path: root/doc (unfollow)
2000-05-28Bug fix from Trevin Beattie <trevin@eyring.com> picked up fromJoel Sherrill1-0/+1
the bug-texinfo mailing list: There is also a bug in the PDF outline: Any outline item containing an underscore shows up as a bunch of texinfo codes ("@unhbox @kern.06em @vbox{..."). This bug was remedied by the following addition to \pdfmakeoutlines.
2000-05-28Updated to reflect lower confdefs.h values and new controlJoel Sherrill2-11/+73
over number of termios ports.
2000-05-25Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>.Joel Sherrill1-2/+2
- char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig
2000-05-17Corrected paths.Joel Sherrill3-7/+7
2000-05-11Added information on the location where the tools are installed.Joel Sherrill1-0/+10
2000-05-10Added "@" in front of "{" and "}" to make texinfo happy.Joel Sherrill2-8/+8
2000-05-10Made examples include checking of return status.Joel Sherrill2-12/+40
2000-05-10Removed duplicate NEEDS_CONSOLE_DRIVER.Joel Sherrill1-1/+0
2000-05-09Typo resulting in bad link fixed.Joel Sherrill1-1/+1
2000-05-09Added comment on RTEMS_DEFAULT_MODE.Joel Sherrill1-0/+3
2000-05-09Updated NT editor information to update status on PFE and addJoel Sherrill1-6/+24
pointers to emacs and vim.
2000-05-09Updated in order to generate a current tool chain documentation set.Joel Sherrill5-97/+144
2000-05-08Updated.Joel Sherrill2-6/+8
2000-05-08Updated versions.Joel Sherrill2-8/+8
2000-05-08Added some more.Joel Sherrill1-0/+8
2000-05-08Added more information to the "next step" chapter. The new informationJoel Sherrill2-1/+58
tries to give a pointer about how to approach writing an application.
2000-05-08Patch from Ralf Corsepies <corsepiu@faw.uni-ulm.de> thatJoel Sherrill3-223/+2
fixes handling of word-replace and removes tool/update.
2000-05-08Made comment a little more detailed.Joel Sherrill1-1/+2
2000-05-08Updated.Joel Sherrill1-17/+4
2000-05-08Added Data Types chapter.Joel Sherrill2-2/+4
2000-05-08New file datatypes.texi added.Joel Sherrill1-0/+1
2000-05-08Added Data Types Chapter.Joel Sherrill2-3/+10
2000-05-08Fixed typo so constand would have "RTEMS_".Joel Sherrill1-1/+1
2000-05-08Added function index entries for all data types and enhanced introductoryJoel Sherrill1-3/+85
structure.
2000-05-08Fixed type so constant would have "RTEMS_" in front of it.Joel Sherrill1-1/+1
2000-05-08Now sharing the "buildrt.t" or Building RTEMS chapter with theJoel Sherrill2-142/+4
C version of Getting Started.
2000-05-05New file.Joel Sherrill1-0/+229
2000-05-05Updated example.Joel Sherrill1-56/+18
2000-05-05Added function indexes for CONFIGURE_ constants.Joel Sherrill1-1/+85
2000-05-05More updates.Joel Sherrill2-4/+4
2000-05-05Added much information on confdefs.h parameters.Joel Sherrill1-78/+437
2000-05-04Modifed to avoid using @uref directive since that does not seemJoel Sherrill3-19/+34
to work with pdf generation.
2000-05-04More information on what symbolic information is for andJoel Sherrill1-0/+13
how to get it from a file other thatn the executable.
2000-05-04Added nextstep.texiJoel Sherrill1-0/+1
2000-05-04Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill31-140/+508
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
2000-05-04New file.Joel Sherrill1-0/+72
2000-05-02Patch rtemsdoc-4.5.0-rc-4-cvs.diff from Ralf CorsepiusJoel Sherrill2-8/+31
<corsepiu@faw.uni-ulm.de> to correct some typos and improve the information for DDD and the Hitachi SH.
2000-05-02Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill5-10/+17
<Stephan.Wilms@CWA.de>.
2000-05-02RTEMS_MAKEFILE_PATH instructions incorrectly included rtems subdirectory.Joel Sherrill1-2/+5
This directory was removed post-4.0 to be more in compliance with GNU standards. Reported by Stephan Wilms <Stephan.Wilms@CWA.de>.
2000-05-01A bit more explanation for task variables per Eric Norum <eric@cls.usask.ca>.Joel Sherrill1-0/+7
2000-05-01File rendered obsolete by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill1-342/+0
2000-05-01Removed file rendered obsolete by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill2-90/+1
2000-05-01New file added by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill1-0/+1045
2000-05-01Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill56-644/+595
It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
2000-04-27Updated.Joel Sherrill1-0/+13
2000-04-27New files. First attempt.Joel Sherrill41-0/+861
2000-04-27Updated.Joel Sherrill1-13/+24
2000-04-27Removed -- temporary files.Joel Sherrill8-11515/+0
2000-04-27Files moved around and missed in the previous commit.Joel Sherrill11-0/+14
2000-04-27Modified to give rpm removal command instead of install command again.Joel Sherrill1-6/+6
