* | 2003-02-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-18 | 6 | -414/+288 | |
| | | | | | | | | * Makefile.am, develenv.texi: Relect generating .texi from .t's. * direct.t, sample.t, utils.t: New files. * direct.texi, sample.texi, utils.texi: Removed. Now generated from corresponding .t files which are in the process of being updated. This commit is a anspshot of the update effort. | |||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 2 | -10/+4 | |
| | | | | * index.html.in: Removed a29k reference. | |||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 2 | -11/+8 | |
| | | | | * cpumodels.t: Removed a29k reference and updated. | |||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 2 | -3/+11 | |
| | | | | * preface.texi: Remove a29k references and update. | |||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 3 | -7/+18 | |
| | | | | * basic.t, entry: Remove A29k references and update. | |||||
* | 2003-02-14 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2003-02-14 | 5 | -111/+29 | |
| | | | | | | PR 347/rtems * rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline assembly so it correctly generates on newer gcc's. | |||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-02-14 | 50 | -3628/+11 | |
* | 2003-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-11 | 2 | -9/+14 | |
| | | | | | | | * interrupts.t: Rework logic that decides when to call _Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru> determined that _ISR_Signals_to_thread_executing was not being honored and/or cleared properly. | |||||
* | 2003-02-11 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2003-02-11 | 2 | -1/+324 | |
| | | | | * networkapp.t: Add an example code snippet for adding a default route. | |||||
* | 2003-02-11 Mike Siers <mikes@poliac.com> | Joel Sherrill | 2003-02-11 | 2 | -0/+38 | |
| | | | | * networkapp.t: Add an example code snippet for adding an IP alias. | |||||
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 | |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
| | | | | * configure.ac: AC_PREREQ(2.57). | |||||
* | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-03 | 2 | -2/+8 | |
| | | | | | | PR 338/filesystem * io.t: Fix Ada binding as side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | |||||
* | 2003-02-03 Steven Johnson <sjohnson@neurizon.net> | Joel Sherrill | 2003-02-03 | 2 | -1/+7 | |
| | | | | | | PR 338/filesystem * io.t: Document the API change that fixed reentrancy problem with rtems_io_lookup_name(). | |||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -14/+18 | |
| | | | | * tversions.texi: Updated tool version numbers. | |||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 3 | -48/+44 | |
| | | | | | * makefiles.t, support.t: Updated to reflect use of automake in addition to autoconf. | |||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+42 | |
| | | | | * .cvsignore: New file. | |||||
* | 2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-27 | 2 | -10/+5 | |
| | | | | * index.html.in: Fix duplicate c4x entry. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -0/+14 | |
| | | | | * index.html.in: Add c4x. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+5 | |
| | | | | * c_user.texi: Set @setfilename c_user.info. | |||||
| | | | | * template.texi: Set @setfilename template.info. | |||||
| | | | | * sparc.texi: Set @setfilename sparc.info. | |||||
| | | | | * sh.texi: Set @setfilename sh.info. | |||||
| | | | | * powerpc.texi: Set @setfilename powerpc.info. | |||||
| | | | | * mips64orion.texi: Set @setfilename mips64orion.info. | |||||
| | | | | * mips.texi: Set @setfilename mips.info. | |||||
| | | | | * m68k.texi: Set @setfilename m68k.info. | |||||
| | | | | * i960.texi: Set @setfilename i960.info. | |||||
| | | | | * i386.texi: Set @setfilename i386.info. | |||||
| | | | | * hppa1_1.texi: Set @setfilename hppa1_1.info. | |||||
| | | | | * c4x.texi: Set @setfilename c4x.info. | |||||
| | | | | * arm.texi: Set @setfilename arm.info. | |||||
| | | | | * started_ada.texi: Set @setfilename started_ada.info. | |||||
| | | | | * started.texi: Set @setfilename started.info. | |||||
| | | | | * rtems_gdb.texi: Set @setfilename rtems_gdb.info. | |||||
| | | | | * rgdb_specs.texi: Set @setfilename rgdb_specs.info. | |||||
| | | | | * relnotes.texi: Set @setfilename relnotes.info. | |||||
| | | | | * posix_users.texi: Set @setfilename posix_users.info. | |||||
| | | | | * posix1003_1.texi: Set @setfilename posix1003_1.info. | |||||
| | | | | * porting.texi: Set @setfilename porting.info. | |||||
| | | | | * new_chapters.texi: Set @setfilename new_chapters.info. | |||||
| | | | | * networking.texi: Set @setfilename networking.info. | |||||
| | | | | * itron.texi: Set @setfilename itron.info. | |||||
| | | | | * filesystem.texi: Set @setfilename filesystem.info. | |||||
| | | | | * develenv.texi: Set @setfilename develenv.info. | |||||
| | | | | * bsp_howto.texi: Set @setfilename bsp_howto.info. | |||||
| | | | | * ada_user.texi: Set @setfilename ada_user.info. | |||||
| | | | | * FAQ.texi: Set @setfilename FAQ.info. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 3 | -0/+9 | |
| | | | | | * configure.ac: Add c4x. * project.am: Add version.texi hack. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+16 | |
| | | | | * Makefile.am: Add c4x, cosmetical changes. |
