PR 1947/doc
* started/buildrt.t: Make note that native toolset is needed to
configure and build RTEMS.
Petr Benes <benesp16@fel.cvut.cz>
PR 1912/doc
* user/conf.t, user/schedule.t: Rework to add scheduler specific
information.
* user/Makefile.am, user/c_user.texi: Reorder chapters to put
scheduling earlier. Also put Barrier and Rate Monotonic Manager where
they logically belong. They appear to have just be added toward the
end.
PR 1864/doc
* user/conf.t: Add missing documentation for
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS,
CONFIGURE_MAXIMUM_POSIX_BARRIERS , CONFIGURE_MAXIMUM_POSIX_SPINLOCKS,
CONFIGURE_MAXIMUM_POSIX_RWLOCKS.
PR 1851/doc
* user/conf.t: Fix typo in CONFIGURE_MESSAGE_BUFFER_MEMORY example.
* user/mp.t: Avoid obsolete notation.
* user/part.t, user/sem.t: Typos.
PR 1824/cpukit
* bsp_howto/init.t, bsp_howto/support.t, user/init.t: Return
exit/shutdown status back to boot_card().
* bsp_howto/support.t: Update copyright.
* bsp_howto/support.t: Add section describing configuration macros
which may be defined at the BSP level to alter defaults in
rtems/confdefs.h.
* user/conf.t: Fix typos.
* user/conf.t: Add SMP Configuration parameters.
* user/conf.t: Slight rework to deemphasize not using confdefs.h
* index.html.in, common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New dates.
PR 1782/cpukit
* porting/taskcontext.t: Disable deferred FPU context switches when SMP
is enabled. Per code tracking of deferred contexts is not
implemented.
* rtems_footer.html.in, common/cpright.texi: Update dates in copyright.
* ada_user/.cvsignore: Add missing files.
PR 1743/cpu
* user/conf.t: Add Simple Priority Scheduler as complement to existing
Deterministic Priority Scheduler. This scheduler serves both as an
example and as a lighter weight implementation for smaller systems.
PR 1752/doc
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Remove TI C4x CPU Supplement
chapter.
* cpu_supplement/tic4x.t: Removed.
* ada_user/Makefile.am: Add ObjectId pdf files.
* configure.ac: Rename RTEMS_API into _RTEMS_API.
PR 1744/doc
* user/clock.t: rtems_clock_time_value type uses changed to struct
timeval.
* setup.def, shell/preface.texi: Bump to 4.10.99.0
* user/conf.t: Document changes to Scheduler configuration.
* posix_users/posix_users.texi, posix_users/signal.t: Review and
improve as part of Google Code-In 2010.
* started/buildc.t, started/buildrt.t, started/nt.t, started/require.t,
started/sample.t: Review and improve.
* develenv/direct.t: Remove Getting Started with GNAT/RTEMS.
* started_ada/.cvsignore, started_ada/Makefile.am,
started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t,
started_ada/require.t, started_ada/sample.t, started_ada/stamp-vti,
started_ada/started_ada.texi, started_ada/tversions.texi,
started_ada/version.texi: Removed.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
PR 1647/cpukit
* user/conf.t, user/schedule.t: Update documentation to reflect
refactoring of SuperCore to add Scheduler and ability for user to
configure a scheduler.
PR 1716/doc
* user/concepts.t: print_name example used a variable which did not
match the name of the passed in parameter.
PR 1714/doc
* user/datatypes.t: Add missing description of rtems_status_codes.
PR 1674/docs
* user/Makefile.am, user/dirstat.texi: Fix bad node reference.
PR 1513/doc
* user/chains.t: Added missing functions. Uniform text for
unprotected functions.
PR 1650/cpukit
* user/part.t: Clarify.
PR 1599/cpukit
* porting/interrupts.t: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1635/cpukit
* porting/prioritybitmap.t: Refactoring of priority handling, to
isolate the bitmap implementation of priorities in the supercore so
that priority management is a little more modular. This change is in
anticipation of scheduler implementations that can select how they
manage tracking priority levels / finding the highest priority ready
task. Note that most of the changes here are simple renaming, to
clarify the use of the bitmap-based priority management.
PR 1573/cpukit
* porting/interrupts.t: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* Makefile.am, configure.ac, index.html.in, develenv/direct.t,
posix_users/gen_size_report, started/nextstep.t,
started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API.
* itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t,
itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all,
itron3.0/gen_section, itron3.0/gen_status_shell,
itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t,
itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t,
itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t,
itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t,
itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
PR 1568/doc
* user/intr.t: Fix list of services callable from ISR.
PR 1565/cpukit
* cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi: Merge
SPARC64 port.
* cpu_supplement/sparc64.t: New file.
* main.am: Don't install html_projectdir unconditionally.
* cpu_supplement/Makefile.am: Include main.am.
* ada_user/stamp-vti, ada_user/version.texi,
bsp_howto/stamp-vti, bsp_howto/version.texi,
cpu_supplement/stamp-vti, cpu_supplement/version.texi,
develenv/stamp-vti, develenv/version.texi,
filesystem/stamp-vti, filesystem/version.texi,
itron3.0/stamp-vti, itron3.0/version.texi,
networking/stamp-vti, networking/version.texi,
new_chapters/stamp-vti, new_chapters/version.texi,
porting/stamp-vti, porting/version.texi,
posix1003.1/stamp-vti, posix1003.1/version.texi,
posix_users/stamp-vti, posix_users/version.texi,
relnotes/stamp-vti, relnotes/version.texi,
shell/stamp-vti, shell/version.texi,
started/stamp-vti, started/version.texi,
started_ada/stamp-vti, started_ada/version.texi,
user/stamp-vti, user/version.texi:
New.
* ada_user/Makefile.am, bsp_howto/Makefile.am,
cpu_supplement/Makefile.am, develenv/Makefile.am,
filesystem/Makefile.am, itron3.0/Makefile.am,
networking/Makefile.am, new_chapters/Makefile.am,
porting/Makefile.am, posix1003.1/Makefile.am,
posix_users/Makefile.am, relnotes/Makefile.am,
shell/Makefile.am, started/Makefile.am,
started_ada/Makefile.am, user/Makefile.am:
Remove EDITION (Unused).
* user/.cvsignore: Add semaphore_attributes.pdf.
PR 1520/doc
* user/part.t: Partition create discussion said it returned the number
of buffers created but it does not.
