path: root/doc (follow)
* Remove refs to Makefile*.Ralf Corsepius2004-03-091-2/+0
* Unused.Ralf Corsepius2004-03-092-4/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-054-63/+10
| | | | | | | | PR 576/doc * FAQ/FAQ.texi, FAQ/Makefile.am: Remove embedded information as it was out of date and frequently duplicated information available from other public sources like the CrossGCC Wiki. * FAQ/embeddedinfo.t: Removed.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-172-3/+7
| | | | * develenv/Makefile.am: Put *.texi into the builddir.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-142-76/+4
| | | | * started/tversions.texi: Remove (Bogus).
* Cleanup.Ralf Corsepius2004-02-132-4/+0
* Reformat.Ralf Corsepius2004-02-051-311/+153
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-052-75/+41
| | | | | * ChangeLog: Merge-in supplements/ChangeLog. * supplements/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-053-139/+48
| | | | | | * ChangeLog: Merge-in ada_user/ChangeLog. * ChangeLog: Merge-in started_ada/ChangeLog. * ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-055-320/+122
| | | | | | | | | * ChangeLog: Merge-in bsp_howto/ChangeLog. * ChangeLog: Merge-in porting/ChangeLog. * ChangeLog: Merge-in rgdb_specs/ChangeLog. * ChangeLog: Merge-in rtems_gdb/ChangeLog. * bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog, rtems_gdb/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-053-141/+55
| | | | | | * ChangeLog: Merge-in filesystem/ChangeLog. * ChangeLog: Merge-in networking/ChangeLog. * filesystem/ChangeLog, networking/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-054-212/+79
| | | | | | | | * ChangeLog: Merge-in posix_users/ChangeLog. * ChangeLog: Merge-in posix1003.1/ChangeLog. * ChangeLog: Merge-in itron3.0/ChangeLog. * posix_users/ChangeLog, posix1003.1/ChangeLog, itron3.0/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-052-91/+35
| | | | | * ChangeLog: Merge-in FAQ/ChangeLog. * FAQ/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-052-153/+96
| | | | | * ChangeLog: Merge-in user/ChangeLog. * user/ChangeLog: Remove.
* 2004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-0417-59/+78
| | | | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-014-1/+9
| | | | | | * configure.ac: Add RTEMSRPMGROUP. * common/rtems.texi.in: Add RTEMSRPMGROUP. * started/binaries.t: Add RTEMSRPMGROUP.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-012-159/+5
| | | | | * ChangeLog: Merge-in started/ChangeLog. * started/ChangeLog: Remove.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-013-35/+39
| | | | * binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-013-1/+10
| | | | | | * configure.ac: Add RTEMS_ENABLE_RPMPREFIX. Add RTEMSRPMPREFIX. * common/rtems.texi.in: Add RTEMSRPMPREFIX.
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-232-93/+56
| | | | | * ChangeLog: Reformat. Merge-in develenv/ChangeLog. * develenv/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-232-89/+39
* 2004-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-202-1/+6
| | | | | PR 555/doc * sample.t: Fix RTEMS_MAKEFILE_PATH reference.
* 2004-01-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-172-5/+12
| | | | | | * Makefile.am: Remove AUTOMAKE_FILES. Add ../scripts/setup.def ../COPYING to EXTRA_DIST. Add rtems.html.in to EXTRA_DIST.
* Fix broken ChangeLog entry.Ralf Corsepius2004-01-172-2/+2
* 2004-01-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-172-0/+6
| | | | * Makefile.am: Add direct.t sample.t utils.t to EXTRA_DIST.
* 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-172-4/+8
| | | | * Makefile.am: Add ata.t, ide_ctrl.t to EXTRA_DIST.
* 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-172-0/+5
| | | | * Makefile.am: Add tversions.texi.in to EXTRA_DIST.
* 2004-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-093-6/+131
| | | | | | | PR 464/doc * clock.t, signal.t: Add documentation for usleep() and ualarm(). Also fixed a couple of calls which have the wrong .h files per the OpenGroup site documentation.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-1/+5
| | | | | * Makefile.am: mips64orion port removed as mips port more completely covers the MIPS family.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-074-69/+6
| | | | | | * configure.ac, index.html.in: mips64orion port removed as mips port more completely covers the MIPS family. * rtems_support.html.in: Removed.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-3/+5
| | | | | * buildada.t: mips64orion port removed as mips port more completely covers the MIPS family.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-0715-1383/+9
| | | | | | | | | * mips64orion/.cvsignore, mips64orion/BSP_TIMES, mips64orion/ChangeLog, mips64orion/Makefile.am, mips64orion/bsp.t, mips64orion/callconv.t, mips64orion/cpumodel.t, mips64orion/cputable.t, mips64orion/fatalerr.t, mips64orion/intr_NOTIMES.t, mips64orion/memmodel.t, mips64orion/mips64orion.texi, mips64orion/preface.texi, mips64orion/timeBSP.t: Removed.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-1264-33/+128
| | | | * Makefile.am: Cosmetics.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-124-4/+12
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-1160-68/+201
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2656-0/+195
| | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-262-1/+5
| | | | | * project.am: Remove $(PROJECT).info* from CLEANFILES (Doesn't work with automake-1.7f/1.8 anymore).
* 2003-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-252-10/+20
| | | | | PR 528/rtems_misc * task.t: Fix Ada binding for task variable calls.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-8/+11
| | | | * Makefile.am: Add missing '\'. Reformat.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-233-23/+5
| | | | | * system.h: Remove USE_INLINES. * chain.c: Remove USE_INLINES.
* 2003-11-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-212-2/+9
| | | | | PR 521/doc * sem.t: Default attributes were wrong for semaphores.
* 2003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-223-16/+12
| | | | | | | PR 513/doc * Makefile.am, index.html.in: Rename Getting Started to be non-language specific and remove link to Ada Getting Started. Also install missing graphic.
* 2003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-222-4/+9
| | | | | PR 513/doc * started.texi: Rename to be non-language specific.
* 2003-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-029-53/+249
| | | | | | | * Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t, sample.t, started.texi: General improvements and merge enough Ada information to justify dropping the Ada specific manual. There is likely still Ada specific information to merge though.
* 2003-10-02 Chris Caudle <chris@chriscaudle.org>Joel Sherrill2003-10-022-18/+39
| | | | | * nextstep.t: RTEMS applications can now use main() so correct the discussion of this.
* 2003-10-02 Gene Smith <gene.smith@siemens.com>Joel Sherrill2003-10-023-7/+56
| | | | | * networkapp.t, preface.texi: Improve documentation for SO_RCVWAKEUP and SO_SNDWAKEUP and update the references in the preface.
* 2003-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-292-1/+4
| | | | * preface.texi: Eliminate references to HPPA.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-2622-11/+55
| | | | * cpumodel.t: Obsoleting HP PA-RISC port and removing all references.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-262-5/+4
| | | | * status.texi: Obsoleting HP PA-RISC port and removing all references.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-262-1/+4
| | | | * cpumodels.t: Obsoleting HP PA-RISC port and removing all references.
