* | Mostly correcting case of section headings although a few minor things | Joel Sherrill | 1998-04-11 | 5 | -32/+32 |
| | | | | | were corrected as the Getting Started with GNAT/RTEMS manual was created. | ||||
* | Now a passable Ada manual | Joel Sherrill | 1998-04-11 | 7 | -92/+268 |
* | Added cross development and real-time embedded systems background. | Joel Sherrill | 1998-04-11 | 2 | -1/+99 |
* | Base line -- copied from C/C++ | Joel Sherrill | 1998-04-11 | 10 | -0/+1238 |
* | Printed copy given to Steve and Mark | Joel Sherrill | 1998-04-10 | 4 | -17/+17 |
* | In texinfo nicely with all version dependent information | Joel Sherrill | 1998-04-10 | 8 | -177/+345 |
| | | | | now in variables and some updates already in place. | ||||
* | moved supplements under a subdirectory | Joel Sherrill | 1998-04-09 | 1 | -2/+3 |
* | Now builds clean for info, html, and ps. | Joel Sherrill | 1998-04-09 | 6 | -224/+250 |
* | base version | Joel Sherrill | 1998-04-09 | 8 | -0/+742 |
* | Fixed improperly named sections for info | Joel Sherrill | 1998-04-03 | 3 | -10/+10 |
* | Completed pass at constants. | Joel Sherrill | 1998-04-03 | 4 | -11/+11 |
* | Cleaned up installation of pictures and common html files. | Joel Sherrill | 1998-04-03 | 2 | -2/+8 |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 |
* | Moved to tools/texi2www since they are part of that distribution. | Joel Sherrill | 1998-04-03 | 4 | -0/+0 |
* | Moved from common directory since they belong to the texi2www distribution. | Joel Sherrill | 1998-04-03 | 5 | -0/+0 |
* | Removed incorrect comment. | Joel Sherrill | 1998-04-03 | 1 | -1/+0 |
* | Added texi2www to this tree | Joel Sherrill | 1998-04-03 | 2 | -3/+3 |
* | Renamed. | Joel Sherrill | 1998-04-03 | 1 | -1/+1 |
* | Nowbiulds html and ps. Info not supported. | Joel Sherrill | 1998-04-03 | 1 | -3/+4 |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 |
| | | | | to specify the base of the name. BASEnnnn.html | ||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 |
* | Base file | Joel Sherrill | 1998-04-03 | 4 | -1/+53 |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 2 | -2/+2 |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 4 | -0/+2122 |
* | Added constants through ch13 | Joel Sherrill | 1998-04-02 | 11 | -446/+459 |
* | Make sure OAR logo is accessible | Joel Sherrill | 1998-04-02 | 1 | -0/+1 |
* | Added egcs 1.0.2 gcc docs | Joel Sherrill | 1998-04-02 | 1 | -1/+1 |
* | Corrected wildcard for info files | Joel Sherrill | 1998-04-02 | 1 | -1/+2 |
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 2 | -5/+7 |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 18 | -4/+98 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Added copy of HELP.html. | Joel Sherrill | 1998-04-02 | 1 | -1/+1 |
* | Added newlib to support and ada_user to internal. | Joel Sherrill | 1998-04-02 | 1 | -2/+2 |
* | Make.config | Joel Sherrill | 1998-03-31 | 1 | -1/+3 |
* | Taking care of minor build problems | Joel Sherrill | 1998-03-30 | 4 | -6/+5 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 15 | -218/+115 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 14 | -15/+19 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 13 | -20/+39 |
* | Added 4th icon | Joel Sherrill | 1998-03-30 | 1 | -2/+0 |
* | Added directories | Joel Sherrill | 1998-03-30 | 1 | -0/+3 |
* | Added support for multiple distribution levels. | Joel Sherrill | 1998-03-30 | 1 | -4/+15 |
* | Mediocre graphic just to use as a place holder to show what it looks like. | Joel Sherrill | 1998-03-30 | 1 | -0/+0 |
* | Added dependency so html would build from scratch. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
* | Corrected by adding "end markers". | Joel Sherrill | 1998-03-27 | 1 | -8/+9 |
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 24 | -1883/+176 |
* | Renamed extra_manuals to oar_manuals. | Joel Sherrill | 1998-03-27 | 1 | -3/+2 |
* | Removed ruler line since it is automatically inserted now along with | Joel Sherrill | 1998-03-27 | 1 | -1/+0 |
| | | | | the buttons at the bottom. | ||||
* | Localized for use in doc tree. | Joel Sherrill | 1998-03-27 | 1 | -2/+7 |
* | Added directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -0/+2 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 22 | -613/+830 |
