path: root/doc (follow)
* 2005-06-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-06-172-0/+71
| | | | * user/region.t: Add documentation on region_resize_segment.
* 2005-04-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-04-282-3/+47
| | | | * bsp_howto/rtc.t: Rewritten to account for removal of dmv177.
* 2005-03-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-042-1/+6
| | | | | * networking/decdriver.t: Make PCI initialize function part of the unified PCI API as pci_initialize().
* Cosmetics.Ralf Corsepius2004-12-301-4/+3
* 2004-11-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-11-052-1/+6
| | | | | PR 706/doc * user/task.t: Remove not that changes explanation.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-2910-20/+7
| | | | | | * configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry, porting/cpumodels.t, started/buildc.t, started_ada/buildada.t, user/preface.texi: i960 obsoleted.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-293-14/+4
| | | | * intro.texi, status.texi: i960 obsoleted.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-2916-1309/+11
| | | | | | | | | | | * supplements/Makefile.am: i960 obsoleted. * supplements/i960/.cvsignore, supplements/i960/CVME961_TIMES, supplements/i960/ChangeLog, supplements/i960/Makefile.am, supplements/i960/bsp.t, supplements/i960/callconv.t, supplements/i960/cpumodel.t, supplements/i960/cputable.t, supplements/i960/fatalerr.t, supplements/i960/i960.texi, supplements/i960/intr_NOTIMES.t, supplements/i960/memmodel.t, supplements/i960/preface.texi, supplements/i960/timeCVME961.t: Removed.
* Correct PR number.Joel Sherrill2004-09-271-3/+3
* 2004-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-275-32/+44
| | | | | | | | PR 681/doc PR 682/doc * buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable binutils link again. * user/overview.t: Chapter numbering in preface was wrong.
* Fix typo in previous change.Ralf Corsepius2004-09-242-2/+2
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-244-2/+10
| | | | * configure.ac: Require automake > 1.9.
* 2004-09-08 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-082-4/+9
| | | | * FAQ/build45.t: Misc. corrections.
* 2004-08-02 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-021-0/+14
| | | | | | | | | * rgdb_specs/layers.txt, rgdb_specs/process.txt, rgdb_specs/seqbreak.txt, rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.txt: New. * rgdb_specs/comm.t, rgdb_specs/conclusion.t, rgdb_specs/gdbinternals.t: Use @image for ASCII figures (Reflect changes above).
* Use @image for ASCII figures (Reflect changes above).Ralf Corsepius2004-08-023-107/+17
* New.Ralf Corsepius2004-08-025-0/+10
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-312-17/+0
| | | | | * common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS, RTEMSSNAPSHOTSSUBSCRIBE.
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-311-0/+7
| | | | | | | * FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi, FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi, FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/tools.texi, FAQ/version.texi, FAQ/stamp-vti: New.
* Readd.Ralf Corsepius2004-07-311-0/+4
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-3111-0/+1904
| | | | | | | * FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi, FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi, FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/tools.texi, FAQ/version.texi: New.
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-316-39/+23
| | | | | | | * networking/networkflow.txt, networking/PCIreg.txt, networking/recvbd.txt: New. * networking/decdriver.t, networking/networktasks.t: Use @image for ASCII figures (Reflect changes above).
* Fix format.Joel Sherrill2004-07-241-1/+1
* 2004-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-07-242-0/+7
| | | | | | PR rtems/652 * user/signal.t: Return RTEMS_INVALID_NUMBER when sending an empty signal set.
* 2004-06-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-06-292-2/+9
| | | | | | PR 631/rtems * user/msg.t: Document the return status from message_queue_create when unable to allocate message buffer memory.
* 2004-05-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-212-4/+10
| | | | | | PR 627/doc * user/task.t: Behavior documented for an rtems_task_create with stacksize < minimum was not the implemented behavior.
* 2004-05-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-0610-14/+70
| | | | | | | PR 618/rtems * user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t, user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL checks.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-313-2/+7
| | | | | * started/buildc.t: Use tar xjf for bzip'ed files. * started/buildrt.t: Use tar xjf to unzip rtems.
* Remove refs to Makefile*.Ralf Corsepius2004-03-091-2/+0
* Unused.Ralf Corsepius2004-03-092-4/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-054-63/+10
| | | | | | | | PR 576/doc * FAQ/FAQ.texi, FAQ/Makefile.am: Remove embedded information as it was out of date and frequently duplicated information available from other public sources like the CrossGCC Wiki. * FAQ/embeddedinfo.t: Removed.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-172-3/+7
| | | | * develenv/Makefile.am: Put *.texi into the builddir.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-142-76/+4
| | | | * started/tversions.texi: Remove (Bogus).
* Cleanup.Ralf Corsepius2004-02-132-4/+0
* Reformat.Ralf Corsepius2004-02-051-311/+153
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-052-75/+41
| | | | | * ChangeLog: Merge-in supplements/ChangeLog. * supplements/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-053-139/+48
| | | | | | * ChangeLog: Merge-in ada_user/ChangeLog. * ChangeLog: Merge-in started_ada/ChangeLog. * ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-055-320/+122
| | | | | | | | | * ChangeLog: Merge-in bsp_howto/ChangeLog. * ChangeLog: Merge-in porting/ChangeLog. * ChangeLog: Merge-in rgdb_specs/ChangeLog. * ChangeLog: Merge-in rtems_gdb/ChangeLog. * bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog, rtems_gdb/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-053-141/+55
| | | | | | * ChangeLog: Merge-in filesystem/ChangeLog. * ChangeLog: Merge-in networking/ChangeLog. * filesystem/ChangeLog, networking/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-054-212/+79
| | | | | | | | * ChangeLog: Merge-in posix_users/ChangeLog. * ChangeLog: Merge-in posix1003.1/ChangeLog. * ChangeLog: Merge-in itron3.0/ChangeLog. * posix_users/ChangeLog, posix1003.1/ChangeLog, itron3.0/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-052-91/+35
| | | | | * ChangeLog: Merge-in FAQ/ChangeLog. * FAQ/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-052-153/+96
| | | | | * ChangeLog: Merge-in user/ChangeLog. * user/ChangeLog: Remove.
* 2004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-0417-59/+78
| | | | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-014-1/+9
| | | | | | * configure.ac: Add RTEMSRPMGROUP. * common/rtems.texi.in: Add RTEMSRPMGROUP. * started/binaries.t: Add RTEMSRPMGROUP.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-012-159/+5
| | | | | * ChangeLog: Merge-in started/ChangeLog. * started/ChangeLog: Remove.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-013-35/+39
| | | | * binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-013-1/+10
| | | | | | * configure.ac: Add RTEMS_ENABLE_RPMPREFIX. Add RTEMSRPMPREFIX. * common/rtems.texi.in: Add RTEMSRPMPREFIX.
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-232-93/+56
| | | | | * ChangeLog: Reformat. Merge-in develenv/ChangeLog. * develenv/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-232-89/+39
* 2004-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-202-1/+6
| | | | | PR 555/doc * sample.t: Fix RTEMS_MAKEFILE_PATH reference.
* 2004-01-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-172-5/+12
| | | | | | * Makefile.am: Remove AUTOMAKE_FILES. Add ../scripts/setup.def ../COPYING to EXTRA_DIST. Add rtems.html.in to EXTRA_DIST.
