* Makefile.am: Add direct.t sample.t utils.t to EXTRA_DIST.
* Makefile.am: Add ata.t, ide_ctrl.t to EXTRA_DIST.
* Makefile.am: Add tversions.texi.in to EXTRA_DIST.
PR 464/doc
* clock.t, signal.t: Add documentation for usleep() and ualarm(). Also
fixed a couple of calls which have the wrong .h files per the
OpenGroup site documentation.
* Makefile.am: mips64orion port removed as mips port more completely
covers the MIPS family.
* configure.ac, index.html.in: mips64orion port removed as mips port
more completely covers the MIPS family.
* rtems_support.html.in: Removed.
* buildada.t: mips64orion port removed as mips port more completely
* mips64orion/.cvsignore, mips64orion/BSP_TIMES, mips64orion/ChangeLog,
mips64orion/Makefile.am, mips64orion/bsp.t, mips64orion/callconv.t,
mips64orion/cpumodel.t, mips64orion/cputable.t,
mips64orion/fatalerr.t, mips64orion/intr_NOTIMES.t,
mips64orion/memmodel.t, mips64orion/mips64orion.texi,
mips64orion/preface.texi, mips64orion/timeBSP.t: Removed.
* Makefile.am: Cosmetics.
* project.am: Remove $(PROJECT).info* from CLEANFILES (Doesn't work
with automake-1.7f/1.8 anymore).
PR 528/rtems_misc
* task.t: Fix Ada binding for task variable calls.
* Makefile.am: Add missing '\'. Reformat.
* system.h: Remove USE_INLINES.
* chain.c: Remove USE_INLINES.
PR 521/doc
* sem.t: Default attributes were wrong for semaphores.
PR 513/doc
* Makefile.am, index.html.in: Rename Getting Started to be non-language
specific and remove link to Ada Getting Started. Also install missing
graphic.
PR 513/doc
* started.texi: Rename to be non-language specific.
* Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t,
sample.t, started.texi: General improvements and merge enough Ada
information to justify dropping the Ada specific manual. There is
likely still Ada specific information to merge though.
* nextstep.t: RTEMS applications can now use main() so correct the
discussion of this.
* networkapp.t, preface.texi: Improve documentation for SO_RCVWAKEUP
and SO_SNDWAKEUP and update the references in the preface.
* preface.texi: Eliminate references to HPPA.
* cpumodel.t: Obsoleting HP PA-RISC port and removing all references.
* status.texi: Obsoleting HP PA-RISC port and removing all references.
* cpumodels.t: Obsoleting HP PA-RISC port and removing all references.
* basic.t, entry: Obsoleting HP PA-RISC port and removing all
references.
* hppa1_1/.cvsignore, hppa1_1/ChangeLog, hppa1_1/Makefile.am,
hppa1_1/SIMHPPA_TIMES, hppa1_1/bsp.t, hppa1_1/callconv.t,
hppa1_1/cpumodel.t, hppa1_1/cputable.t, hppa1_1/fatalerr.t,
hppa1_1/hppa1_1.texi, hppa1_1/intr_NOTIMES.t, hppa1_1/memmodel.t,
hppa1_1/preface.texi, hppa1_1/timeSIMHPPA.t: Removed.
* nt.t: Significant update of Windows information. Hopefully this is
now more useful.
* images/ChangeLog: Removed.
* ChangeLog: Merge images/ChangeLog.
* common/ChangeLog: Removed.
* ChangeLog: Merge common/ChangeLog.
* common/.cvsignore: Add rtems.texi, rtems.sed.
* configure.ac: Merger from rtems-4-6-branch.
Purge hppa1.1.
* index.html.in: Purge hppa1.1.
* project.am: Merger from rtems-4-6-branch.
* rtems_support.html.in: Purge hppa1.1.
* supplement.am: Add -I $(top_builddir) TEXI2WWW_ARGS.
* Makefile.am: Purge hppa1.1.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* FAQ.texi, basic.t, build45.t, entry, tools.t: Merge from branch.
* analog.t, bsp_howto.texi, discrete.t, nvmem.t, target.t: Merge from
branch.
* cpright.texi, setup.texi: Merge from branch.
* rtems.texi.in: New file.
* develenv.texi, direct.t, sample.t, utils.t: Merge from branch.
* filesystem.texi: Merge from branch.
* gnu_footer.html, gnu_header.html, index.html, refcard.html,
rtems_tools_index.html: Merge from branch.
* itron.texi: Merge from branch.
* networking.texi: Merge from branch.
* porting.texi: Merge from branch.
* new_chapters.texi: Merge from branch.
