* | Clarified. | Joel Sherrill | 1999-11-29 | 1 | -0/+2 |
* | Clarified status of mkfifo(). | Joel Sherrill | 1999-11-29 | 1 | -0/+2 |
* | Updated. | Joel Sherrill | 1999-11-29 | 3 | -276/+324 |
* | Removed bad descriptions of mount() and umount(). Added shell of an | Joel Sherrill | 1999-11-29 | 1 | -124/+25 |
| | | | | accurate description. | ||||
* | Added chapter of list of routines provided by libm. | Joel Sherrill | 1999-11-24 | 4 | -17/+102 |
* | New file. | Joel Sherrill | 1999-11-24 | 1 | -0/+154 |
* | Added routines included by C library. | Joel Sherrill | 1999-11-24 | 4 | -2/+336 |
* | Added information on RTEMS Time/Date Representatin. | Joel Sherrill | 1999-11-24 | 3 | -2/+120 |
* | Added sem_timedwait to bullet list at front of chapter. | Joel Sherrill | 1999-11-23 | 1 | -0/+1 |
* | Added descriptions for bullet list and routine section headings. | Joel Sherrill | 1999-11-23 | 1 | -8/+8 |
* | Added Timer Manager Chapter. | Joel Sherrill | 1999-11-23 | 2 | -1/+8 |
* | Fixed line too long. | Joel Sherrill | 1999-11-23 | 1 | -2/+2 |
* | New file. | Joel Sherrill | 1999-11-23 | 1 | -0/+196 |
* | Added projects chapter to FAQ. | Joel Sherrill | 1999-11-23 | 3 | -2/+122 |
* | changed version to 19991117 | Joel Sherrill | 1999-11-17 | 1 | -1/+1 |
* | Removed reference to Jennifer. | Joel Sherrill | 1999-11-17 | 1 | -2/+1 |
* | New date. | Joel Sherrill | 1999-11-17 | 2 | -5/+5 |
* | Corrected spacing. | Joel Sherrill | 1999-11-17 | 1 | -8/+12 |
* | Correctd name of document produced for consistency. | Joel Sherrill | 1999-11-17 | 1 | -1/+1 |
* | Updated to reflect Mailbox Manager submission. | Joel Sherrill | 1999-11-17 | 1 | -3/+1 |
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 12 | -175/+185 |
* | Changed name of document generated. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added ITRON 3.0 API User's Guide. | Joel Sherrill | 1999-11-16 | 2 | -2/+12 |
* | Fixed typo. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Corrected status. | Joel Sherrill | 1999-11-16 | 1 | -2/+2 |
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 2 | -48/+48 |
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+14 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 308 | -372/+384 |
* | Added copyright. | Joel Sherrill | 1999-11-16 | 14 | -12/+62 |
* | Changed release date. | Joel Sherrill | 1999-11-16 | 2 | -6/+6 |
* | Added status chapter. | Joel Sherrill | 1999-11-16 | 3 | -2/+73 |
* | Added reference to rtems_get_class, rtems_get_node, and rtems_get_index | Joel Sherrill | 1999-11-16 | 1 | -7/+29 |
| | | | | so users know they are part of the public API. | ||||
* | Added task variable services. | Joel Sherrill | 1999-11-16 | 2 | -1/+131 |
* | Added categorized list of constants in confdefs.h. | Joel Sherrill | 1999-11-16 | 1 | -0/+126 |
* | Added paragraph describing SUSP. | Joel Sherrill | 1999-11-15 | 1 | -0/+9 |
* | Added information about the NTP servier field and included a copy | Joel Sherrill | 1999-11-11 | 2 | -3/+69 |
| | | | | of the C definition of the configuration structure. | ||||
* | Updated to include more documentation from CS595. | Joel Sherrill | 1999-11-10 | 5 | -22/+51 |
* | Better formatting. | Joel Sherrill | 1999-11-10 | 1 | -47/+75 |
* | Converted from DOS to UNIX filemode. | Joel Sherrill | 1999-11-09 | 3 | -1630/+1630 |
* | Corrected lines that were too long. | Joel Sherrill | 1999-11-09 | 2 | -8/+8 |
* | Fixed formatting error. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Corrected manual name. | Joel Sherrill | 1999-11-09 | 1 | -8/+8 |
* | Integrated into main tree. | Joel Sherrill | 1999-11-09 | 1 | -26/+15 |
* | Update from Jennifer. | Joel Sherrill | 1999-11-09 | 1 | -30/+54 |
* | Added more status information. | Joel Sherrill | 1999-11-09 | 1 | -0/+80 |
* | Added Status chapter. | Joel Sherrill | 1999-11-09 | 4 | -4/+1059 |
* | Corrected flaws which prevented formatting with texi2pdf since it | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
| | | | | is stricter on node names. | ||||
* | Changed version timestamp. | Joel Sherrill | 1999-10-28 | 2 | -4/+4 |
* | Added information to fstat handler. | Joel Sherrill | 1999-10-28 | 1 | -14/+21 |
* | Reformatted. | Joel Sherrill | 1999-10-28 | 1 | -359/+395 |
