* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 2 | -6/+6 |
| | | | | | | | | | | | | pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed. | ||||
* | Switched back to jpg for networkflow because netscape 4.71 for linux | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | did not display the png properly. | ||||
* | Regenerated. | Joel Sherrill | 1999-10-07 | 3 | -0/+0 |
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 10 | -10/+10 |
| | | | | viewer can have section headings. | ||||
* | Now includes figures. | Joel Sherrill | 1999-10-07 | 1 | -12/+5 |
* | Updated. | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | COpy the images to the html install point. | Joel Sherrill | 1999-10-07 | 1 | -2/+6 |
| | | | | Added stanza to generate pdf files from eps ones. | ||||
* | Copy figures from user guide directory so they can be included in the | Joel Sherrill | 1999-10-07 | 1 | -7/+15 |
| | | | | | | generated document. User $(PROJECT) instead of ada_user | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 3 | -3/+3 |
| | | | | pdf version of figures. | ||||
* | Added Porting Guide to documentation set. | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
* | Enabled building pdf. | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
* | Changed install point to /usr1/rtems/tmp. | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
* | Renamed and generated pdf. | Joel Sherrill | 1999-10-07 | 3 | -1/+1 |
* | New file -- converted from networkflow.eps | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | New files. | Joel Sherrill | 1999-10-07 | 2 | -0/+0 |
* | Added rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 1 | -0/+42 |
* | Cleaned up use of $(PROJECT) instead of hard-coding c_user. | Joel Sherrill | 1999-10-07 | 1 | -3/+5 |
| | | | | Added rule to convert rtemspie.eps to .pdf. | ||||
* | Added Porting Guide. | Joel Sherrill | 1999-10-06 | 1 | -0/+2 |
* | Added portability write up from paper from France in 1997 as starting | Joel Sherrill | 1999-10-06 | 2 | -5/+133 |
| | | | | point for portability discussion. | ||||
* | Added copyrights and CVS Ids. | Joel Sherrill | 1999-10-06 | 10 | -0/+80 |
* | Now builds with full links. | Joel Sherrill | 1999-10-06 | 2 | -20/+20 |
* | Now builds successfully. | Joel Sherrill | 1999-10-06 | 6 | -26/+24 |
* | Renamed preface.t to preface.texi since it has no automatically | Joel Sherrill | 1999-10-06 | 1 | -2/+12 |
| | | | | generated information. Also added CVS Id and Copyright notice. | ||||
* | New manual. First version to CVS. Just starting to see if it builds. | Joel Sherrill | 1999-10-06 | 13 | -0/+1846 |
* | Added convert stanza to generate pdf version of figures from eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+3 |
* | Disabled building PDF by default. | Joel Sherrill | 1999-10-06 | 1 | -1/+1 |
* | Enabled images. They appear to work ok for PostScript but not as well | Joel Sherrill | 1999-10-06 | 5 | -24/+13845 |
| | | | | for PDF -- at least according to ghostview. | ||||
* | Enabled images. Works pretty well for PostScript. Ghostview does | Joel Sherrill | 1999-10-06 | 10 | -41/+38 |
| | | | | not like the generated pdf but who knows what that really means. | ||||
* | Renamed seq_init.jpg to seqinit.jpg. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seq_init.eps to seqinit.eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seq_detach.jpg to seqdetach.jpg. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seq_detach.eps to seqdetach.eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seq_break.jpg to seqbreak.jpg. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seq_break.eps to seqbreak.eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seg_init to seq_init. | Joel Sherrill | 1999-10-06 | 4 | -7/+19 |
* | Renamed networking figure to networkflow and added PCIreg.pdf. | Joel Sherrill | 1999-10-06 | 4 | -0/+1343 |
* | Turned this image back off because it works for PS but not PDF. | Joel Sherrill | 1999-10-06 | 1 | -2/+2 |
* | Changing names to avoid the name of the document. | Joel Sherrill | 1999-10-06 | 4 | -1347/+6 |
* | Enabled PCI register figure and renamed them to avoid _ in name to avoid | Joel Sherrill | 1999-10-06 | 3 | -12/+4 |
| | | | | tool problems. | ||||
* | Added multiple formats of the image so we can use the @image command. | Joel Sherrill | 1999-10-06 | 3 | -0/+2164 |
* | Corrected a typo. | Joel Sherrill | 1999-10-06 | 2 | -21/+23 |
* | Removed Makefile.in generated from Makefile.am | Joel Sherrill | 1999-10-04 | 1 | -213/+0 |
* | Regenerated. | Joel Sherrill | 1999-10-04 | 1 | -5/+6 |
* | Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' | Joel Sherrill | 1999-10-01 | 1 | -3/+3 |
| | | | | <ccj@acm.org> suggestion. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 76 | -182/+283 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1999-10-01 | 1 | -0/+10 |
* | Added return 0 to pollWrite and InterruptWrite examples. Chris | Joel Sherrill | 1999-10-01 | 1 | -7/+4 |
| | | | | Johns <ccj@acm.org> suggested this. | ||||
* | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1999-09-07 | 1 | -1/+1 |
| | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | ||||
* | Added BSP chapter to FAQ. | Joel Sherrill | 1999-09-02 | 3 | -1/+43 |
* | Link fixed for CPU Supplements. Reported by Jose Vasconcellos | Joel Sherrill | 1999-08-30 | 1 | -6/+6 |
| | | | | <josev@utstar.com>. |
