1999-05-20 | Initial revision | Joel Sherrill | 16 | -0/+4561 | |
1999-05-14 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
1999-05-14 | Added tool hints. | Joel Sherrill | 3 | -1/+12 | |
1999-05-14 | New file. | Joel Sherrill | 1 | -0/+47 | |
1999-04-23 | Fixed Makefile to avoid copying the file to a new name. | Joel Sherrill | 1 | -1/+0 | |
1999-04-23 | Changed date. | Joel Sherrill | 7 | -28/+27 | |
1999-04-23 | Switched to full doc set. | Joel Sherrill | 1 | -1/+30 | |
1999-04-20 | Updated to reflect inclusion of IRQ test in ada examples. | Joel Sherrill | 1 | -3/+7 | |
1999-04-19 | Added FAQ to the documentation set. | Joel Sherrill | 3 | -12/+9 | |
1999-04-19 | Added debugging hints to the FAQ. | Joel Sherrill | 3 | -8/+10 | |
1999-04-19 | New file. | Joel Sherrill | 1 | -0/+43 | |
1999-04-19 | Updated to include first set of questions. | Joel Sherrill | 2 | -1/+124 | |
1999-04-19 | First attempt to build. | Joel Sherrill | 3 | -5/+20 | |
1999-04-19 | New file. | Joel Sherrill | 2 | -0/+176 | |
1999-04-19 | New file based on notes from Jiri Gaisler <jgais@ws.estec.esa.nl>. | Joel Sherrill | 1 | -0/+77 | |
1999-04-19 | Added info based on i960HA support. | Joel Sherrill | 1 | -10/+8 | |
1999-04-19 | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1 | -12/+36 | |
1999-04-19 | Comments from Eric Norum taken into account. | Joel Sherrill | 1 | -2/+14 | |
1999-04-19 | First cut at addition of information on macros that need to be defined. | Joel Sherrill | 1 | -0/+29 | |
1999-04-19 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -1/+1 | |
This one is an enhancement to acpolish. It replaces some Makefile variables by others variable in Makefile.ins (tries to use unique name for some variables). It therefore eases parsing Makefile.ins for further automatic Makefile.in conversions in future. To apply: cd <rtems-source-tree> sh <path-to>/rtems-rc-19990407-8.sh ./autogen | |||||
1999-04-08 | Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>. | Joel Sherrill | 3 | -6/+14 | |
1999-04-08 | First attempt to build. | Joel Sherrill | 1 | -264/+305 | |
1999-04-08 | New files. | Joel Sherrill | 4 | -0/+500 | |
1999-04-08 | New file | Joel Sherrill | 1 | -0/+264 | |
1999-04-06 | changed version to 19990406 | Joel Sherrill | 1 | -0/+5 | |
1999-04-06 | oNew file. | Joel Sherrill | 1 | -0/+0 | |
1999-04-06 | Sanitized. | Joel Sherrill | 1 | -3/+0 | |
1999-04-06 | Removed. | Joel Sherrill | 6 | -2860/+0 | |
1999-04-06 | Updated. | Joel Sherrill | 1 | -0/+2 | |
1999-04-02 | Changed dates. | Joel Sherrill | 3 | -8/+8 | |
1999-04-02 | Added RTEMS Remote Debugger Server Specifications links. | Joel Sherrill | 1 | -0/+2 | |
1999-04-02 | Fixed target name. | Joel Sherrill | 1 | -1/+1 | |
1999-04-02 | Added Network Servers Chapter including Jake Janovetz's ftpd server. | Joel Sherrill | 3 | -2/+7 | |
1999-04-02 | Now at least a version of the figures shows up in the html although | Joel Sherrill | 9 | -7/+150 | |
there are no captions. | |||||
1999-04-02 | Can now produce html, info, and PostScript without errors. Links | Joel Sherrill | 7 | -61/+67 | |
between chapters are correct. | |||||
1999-04-02 | Accidentally added the .tex file not the .texi root document. | Joel Sherrill | 3 | -1234/+115 | |
Also the Makefile had "@include" lines in it. | |||||
1999-04-02 | New files. This manual was ritten by Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 16 | -0/+12427 | |
and Emmanuel Raguet <raguet@crf.canon.fr>. It was submitted in LaTeX and converted to Texinfo by Joel. At this point, the figures are largely ignored except to put in an example block to show they are missing. The Makefile should be just enough to produce output with no links between chapters. | |||||
1999-04-01 | New file. Text from Jake Janovetz. | Joel Sherrill | 2 | -1/+122 | |
1999-03-23 | Patch from Eric Norum to account for new routine that improved | Joel Sherrill | 1 | -9/+22 | |
parsing of interface names. | |||||
1999-03-19 | Towards automake XI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -0/+13 | |
This patch is the most scary of all proposals I've been mailing to you this week until now. It consists of 3 parts: 1. a patch 2. a perl script (acpolish) 3. a shell script wrapper to invoke the perl-script. The perl-script reads in each Makefile.in and modifies them ("polishes/beautifies" them :-). These modifications are not easy to describe: Basically, it hard-codes some automake Makefile-variables and rules into RTEMS autoconf-Makefile.ins (Note: autoconf vs. automake!!) and converts some settings/variables to configure scripts' requirements (Yes, plural). E.g. it adds the automake standard variables $top_builddir and $subdir, adds dependency rules for automatic re-generation of Makefiles from Makefile.in, adds support variables for relative paths to multiple configure scripts etc. The patch is a one-line patch to enable the support of the new features added by acpolish. The shell script is a wrapper which pokes around inside of the source tree for Makefile.ins and invokes acpolish on all autoconf-Makefile.ins. acpolish is designed to be able to run several times on the same Makefile.in and may once become a more general tool to convert RTEMS Makefile.in to automake. Therefore, I'd like to keep it inside of source tree. (e.g. as contrib/acpolish or c/update-tools/acpolish). However, it doesn't make sense to export it outside of RTEMS. To apply this: cd <source-tree> patch -p1 -E < <path-to-patch>/rtems-rc-19990318-1.diff tar xzvf <path-to>/rtems-rc-polish.tar.gz ./rtems-polish.sh ./autogen Note: The path contrib/acpolish is hard-coded into rtems-polish.sh, if you decide to put it in an alternative place, please modify rtems-polish.sh to reflect this change. Later: cvs rm make/rtems.cfg (It isn't used anymore) cvs add contrib cvs add contrib/acpolish cvs commit I've tested this intensively, but naturally I can't exclude bugs. Ralf. PS.: Most probably, this is the last "Towards automake" patch. The next one probably will be a real automake patch. | |||||
1999-03-02 | This file is linked in | Joel Sherrill | 1 | -284/+0 | |
1999-02-10 | Added thank you. | Joel Sherrill | 1 | -2/+2 | |
1999-02-10 | Added POSIX timers. | Joel Sherrill | 1 | -5/+5 | |
1999-02-10 | Corrected title | Joel Sherrill | 1 | -1/+1 | |
1999-02-10 | Added gdb_rtems | Joel Sherrill | 3 | -2/+5 | |
1999-02-10 | Changed versions. | Joel Sherrill | 3 | -11/+11 | |
1999-02-10 | Now generates HTML, PostScript, and info correctly. | Joel Sherrill | 7 | -63/+42 | |
1999-02-10 | Base file. | Joel Sherrill | 1 | -0/+129 | |
1999-02-10 | Base version. | Joel Sherrill | 7 | -0/+374 | |
1999-02-09 | Added maximum_timers field to configuration table. | Joel Sherrill | 1 | -1/+1 | |
