2000-01-04 | Fixed typos. | Joel Sherrill | 2 | -11/+12 | |
2000-01-04 | Updated dates and miscellaneous. | Joel Sherrill | 9 | -18/+27 | |
2000-01-04 | Added timer manager. | Joel Sherrill | 1 | -0/+5 | |
2000-01-04 | Improved clean stanza. | Joel Sherrill | 1 | -1/+1 | |
2000-01-03 | Added new URL. | Joel Sherrill | 1 | -0/+3 | |
1999-11-29 | Clarified. | Joel Sherrill | 1 | -0/+2 | |
1999-11-29 | Clarified status of mkfifo(). | Joel Sherrill | 1 | -0/+2 | |
1999-11-29 | Updated. | Joel Sherrill | 3 | -276/+324 | |
1999-11-29 | Removed bad descriptions of mount() and umount(). Added shell of an | Joel Sherrill | 1 | -124/+25 | |
accurate description. | |||||
1999-11-24 | Added chapter of list of routines provided by libm. | Joel Sherrill | 4 | -17/+102 | |
1999-11-24 | New file. | Joel Sherrill | 1 | -0/+154 | |
1999-11-24 | Added routines included by C library. | Joel Sherrill | 4 | -2/+336 | |
1999-11-24 | Added information on RTEMS Time/Date Representatin. | Joel Sherrill | 3 | -2/+120 | |
1999-11-23 | Added sem_timedwait to bullet list at front of chapter. | Joel Sherrill | 1 | -0/+1 | |
1999-11-23 | Added descriptions for bullet list and routine section headings. | Joel Sherrill | 1 | -8/+8 | |
1999-11-23 | Added Timer Manager Chapter. | Joel Sherrill | 2 | -1/+8 | |
1999-11-23 | Fixed line too long. | Joel Sherrill | 1 | -2/+2 | |
1999-11-23 | New file. | Joel Sherrill | 1 | -0/+196 | |
1999-11-23 | Added projects chapter to FAQ. | Joel Sherrill | 3 | -2/+122 | |
1999-11-17 | changed version to 19991117 | Joel Sherrill | 1 | -1/+1 | |
1999-11-17 | Removed reference to Jennifer. | Joel Sherrill | 1 | -2/+1 | |
1999-11-17 | New date. | Joel Sherrill | 2 | -5/+5 | |
1999-11-17 | Corrected spacing. | Joel Sherrill | 1 | -8/+12 | |
1999-11-17 | Correctd name of document produced for consistency. | Joel Sherrill | 1 | -1/+1 | |
1999-11-17 | Updated to reflect Mailbox Manager submission. | Joel Sherrill | 1 | -3/+1 | |
1999-11-16 | Fixed spacing. | Joel Sherrill | 12 | -175/+185 | |
1999-11-16 | Changed name of document generated. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Added ITRON 3.0 API User's Guide. | Joel Sherrill | 2 | -2/+12 | |
1999-11-16 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Corrected status. | Joel Sherrill | 1 | -2/+2 | |
1999-11-16 | Fixed spacing. | Joel Sherrill | 2 | -48/+48 | |
1999-11-16 | New file. | Joel Sherrill | 1 | -0/+14 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 308 | -372/+384 | |
1999-11-16 | Added copyright. | Joel Sherrill | 14 | -12/+62 | |
1999-11-16 | Changed release date. | Joel Sherrill | 2 | -6/+6 | |
1999-11-16 | Added status chapter. | Joel Sherrill | 3 | -2/+73 | |
1999-11-16 | Added reference to rtems_get_class, rtems_get_node, and rtems_get_index | Joel Sherrill | 1 | -7/+29 | |
so users know they are part of the public API. | |||||
1999-11-16 | Added task variable services. | Joel Sherrill | 2 | -1/+131 | |
1999-11-16 | Added categorized list of constants in confdefs.h. | Joel Sherrill | 1 | -0/+126 | |
1999-11-15 | Added paragraph describing SUSP. | Joel Sherrill | 1 | -0/+9 | |
1999-11-11 | Added information about the NTP servier field and included a copy | Joel Sherrill | 2 | -3/+69 | |
of the C definition of the configuration structure. | |||||
1999-11-10 | Updated to include more documentation from CS595. | Joel Sherrill | 5 | -22/+51 | |
1999-11-10 | Better formatting. | Joel Sherrill | 1 | -47/+75 | |
1999-11-09 | Converted from DOS to UNIX filemode. | Joel Sherrill | 3 | -1630/+1630 | |
1999-11-09 | Corrected lines that were too long. | Joel Sherrill | 2 | -8/+8 | |
1999-11-09 | Fixed formatting error. | Joel Sherrill | 1 | -1/+0 | |
1999-11-09 | Corrected manual name. | Joel Sherrill | 1 | -8/+8 | |
1999-11-09 | Integrated into main tree. | Joel Sherrill | 1 | -26/+15 | |
1999-11-09 | Update from Jennifer. | Joel Sherrill | 1 | -30/+54 | |
1999-11-09 | Added more status information. | Joel Sherrill | 1 | -0/+80 | |
