Returning this state in the return value leads to race conditions on
SMP. The inactive state notification must be inside the critical
section.
Interrupt locks are low-level lock to protect critical sections accessed
by threads and interrupt service routines.
Stephen Tether <tether@slac.stanford.edu> posted to the users list:
http://www.rtems.org/pipermail/rtems-users/2013-April/011273.html
I tried to make the requested changes.
This patch includes a heavy rewrite of the chapter to have a more
structured approach to this chapter. It also changes the sectioning
to have the Data Structures be a section to themselves as a peer in the
outline with each logical area of macros in confdefs.h.
Building with a document specific prefix will require coding
in both texi2any and texi2html. It is easier to build into
a directory (e.g. $(PROJECT)/). This also fixes "make clean"
which was broken.
In PDF, DVI, and PostScript files, the contents of the @top
node were being printed. These are intended only for info
and html output formats.
See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html
for instructions on how to do this.
The 16 bit Object Id image was incorrectly rotated in the manual.
Both the 16 and 32 Object Id bit images had thin borders on the table
and the bottom line was not visible in the PDF. I tinkered with the
original drawings to add a bit more space around the tables and
manually converted the PNG to EPS using Gimp to ensure a controlled
and high quality conversion.
Per a discussion with the GNU Texinfo maintainer Patrice Dumas,
change to generating HTML files per a standard for stable URL
names and easier cross manual referencing.
http://lists.gnu.org/archive/html/help-texinfo/2013-02/msg00002.html
This was tested with texi2html-1.82-5.1.el6.noarch and
a locally built texinfo 5.0. These are completely different
implementations and require different invocations.
The Makefile dependencies appear to work but are likely not
perfect at this point. The key point is that the autoconf
probe detects which to use and responds accordingly with
preference given to texi2any.
Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Call the fatal handlers of the user extensions before the update of
_Internal_errors_What_happened. This reduces the requirements on the
execution context further. Now a valid read-write data is only required
after the call to the fatal handlers.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Joel editted the documentation for clarity, grammar and technical
correctness. I also moved it in the manual and added @findex
entries. The core work was just polished.
Author: Krzysztof Mięsowicz <krzysztof.miesowicz@gmail.com>
