* | Fixed back so it would build. | Joel Sherrill | 1998-09-10 | 1 | -0/+2 |
* | Added references. | Joel Sherrill | 1998-09-10 | 1 | -0/+33 |
* | Added section on format of the configuration space file. | Joel Sherrill | 1998-09-09 | 1 | -0/+2 |
* | Added gettimeofday(). | Joel Sherrill | 1998-09-09 | 1 | -0/+26 |
* | Removed chapter names from automatically generated node names. | Joel Sherrill | 1998-09-08 | 2 | -3/+5 |
* | Fixed include file path. | Joel Sherrill | 1998-09-08 | 1 | -1/+1 |
* | Added text to describe System log, Non-system logs,facility, and severity. | Jennifer Averett | 1998-09-02 | 1 | -5/+22 |
* | Updated the descriptions section for the log_create and log_sys_create | Wade A Smith | 1998-08-31 | 1 | -5/+62 |
| | | | | functions.d | ||||
* | Reviewed log_read(). | Joel Sherrill | 1998-08-28 | 1 | -21/+41 |
* | Reviewed and corrected log_write(), log_write_any(), and log_write_entry(). | Joel Sherrill | 1998-08-28 | 1 | -84/+202 |
* | Added log_write_any and part of log_copy. | Joel Sherrill | 1998-08-28 | 1 | -3/+92 |
| | | | | Reviewed log_close. | ||||
* | Added author credit. | Joel Sherrill | 1998-08-28 | 1 | -0/+5 |
* | Added CVS Ids. | Joel Sherrill | 1998-08-28 | 9 | -0/+72 |
* | Added top level file and cleaned up chapter names | Joel Sherrill | 1998-08-28 | 7 | -6/+127 |
* | Undid renaming. | Joel Sherrill | 1998-08-28 | 1 | -0/+0 |
* | Renamed intro to preface. | Joel Sherrill | 1998-08-28 | 1 | -0/+0 |
* | Base files | Joel Sherrill | 1998-08-28 | 10 | -25/+1151 |
* | New file | Joel Sherrill | 1998-08-28 | 1 | -0/+94 |
* | Updated log_seek() per review. | Joel Sherrill | 1998-08-27 | 1 | -14/+10 |
* | Modified log_open() to reflect review. | Joel Sherrill | 1998-08-27 | 1 | -26/+29 |
* | Corrected descriptions of log facility set manipulation routines as | Joel Sherrill | 1998-08-27 | 1 | -130/+59 |
| | | | | part of the review. | ||||
* | Corrected log_severity_before as part of reviewing the code. | Joel Sherrill | 1998-08-27 | 1 | -7/+16 |
* | Incorporated the "#include <dump.h>" statement in file. | Wade A Smith | 1998-08-26 | 1 | -0/+2 |
* | Incorporated the "#include cfg.h" statement in document | Wade A Smith | 1998-08-26 | 1 | -0/+24 |
* | Incorporated the "#include <admin.h>" statement in file | Wade A Smith | 1998-08-26 | 1 | -0/+2 |
* | Corrected mispelled words. | Wade A Smith | 1998-08-26 | 1 | -2/+30 |
* | Added some background and operations subsections. | Joel Sherrill | 1998-08-25 | 3 | -0/+20 |
* | Fixed spelling mistakes. | Joel Sherrill | 1998-08-25 | 2 | -41/+41 |
* | Fixed spelling mistake. | Joel Sherrill | 1998-08-25 | 1 | -1/+1 |
* | Cleaned up formatting. | Joel Sherrill | 1998-08-25 | 4 | -789/+906 |
| | | | | | | Added notes on background and operations sections. Added NOTE to indicate the feature flag defined. | ||||
* | Commit for review | Joel Sherrill | 1998-08-25 | 4 | -77/+77 |
* | Documented the log_create and log_sys_create routines | Wade A Smith | 1998-08-25 | 1 | -0/+76 |
* | Posix users manual now makes multiple info files. | Joel Sherrill | 1998-08-24 | 1 | -2/+2 |
* | Patch from Eric Norum | Joel Sherrill | 1998-08-21 | 1 | -10/+9 |
* | Update from Eric Norum. | Joel Sherrill | 1998-08-21 | 1 | -4/+23 |
* | Changed version. | Joel Sherrill | 1998-08-21 | 1 | -2/+2 |
* | Added Networking and Obsoleted KA9Q manual. | Joel Sherrill | 1998-08-21 | 1 | -1/+3 |
* | Added networking to public documents. | Joel Sherrill | 1998-08-21 | 1 | -1/+1 |
* | Changed date/version. | Joel Sherrill | 1998-08-21 | 1 | -1/+1 |
* | Made the description of timeing generation more accurate. | Joel Sherrill | 1998-08-20 | 2 | -8/+42 |
* | Changed wording to read better for PSIM. | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | New times. | Joel Sherrill | 1998-08-20 | 2 | -168/+169 |
* | Changed distribution level for this document. | Joel Sherrill | 1998-08-20 | 1 | -1/+1 |
* | Switched from generating tables based on CPU model to BSP. | Joel Sherrill | 1998-08-20 | 1 | -14/+14 |
* | Changed version. | Joel Sherrill | 1998-08-20 | 1 | -5/+5 |
* | PowerPC Supplement now part of support documentation. | Joel Sherrill | 1998-08-20 | 1 | -2/+2 |
* | rtems_support.html added. | Joel Sherrill | 1998-08-20 | 1 | -0/+2 |
* | New file | Joel Sherrill | 1998-08-20 | 1 | -0/+72 |
* | rtems_full.html sed'ed to get right version number. | Joel Sherrill | 1998-08-20 | 1 | -1/+2 |
* | PowerPC now part of customer support version. | Joel Sherrill | 1998-08-20 | 1 | -1/+0 |
