1999-11-16 | Added task variable services. | Joel Sherrill | 2 | -1/+131 | |
1999-11-16 | Added categorized list of constants in confdefs.h. | Joel Sherrill | 1 | -0/+126 | |
1999-11-15 | Added paragraph describing SUSP. | Joel Sherrill | 1 | -0/+9 | |
1999-11-11 | Added information about the NTP servier field and included a copy | Joel Sherrill | 2 | -3/+69 | |
of the C definition of the configuration structure. | |||||
1999-11-10 | Updated to include more documentation from CS595. | Joel Sherrill | 5 | -22/+51 | |
1999-11-10 | Better formatting. | Joel Sherrill | 1 | -47/+75 | |
1999-11-09 | Converted from DOS to UNIX filemode. | Joel Sherrill | 3 | -1630/+1630 | |
1999-11-09 | Corrected lines that were too long. | Joel Sherrill | 2 | -8/+8 | |
1999-11-09 | Fixed formatting error. | Joel Sherrill | 1 | -1/+0 | |
1999-11-09 | Corrected manual name. | Joel Sherrill | 1 | -8/+8 | |
1999-11-09 | Integrated into main tree. | Joel Sherrill | 1 | -26/+15 | |
1999-11-09 | Update from Jennifer. | Joel Sherrill | 1 | -30/+54 | |
1999-11-09 | Added more status information. | Joel Sherrill | 1 | -0/+80 | |
1999-11-09 | Added Status chapter. | Joel Sherrill | 4 | -4/+1059 | |
1999-11-09 | Corrected flaws which prevented formatting with texi2pdf since it | Joel Sherrill | 1 | -1/+1 | |
is stricter on node names. | |||||
1999-10-28 | Changed version timestamp. | Joel Sherrill | 2 | -4/+4 | |
1999-10-28 | Added information to fstat handler. | Joel Sherrill | 1 | -14/+21 | |
1999-10-28 | Reformatted. | Joel Sherrill | 1 | -359/+395 | |
1999-10-28 | Cleaned up spacing on function prototypes. | Joel Sherrill | 1 | -56/+56 | |
1999-10-28 | Added lstat(). | Joel Sherrill | 1 | -3/+57 | |
1999-10-28 | Added shell of chapters on implementation of miniIMFS and TFTP client | Joel Sherrill | 5 | -6/+50 | |
filesystems. Moved system call chapter to before filesystem implementation requirements. | |||||
1999-10-26 | Added information on the evaluate and evaluate for make routines. | Jennifer Averett | 2 | -21/+115 | |
Added details on how generic code starts the pathevaluation process. | |||||
1999-10-26 | Corrected spacing problem. | Jennifer Averett | 1 | -1/+1 | |
1999-10-25 | Fixed line too long problems. | Joel Sherrill | 3 | -14/+22 | |
1999-10-25 | Updated copyright year and corrected image path. | Joel Sherrill | 1 | -4/+4 | |
1999-10-25 | Updated copyright year. | Joel Sherrill | 2 | -2/+3 | |
1999-10-25 | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 5 | -33/+56 | |
1999-10-25 | Added descriptions of the mount table entry elements. | Jennifer Averett | 1 | -0/+97 | |
1999-10-25 | Modified url references to be dynamic links. | Charles Phillips | 1 | -1/+1 | |
1999-10-25 | Added definition of DDD. Modified url references to be | Charles Phillips | 1 | -3/+3 | |
dynamic links. | |||||
1999-10-25 | + Filled in information on IMFS_freenod and IMFS_freenodinfo | Jennifer Averett | 1 | -13/+58 | |
+ Filled in information on the imfs_fsunmount and imfs_unmount methods. | |||||
1999-10-25 | + Cleaned up lines that were too long. | Jennifer Averett | 1 | -129/+19 | |
+ Removed subheading File - This is not valid for the callback descriptions. + Filled in information on freenod | |||||
1999-10-25 | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 9 | -50/+54 | |
1999-10-25 | Added information on how the directory is stored for future referance | Jennifer Averett | 1 | -2/+3 | |
during a mount. | |||||
1999-10-25 | Formatting improvements. | Joel Sherrill | 3 | -12/+80 | |
1999-10-25 | Enabled Ada95 interrupt support chapter and reformatted a | Joel Sherrill | 6 | -35/+48 | |
bunch of stuff to avoid line wrappings. | |||||
1999-10-25 | Made html links browsable. | Charles Phillips | 1 | -4/+3 | |
1999-10-25 | Made urls browsable links. | Charles Phillips | 1 | -3/+3 | |
1999-10-25 | Made html urls browsable links. | Charles Phillips | 1 | -1/+1 | |
1999-10-25 | Made html urls browable links. Updated the reference to the | Charles Phillips | 1 | -6/+48 | |
U.S. Army Missile Command to show the merger with the Aviation Command | |||||
1999-10-25 | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1 | -11/+10 | |
backwards. | |||||
1999-10-13 | Reorganized a lot per Jennifer's suggestions. | Joel Sherrill | 4 | -120/+120 | |
1999-10-13 | Updated copyright date. | Joel Sherrill | 6 | -5/+7 | |
1999-10-13 | More manuals and a little reorganization. | Joel Sherrill | 1 | -5/+25 | |
1999-10-13 | First commit of miscellaneous tools and documentation for a procedure | Joel Sherrill | 8 | -0/+343 | |
that can be used to produce an online bookshelf of the GNU tools. | |||||
1999-10-12 | Made many changes to turn the outline into something more like a manual | Joel Sherrill | 9 | -448/+1854 | |
and less like a collection of notes. | |||||
1999-10-12 | Dispersed. | Joel Sherrill | 1 | -35/+0 | |
1999-10-12 | Dispersed. | Joel Sherrill | 1 | -324/+0 | |
1999-10-12 | Dispersed. | Joel Sherrill | 1 | -339/+0 | |
1999-10-12 | New file. | Joel Sherrill | 1 | -0/+34 | |
