 |
| | | | | * daemon.t: Reflect c/src/exec having moved to cpukit. | ||||
* | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-22 | 1 | -6/+6 |
| | | | | * example.t: Reflect c/src/exec having moved to cpukit. | ||||
* | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-22 | 1 | -1/+1 |
| | | | | * build45.t: Fix typo (config.long). | ||||
* | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-22 | 1 | -0/+4 |
* | 2003-05-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-21 | 2 | -0/+9 |
| | | | | * texi2www: Add support for @ifnottex. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-04-29 | 2 | -1/+5 |
* | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-17 | 2 | -27/+13 |
| | | | | * index.html.in: Development Environment Guide should be updated now. | ||||
* | 2003-04-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-16 | 4 | -163/+6 |
| | | | | | * Makefile.am, develenv.texi: Remove unused file. * compile.texi: Removed. | ||||
* | 2003-04-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-16 | 2 | -2/+6 |
| | | | | * Makefile.am: Fix next/previous section names. | ||||
* | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-11 | 2 | -1/+5 |
* | 2003-03-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-03-24 | 4 | -380/+489 |
| | | | | * direct.t, sample.t, utils.t: Significantly updated. | ||||
* | 2003-02-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-28 | 2 | -0/+7 |
| | | | | * .cvsignore: Add newly generated .texi files. | ||||
* | 2003-02-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-18 | 4 | -3/+8 |
| | | | | | | * Makefile.am, configure.ac: Remove src2html references. * index.html.in: Update to reflect partial update of Development Environment Guide. | ||||
* | 2003-02-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-18 | 6 | -414/+288 |
| | | | | | | | | * Makefile.am, develenv.texi: Relect generating .texi from .t's. * direct.t, sample.t, utils.t: New files. * direct.texi, sample.texi, utils.texi: Removed. Now generated from corresponding .t files which are in the process of being updated. This commit is a anspshot of the update effort. | ||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 2 | -10/+4 |
| | | | | * index.html.in: Removed a29k reference. | ||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 2 | -11/+8 |
| | | | | * cpumodels.t: Removed a29k reference and updated. | ||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 2 | -3/+11 |
| | | | | * preface.texi: Remove a29k references and update. | ||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 3 | -7/+18 |
| | | | | * basic.t, entry: Remove A29k references and update. | ||||
* | 2003-02-14 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2003-02-14 | 5 | -111/+29 |
| | | | | | | PR 347/rtems * rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline assembly so it correctly generates on newer gcc's. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-02-14 | 50 | -3628/+11 |
* | 2003-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-11 | 2 | -9/+14 |
| | | | | | | | * interrupts.t: Rework logic that decides when to call _Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru> determined that _ISR_Signals_to_thread_executing was not being honored and/or cleared properly. |
