* supplement.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* Makefile.am: Merge-in images/Makefile.am, common/Makefile.am.
* images/Makefile.am: Remove.
* common/Makefile.am: Remove.
* main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* index.html.in: Note that the Getting Started with GNAT/RTEMS
manual is largely obsolete now that GNAT is in GCC.
* Makefile.am: Corrected link.
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi:
Removed all references to bit scripts.
* gdb.t: Removed.
* intr_NOTIMES.t: Real version submitted.
* ata.t, ide-ctrl.t: New file.
* .cvsignore: Added new .texi files.
* Makefile.am:: Added new files to generate.
* bsp_howto.texi: Added new chapters.
* index.html.in: Add links to multiple missing CPU supplements.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* io.t: Correct Ada bindings.
* BSP_TIMES, wksheets.texi: Updated to reflect ARM times
reported by Jay Monkman <jmonkman@adventnetworks.com>. These
times are subject to change as he tunes the ARM port and their BSP.
* Makefile.am: Added arm subdirectory.
* intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* .cvsignore: Corrected some errors.
* timeMVME136.t, timedata.t: Replaced XXX's with real info.
* callconf.t: Added some markups for fonts and clarified
some places.
* miscellaneous.t: Added some markups for fonts and clarified
some places.
* configure.ac: Added supplements/arm/Makefile.
* README: Updated.
* README: Updated.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2001-01-17 Joel Sherrill <joel@OARcorp.com>
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* .cvsignore: Corrected by tailoring for the ARM.
* .cvsignore: New file.
* BSP_TIMES, ChangeLog, Makefile.am, arm.texi, bsp.t, callconv.t,
cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t,
preface.texi, stamp-vti, timeBSP.t, timing.texi, version.texi,
wksheets.texi: New files as ARM supplement initial version added.
CPUDIR=/opt/rtems/powerpc-rtems/include
cd $BSPDIR
find . -name "*.h" | while read f
do
if [ -r ${CPUDIR}/${f} ] ; then
echo Conflict on ${f}
fi
done
* intr_NOTIMES.t: Per PR70 incorporate the posting by
Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* tverstions.texi: Updated to reflect newer versions.
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression
schemes including bzip2.
* preface.texi, procenv.t, process.t, signal.t, stamp-vti,
version.texi: Updated as part of starting a sweep on the POSIX
User's Guide.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* doc/user/userext.t: Per PR138, updated the documentation to show
how to obtain an extension table index. Also provided some extra
background on the user extension API.
* VERSION, bootstrap: Removed as unneeded.
* bootstrap: Remove.
* VERSION: Remove.
* Makefile.am:
Remove bootstrap.
Add ACLOCAL_AMFLAGS.
* configure.ac: Add RTEMS_TOP.
* io.t: Fix typo @sybsection.
* intr.t: Per PR165, now correctly states that passing a NULL
pointer for the return argument is an error.
* Ctags/Makefile.am: Remove AUTOMAKE_OPTIONS.
* FreeBSD/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ctags-emacs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pictures/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* PR137
* buildc.t: Now provides more explicit requirements on $PATH
after building binutils.
* rtmon.t: Correct example and correctly used ensure not insure.
