* | smp: Add Deterministic Priority SMP Scheduler | Sebastian Huber | 2013-08-20 | 1 | -3/+37 |
* | documentation: Directives allowed from an ISR | Sebastian Huber | 2013-08-14 | 1 | -12/+36 |
| | | | | Update list. | ||||
* | doc/user/conf.t: More clean ups | Shubham Somani | 2013-07-29 | 1 | -100/+7 |
* | conf.t: Fix minor typos. | Joel Sherrill | 2013-07-24 | 1 | -2/+2 |
* | doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go configuration | Cynthia Rempel | 2013-07-24 | 1 | -1/+93 |
* | doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go Configuration | Cynthia Rempel | 2013-07-22 | 1 | -4/+97 |
* | doc/shell/Makefile.am: Fix dependency | Joel Sherrill | 2013-07-22 | 1 | -1/+1 |
* | Make the default values easier for the configuration GUI to parse | Cynthia Rempel | 2013-06-12 | 1 | -91/+94 |
* | termios: Notify driver about inactive transmit | Sebastian Huber | 2013-06-12 | 1 | -0/+6 |
| | | | | | | Returning this state in the return value leads to race conditions on SMP. The inactive state notification must be inside the critical section. | ||||
* | rtems: Add interrupt locks | Sebastian Huber | 2013-06-12 | 1 | -0/+170 |
| | | | | | Interrupt locks are low-level lock to protect critical sections accessed by threads and interrupt service routines. | ||||
* | shell: Add df command | Andrei Mozzhuhin | 2013-05-16 | 1 | -0/+78 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 1 | -0/+25 |
* | doc: Config documentation changes throughout | Sebastian Huber | 2013-04-10 | 1 | -200/+166 |
* | doc: Add bdbuf configuration options | Sebastian Huber | 2013-04-10 | 1 | -0/+376 |
* | user/conf.t: Address User Feedback from Stephen Tether | Joel Sherrill | 2013-04-09 | 1 | -68/+78 |
| | | | | | | | | Stephen Tether <tether@slac.stanford.edu> posted to the users list: http://www.rtems.org/pipermail/rtems-users/2013-April/011273.html I tried to make the requested changes. | ||||
* | user/overview.t: Fix broken cross reference | Joel Sherrill | 2013-04-09 | 1 | -2/+1 |
* | doc/user/conf.t: Rewrite to emphasize confdefs.h and add detail | Joel Sherrill | 2013-04-09 | 2 | -1874/+3782 |
| | | | | | | | This patch includes a heavy rewrite of the chapter to have a more structured approach to this chapter. It also changes the sectioning to have the Data Structures be a section to themselves as a peer in the outline with each logical area of macros in confdefs.h. | ||||
* | doc/texi2html_init.in: Correct typo | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | doc/texi2any_init.in: Correct link to Library index.html | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | doc/main.am: Tweak TEXI2ANY_ARGS to make HTML menus look better | Joel Sherrill | 2013-03-11 | 1 | -0/+1 |
* | doc/texi2html_init.in: Update copyright on html output | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | doc/project.am: texi2html invocation had file name twice | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | doc/main.am: TEXI2HTML_ARGS macro clean up | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 5 | -2555/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | doc: Build html into subdirectory (fix make clean) | Joel Sherrill | 2013-02-26 | 2 | -7/+11 |
| | | | | | | | Building with a document specific prefix will require coding in both texi2any and texi2html. It is easier to build into a directory (e.g. $(PROJECT)/). This also fixes "make clean" which was broken. | ||||
* | user/preface.texi: Add NEC V850 and SPARC V9 | Joel Sherrill | 2013-02-26 | 1 | -2/+2 |
* | user/overview.t: Add missing chapters to overview | Joel Sherrill | 2013-02-26 | 1 | -32/+65 |
* | doc master include files: Do not include top node on printed output | Joel Sherrill | 2013-02-26 | 12 | -1/+25 |
| | | | | | | In PDF, DVI, and PostScript files, the contents of the @top node were being printed. These are intended only for info and html output formats. | ||||
* | doc/project.am: Make texi2html and texi2any stanzas share | Joel Sherrill | 2013-02-26 | 1 | -17/+5 |
* | doc: Update copyright year in common files | Joel Sherrill | 2013-02-26 | 2 | -3/+3 |
* | doc: Update version.texi and stamp-vti files | Joel Sherrill | 2013-02-26 | 26 | -52/+52 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html for instructions on how to do this. | ||||
* | doc/user Object Id Figures: Correct rotation and border | Joel Sherrill | 2013-02-26 | 4 | -42536/+8462 |
| | | | | | | | | | The 16 bit Object Id image was incorrectly rotated in the manual. Both the 16 and 32 Object Id bit images had thin borders on the table and the bottom line was not visible in the PDF. I tinkered with the original drawings to add a bit more space around the tables and manually converted the PNG to EPS using Gimp to ensure a controlled and high quality conversion. | ||||
* | doc/user/semaphore_attributes.eps: Correct rotation | Joel Sherrill | 2013-02-26 | 1 | -106459/+3742 |
* | doc/c_user: Fix Lines that were too long | Joel Sherrill | 2013-02-26 | 2 | -9/+9 |
* | doc: Use More Readable Names for Generated Nodes | Joel Sherrill | 2013-02-26 | 2 | -3/+7 |
| | | | | | | | | Per a discussion with the GNU Texinfo maintainer Patrice Dumas, change to generating HTML files per a standard for stable URL names and easier cross manual referencing. http://lists.gnu.org/archive/html/help-texinfo/2013-02/msg00002.html | ||||
* | doc: Support texi2any and texi2html | Joel Sherrill | 2013-02-26 | 5 | -19/+80 |
| | | | | | | | | | | | This was tested with texi2html-1.82-5.1.el6.noarch and a locally built texinfo 5.0. These are completely different implementations and require different invocations. The Makefile dependencies appear to work but are likely not perfect at this point. The key point is that the autoconf probe detects which to use and responds accordingly with preference given to texi2any. | ||||
* | doc: Update to build info format with texinfo 4.13 and 5.0 | Joel Sherrill | 2013-02-26 | 16 | -224/+231 |
| | | | | | Texinfo 5.0 is a complete reimplementation and has stricter interpretations of the texinfo language. | ||||
* | Add missing @item. | Ralf Corsépius | 2013-02-26 | 1 | -1/+1 |
* | Add missing @items. | Ralf Corsépius | 2013-02-26 | 1 | -3/+3 |
* | Fix typo. | Ralf Corsépius | 2013-02-25 | 2 | -2/+2 |
* | make: Remove -qrtems_debug flag usage | Sebastian Huber | 2013-02-13 | 1 | -2/+1 |
* | sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS | Sebastian Huber | 2013-02-12 | 1 | -0/+63 |
* | sapi: Add rtems_fatal_source_description() | Sebastian Huber | 2013-01-07 | 1 | -0/+27 |
* | score: Add rtems_chain_node_count_unprotected() | Sebastian Huber | 2012-12-21 | 1 | -0/+28 |
* | score: rtems_initialize_start_multitasking() | Sebastian Huber | 2012-12-07 | 3 | -44/+44 |
| | | | | | | | | | Do not return from rtems_initialize_start_multitasking() and call rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and a fatal code with the exit status. Remove all bsp_cleanup() functions. The boot_card() is now a no return function. | ||||
* | score: Add CPU_Exception_frame | Sebastian Huber | 2012-11-27 | 1 | -0/+27 |
| | | | | | | | | | | | | | | | | | | | | | Add CPU port type CPU_Exception_frame and function _CPU_Exception_frame_print(). The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh, sparc64, and v850 use an empty default implementation of _CPU_Exception_frame_print(). Add rtems_exception_frame and rtems_exception_frame_print(). Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal() with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc, and sparc for unexpected exceptions. Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the BSP_PRINT_EXCEPTION_CONTEXT define used in the default bsp_fatal_extension(). Add test sptests/spfatal26. | ||||
* | score: Change _Internal_error_Occurred() | Sebastian Huber | 2012-11-22 | 1 | -4/+4 |
| | | | | | | | Call the fatal handlers of the user extensions before the update of _Internal_errors_What_happened. This reduces the requirements on the execution context further. Now a valid read-write data is only required after the call to the fatal handlers. | ||||
* | rtems: Add rtems_clock_get_uptime_seconds() | Sebastian Huber | 2012-11-21 | 1 | -0/+31 |
* | rtems: Add rtems_clock_get_uptime_timeval() | Sebastian Huber | 2012-11-21 | 1 | -0/+35 |
* | score: Add rtems_fatal() | Sebastian Huber | 2012-11-15 | 1 | -0/+31 |
