path: root/doc (follow)
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-272-6/+4
| | | | * io.t: Correct Ada bindings.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-023-278/+284
| | | | | | * BSP_TIMES, wksheets.texi: Updated to reflect ARM times reported by Jay Monkman <jmonkman@adventnetworks.com>. These times are subject to change as he tunes the ARM port and their BSP.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-023-4/+8
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-313-4/+8
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-312-1/+5
| | | | * Makefile.am: Added arm subdirectory.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-319-27/+51
| | | | * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-314-28/+37
| | | | | * .cvsignore: Corrected some errors. * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-313-8/+20
| | | | * timeMVME136.t, timedata.t: Replaced XXX's with real info.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-312-13/+17
| | | | | * callconf.t: Added some markups for fonts and clarified some places.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-312-16/+26
| | | | | * miscellaneous.t: Added some markups for fonts and clarified some places.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-312-0/+5
| | | | * configure.ac: Added supplements/arm/Makefile.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-301-0/+4
| | | | * README: Updated.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-301-2/+2
| | | | | * README: Updated.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-3051-110/+110
| | | | | * stamp-vti, verstion.texi: Regenerated.
| | | | | | | | | | | | | | | | | | | | * stamp-vti, verstion.texi: Regenerated. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: include main.am, require automake-1.5. 2001-01-17 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Added rtems_header.html and rtems_footer.html. 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-17/+22
| | | | * .cvsignore: Corrected by tailoring for the ARM.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-0/+39
| | | | * .cvsignore: New file.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-3017-0/+2175
| | | | | | | * BSP_TIMES, ChangeLog, Makefile.am, arm.texi, bsp.t, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, stamp-vti, timeBSP.t, timing.texi, version.texi, wksheets.texi: New files as ARM supplement initial version added.
* BSPDIR=/opt/rtems/powerpc-rtems/mcp750/lib/includeJoel Sherrill2002-07-262-1/+6
| | | | | | | | | | | | | | CPUDIR=/opt/rtems/powerpc-rtems/include cd $BSPDIR find . -name "*.h" | while read f do if [ -r ${CPUDIR}/${f} ] ; then echo Conflict on ${f} fi done
* 2002-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-282-0/+75
| | | | | * intr_NOTIMES.t: Per PR70 incorporate the posting by Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* 2001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-282-19/+23
| | | | * tverstions.texi: Updated to reflect newer versions.
* 2001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-283-6/+26
| | | | | * buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2.
* 2001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-287-143/+358
| | | | | | * preface.texi, procenv.t, process.t, signal.t, stamp-vti, version.texi: Updated as part of starting a sweep on the POSIX User's Guide.
* 2002-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-282-6/+22
| | | | | | * userext.t: Per PR228, correct the prototype of the task create user extension to indicate it returns a boolean and augment the documentation to explain the purpose of the boolean return value.
* 2002-06-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-142-1/+5
| | | | * project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* 2002-04-12 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-132-2/+34
| | | | | | * doc/user/userext.t: Per PR138, updated the documentation to show how to obtain an extension table index. Also provided some extra background on the user extension API.
* 2002-04-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-113-0/+4
| | | | * VERSION, bootstrap: Removed as unneeded.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-085-144/+13
| | | | | | | | | * bootstrap: Remove. * VERSION: Remove. * Makefile.am: Remove bootstrap. Add ACLOCAL_AMFLAGS. * configure.ac: Add RTEMS_TOP.
* 2002-04-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-032-1/+5
| | | | * io.t: Fix typo @sybsection.
* 2002-03-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-282-6/+6
| | | | | * intr.t: Per PR165, now correctly states that passing a NULL pointer for the return argument is an error.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-286-6/+18
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2868-34/+136
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-4/+7
| | | | | | | * Ctags/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * FreeBSD/Makefile.am: Remove AUTOMAKE_OPTIONS. * ctags-emacs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-2/+5
| | | | | * pictures/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-272-13/+18
| | | | | * PR161 * rtmon.t: Add rtems_ prefix to directives in the example.
* 2002-03-22 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-273-13/+156
| | | | | * io.t, conf.t: PR 160. Added the IO Manager's register and unregister interface documentation.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+21
| | | | | | * PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils.
* 2002-03-15 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-152-12/+16
| | | | * rtmon.t: Correct example and correctly used ensure not insure.
* 2001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-012-0/+40
* 2001-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-142-0/+5
| | | | * configure.ac: New mips supplement.
* 2001-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-142-1/+5
| | | | * mips: New supplement.
* 2002-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-1415-0/+1278
| | | | | | * bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi, preface.texi, stamp-vti, timeBSP.t, version.texi: New files.
* fixing branchJoel Sherrill2002-01-301-7/+23
* fixing branchJoel Sherrill2002-01-301-23/+7
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-228-6008/+32
| | | | | | | | | | * .cvsignore: Reworked. * Makefile.am: Remove texinfo/texinfo.tex * bootstrap: Removed. * configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir. * main.am: Remove TEXINFO_TEX. * project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir. Remove commented out make-variables.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2220-5308/+13
| | | | | | * configure.ac: Autoupdate to 2.52. Remove pdl2texi. * Makefile.am: Remove pdl2texi.
* regeneratedJoel Sherrill2002-01-2052-96/+148
* regeneratedJoel Sherrill2002-01-2034-60/+60
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-206-22/+14
| | | | | | | | | * .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing, mkinstalldirs, texinfo.tex. * Makefile.am: Add main.am to AUTOMAKE_FILES. * configure.ac: Add AC_CONFIG_AUX_DIR([.]). * project.am: Remove custom .texi and stamp-vti rules. * main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2020-37/+41
| | | | * supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
