* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-03 | 2 | -2/+8 |
| | | | | | | PR 338/filesystem * io.t: Fix Ada binding as side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | ||||
* | 2003-02-03 Steven Johnson <sjohnson@neurizon.net> | Joel Sherrill | 2003-02-03 | 2 | -1/+7 |
| | | | | | | PR 338/filesystem * io.t: Document the API change that fixed reentrancy problem with rtems_io_lookup_name(). | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -14/+18 |
| | | | | * tversions.texi: Updated tool version numbers. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 3 | -48/+44 |
| | | | | | * makefiles.t, support.t: Updated to reflect use of automake in addition to autoconf. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+42 |
| | | | | * .cvsignore: New file. | ||||
* | 2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-27 | 2 | -10/+5 |
| | | | | * index.html.in: Fix duplicate c4x entry. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -0/+14 |
| | | | | * index.html.in: Add c4x. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+5 |
| | | | | * c_user.texi: Set @setfilename c_user.info. | ||||
| | | | | * template.texi: Set @setfilename template.info. | ||||
| | | | | * sparc.texi: Set @setfilename sparc.info. | ||||
| | | | | * sh.texi: Set @setfilename sh.info. | ||||
| | | | | * powerpc.texi: Set @setfilename powerpc.info. | ||||
| | | | | * mips64orion.texi: Set @setfilename mips64orion.info. | ||||
| | | | | * mips.texi: Set @setfilename mips.info. | ||||
| | | | | * m68k.texi: Set @setfilename m68k.info. | ||||
| | | | | * i960.texi: Set @setfilename i960.info. | ||||
| | | | | * i386.texi: Set @setfilename i386.info. | ||||
| | | | | * hppa1_1.texi: Set @setfilename hppa1_1.info. | ||||
| | | | | * c4x.texi: Set @setfilename c4x.info. | ||||
| | | | | * arm.texi: Set @setfilename arm.info. | ||||
| | | | | * started_ada.texi: Set @setfilename started_ada.info. | ||||
| | | | | * started.texi: Set @setfilename started.info. | ||||
| | | | | * rtems_gdb.texi: Set @setfilename rtems_gdb.info. | ||||
| | | | | * rgdb_specs.texi: Set @setfilename rgdb_specs.info. | ||||
| | | | | * relnotes.texi: Set @setfilename relnotes.info. | ||||
| | | | | * posix_users.texi: Set @setfilename posix_users.info. | ||||
| | | | | * posix1003_1.texi: Set @setfilename posix1003_1.info. | ||||
| | | | | * porting.texi: Set @setfilename porting.info. | ||||
| | | | | * new_chapters.texi: Set @setfilename new_chapters.info. | ||||
| | | | | * networking.texi: Set @setfilename networking.info. | ||||
| | | | | * itron.texi: Set @setfilename itron.info. | ||||
| | | | | * filesystem.texi: Set @setfilename filesystem.info. | ||||
| | | | | * develenv.texi: Set @setfilename develenv.info. | ||||
| | | | | * bsp_howto.texi: Set @setfilename bsp_howto.info. | ||||
| | | | | * ada_user.texi: Set @setfilename ada_user.info. | ||||
| | | | | * FAQ.texi: Set @setfilename FAQ.info. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 3 | -0/+9 |
| | | | | | * configure.ac: Add c4x. * project.am: Add version.texi hack. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+16 |
| | | | | * Makefile.am: Add c4x, cosmetical changes. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 5 | -23/+131 |
| | | | | | | * Makefile.am: New. * c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them building. | ||||
* | 2003-01-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-24 | 12 | -0/+1378 |
| | | | | | | * BSP_TIMES, bsp.t, c4x.texi, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, timeBSP.t: New files. These should have been added long ago. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 2 | -4/+4 |
| | | | | * supplements.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 44 | -243/+331 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 8 | -50/+66 |
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 3 | -5/+20 |
| | | | | | | | * main.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. Append -I $(top_builddir) to TEXI2WWW_ARGS. * project.am: Add AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. Override automake's .dvi.ps:-rule. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 2 | -3/+8 |
| | | | | | * supplements.am: Use automake rules to build ps, pdf, info. Various minor changes. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 3 | -23/+13 |
| | | | | | * project.am, main.am: Use automake rules to build ps, pdf, info. Various minor changes. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 2 | -1/+5 |
| | | | | * build45.t: Fix typo in previous patch. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 2 | -9/+70 |
| | | | | * build45.t: Several fixes and additions. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 2 | -2/+7 |
| | | | | | * project.am: Append $($(PROJECT)_TEXINFOS) to html-dependencies. |
