* posix_users/posix_users.texi, posix_users/signal.t: Review and
improve as part of Google Code-In 2010.
* started/buildc.t, started/buildrt.t, started/nt.t, started/require.t,
started/sample.t: Review and improve.
* develenv/direct.t: Remove Getting Started with GNAT/RTEMS.
* started_ada/.cvsignore, started_ada/Makefile.am,
started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t,
started_ada/require.t, started_ada/sample.t, started_ada/stamp-vti,
started_ada/started_ada.texi, started_ada/tversions.texi,
started_ada/version.texi: Removed.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
PR 1647/cpukit
* user/conf.t, user/schedule.t: Update documentation to reflect
refactoring of SuperCore to add Scheduler and ability for user to
configure a scheduler.
PR 1716/doc
* user/concepts.t: print_name example used a variable which did not
match the name of the passed in parameter.
PR 1714/doc
* user/datatypes.t: Add missing description of rtems_status_codes.
PR 1674/docs
* user/Makefile.am, user/dirstat.texi: Fix bad node reference.
PR 1513/doc
* user/chains.t: Added missing functions. Uniform text for
unprotected functions.
PR 1650/cpukit
* user/part.t: Clarify.
PR 1599/cpukit
* porting/interrupts.t: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1635/cpukit
* porting/prioritybitmap.t: Refactoring of priority handling, to
isolate the bitmap implementation of priorities in the supercore so
that priority management is a little more modular. This change is in
anticipation of scheduler implementations that can select how they
manage tracking priority levels / finding the highest priority ready
task. Note that most of the changes here are simple renaming, to
clarify the use of the bitmap-based priority management.
PR 1573/cpukit
* porting/interrupts.t: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* Makefile.am, configure.ac, index.html.in, develenv/direct.t,
posix_users/gen_size_report, started/nextstep.t,
started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API.
* itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t,
itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all,
itron3.0/gen_section, itron3.0/gen_status_shell,
itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t,
itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t,
itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t,
itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t,
itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
PR 1568/doc
* user/intr.t: Fix list of services callable from ISR.
PR 1565/cpukit
* cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi: Merge
SPARC64 port.
* cpu_supplement/sparc64.t: New file.
* main.am: Don't install html_projectdir unconditionally.
* cpu_supplement/Makefile.am: Include main.am.
* ada_user/stamp-vti, ada_user/version.texi,
bsp_howto/stamp-vti, bsp_howto/version.texi,
cpu_supplement/stamp-vti, cpu_supplement/version.texi,
develenv/stamp-vti, develenv/version.texi,
filesystem/stamp-vti, filesystem/version.texi,
itron3.0/stamp-vti, itron3.0/version.texi,
networking/stamp-vti, networking/version.texi,
new_chapters/stamp-vti, new_chapters/version.texi,
porting/stamp-vti, porting/version.texi,
posix1003.1/stamp-vti, posix1003.1/version.texi,
posix_users/stamp-vti, posix_users/version.texi,
relnotes/stamp-vti, relnotes/version.texi,
shell/stamp-vti, shell/version.texi,
started/stamp-vti, started/version.texi,
started_ada/stamp-vti, started_ada/version.texi,
user/stamp-vti, user/version.texi:
New.
* ada_user/Makefile.am, bsp_howto/Makefile.am,
cpu_supplement/Makefile.am, develenv/Makefile.am,
filesystem/Makefile.am, itron3.0/Makefile.am,
networking/Makefile.am, new_chapters/Makefile.am,
porting/Makefile.am, posix1003.1/Makefile.am,
posix_users/Makefile.am, relnotes/Makefile.am,
shell/Makefile.am, started/Makefile.am,
started_ada/Makefile.am, user/Makefile.am:
Remove EDITION (Unused).
* user/.cvsignore: Add semaphore_attributes.pdf.
PR 1520/doc
* user/part.t: Partition create discussion said it returned the number
of buffers created but it does not.
PR 1519/doc
* user/chains.t: Fix typo in Chain_Control example.
* shell/file.t: Add dd, debugrfs, hexdump, ln, mknod, mkrfs, mv.
* shell/general.t: Add time.
PR 1512/doc
* shell/general.t: Add rtc.
* shell/file.t: Add fdisk.
PR 1512/doc
* shell/general.t: Add setenv, getenv, and unsetenv.
PR 1510/doc
* user/chains.t: Fix code example.
* texi2www/texi2www: Add some new texinfo commands.
* user/chain.t: Fixed the example from PR 1504.
* user/conf.t: CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
* networking/networkapp.t: Updated the BOOTP/DHCP to document the
default behaviour of looping forever.
PR 1490/doc
* user/clock.t: Fix typo. rtems_clock_get_ticks_per_second not
rtems_clock_get_ticks_per_seconds.
* user/clock.t: Eliminate unused type rtems_clock_time_value.
PR 1460/cpukit
* user/object.t: Change return type on methods accessing portions of
RTEMS Ids to int. This allows -1 to be return on error.
* ada_user/Makefile.am, ada_user/ada_user.texi, user/Makefile.am,
user/c_user.texi, user/concepts.t, user/overview.t,
user/preface.texi, user/schedule.t, user/sem.t: Add table of figures.
Add text and graphic of tree illustrating valid combinations of
semaphore attributes.
* user/semaphore_attributes.eps, user/semaphore_attributes.png:
New files.
* bsp_howto/console.t: Capitalization.
* user/preface.texi: Remove UNIX and update port list.
* HELP.html, bsp_howto/support.t, relnotes/status.texi,
started_ada/buildada.t: Remove references to posix/Unix port.
* user/conf.t, user/userext.t: Eliminate use of deprecated
rtems_extension.
* cpu_supplement/arm.t: Update.
* cpu_supplement/preface.texi: Typo.
* cpu_supplement/general.t: Expanded abbreviation.
* user/conf.t: Change stack allocator signature.
* bsp_howto/framebuffer.t: documented the improvements made to
read/write
* bsp_howto/framebuffer.t: Updated the frame buffer documentation.
* user/conf.t: Add configuration of posix message queue file
descriptors as separate entity. Also add documentation on posix
configuration elements not previously covered.
