* | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1999-07-08 | 1 | -12/+351 |
* | From Fei Ling <fling@cs.uah.edu>. | Joel Sherrill | 1999-07-06 | 1 | -19/+524 |
* | Added a lot of information on confdefs.t | Joel Sherrill | 1999-07-03 | 1 | -16/+367 |
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 2 | -4/+68 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 27 | -35/+10 |
* | Changed System Database routines to implemented. | Joel Sherrill | 1999-07-03 | 1 | -10/+10 |
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 |
* | Corrected formatting so argument was in code font. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 |
* | Filled in. | Joel Sherrill | 1999-07-01 | 1 | -10/+30 |
* | Cleaned up and much neater. | Joel Sherrill | 1999-07-01 | 1 | -19/+33 |
* | Corrected and fleshed out. | Joel Sherrill | 1999-06-18 | 1 | -43/+2 |
* | Directives -> services. | Joel Sherrill | 1999-06-15 | 1 | -4/+4 |
* | Some stuff added. | Joel Sherrill | 1999-06-15 | 1 | -38/+131 |
* | Significantly enhanced. At least the per routine pages for this chapter | Joel Sherrill | 1999-06-15 | 1 | -59/+349 |
| | | | | are now filled in. | ||||
* | Added information on pathname evaluation. | Joel Sherrill | 1999-06-11 | 1 | -1/+14 |
* | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 1999-06-04 | 13 | -249/+361 |
| | | | | class. | ||||
* | Added much of the text required to turn this into a real chapter. | Joel Sherrill | 1999-06-04 | 1 | -52/+195 |
* | New file. | Joel Sherrill | 1999-05-26 | 1 | -0/+4 |
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 13 | -253/+257 |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 11 | -83/+166 |
| | | | | The style in the output is not right but it is a good starting point. | ||||
* | Basic prototypes are now included. | Joel Sherrill | 1999-05-26 | 1 | -1/+6 |
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 12 | -180/+184 |
| | | | | the descriptive titles. | ||||
* | Changed word "directive" to "system call." | Joel Sherrill | 1999-05-26 | 1 | -1/+1 |
* | Added error codes to all service calls | Joel Sherrill | 1999-05-26 | 1 | -14/+190 |
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 12 | -168/+0 |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 12 | -252/+84 |
* | Enhanced. | Joel Sherrill | 1999-05-26 | 1 | -63/+156 |
* | Initial revision | Joel Sherrill | 1999-05-20 | 16 | -0/+4561 |
* | Fixed typo. | Joel Sherrill | 1999-05-14 | 1 | -1/+1 |
* | Added tool hints. | Joel Sherrill | 1999-05-14 | 3 | -1/+12 |
* | New file. | Joel Sherrill | 1999-05-14 | 1 | -0/+47 |
* | Fixed Makefile to avoid copying the file to a new name. | Joel Sherrill | 1999-04-23 | 1 | -1/+0 |
* | Changed date. | Joel Sherrill | 1999-04-23 | 7 | -28/+27 |
* | Switched to full doc set. | Joel Sherrill | 1999-04-23 | 1 | -1/+30 |
* | Updated to reflect inclusion of IRQ test in ada examples. | Joel Sherrill | 1999-04-20 | 1 | -3/+7 |
* | Added FAQ to the documentation set. | Joel Sherrill | 1999-04-19 | 3 | -12/+9 |
* | Added debugging hints to the FAQ. | Joel Sherrill | 1999-04-19 | 3 | -8/+10 |
* | New file. | Joel Sherrill | 1999-04-19 | 1 | -0/+43 |
* | Updated to include first set of questions. | Joel Sherrill | 1999-04-19 | 2 | -1/+124 |
* | First attempt to build. | Joel Sherrill | 1999-04-19 | 3 | -5/+20 |
* | New file. | Joel Sherrill | 1999-04-19 | 2 | -0/+176 |
* | New file based on notes from Jiri Gaisler <jgais@ws.estec.esa.nl>. | Joel Sherrill | 1999-04-19 | 1 | -0/+77 |
* | Added info based on i960HA support. | Joel Sherrill | 1999-04-19 | 1 | -10/+8 |
* | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1999-04-19 | 1 | -12/+36 |
* | Comments from Eric Norum taken into account. | Joel Sherrill | 1999-04-19 | 1 | -2/+14 |
* | First cut at addition of information on macros that need to be defined. | Joel Sherrill | 1999-04-19 | 1 | -0/+29 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-04-19 | 1 | -1/+1 |
| | | | | | | | | | | | | | | This one is an enhancement to acpolish. It replaces some Makefile variables by others variable in Makefile.ins (tries to use unique name for some variables). It therefore eases parsing Makefile.ins for further automatic Makefile.in conversions in future. To apply: cd <rtems-source-tree> sh <path-to>/rtems-rc-19990407-8.sh ./autogen | ||||
* | Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>. | Joel Sherrill | 1999-04-08 | 3 | -6/+14 |
* | First attempt to build. | Joel Sherrill | 1999-04-08 | 1 | -264/+305 |
