for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
Add new file for CBS documentation.
Adds documentation on the scheduler options and scheduler selection
to the User's Manual to reflect changes made in the development of
pluggable scheduling with EDF and CBS schedulers.
Adds to confdefs a way to specify rtems_resource_unlimited for classic and
posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
extending the set of objects at runtime. Updates the unlimited sample
to demonstrate how to use the new macros. Also adds new documentation in
the C User's Manual regarding configuring with unlimited objects.
* libmisc/shell/main_mdump.c: Reworked to fix bugs in handling of the
length argument and to provide an "ldump" command. This file now also
supports the "wdump" command. In addition, an RTEMS API function called
rtems_mdump() is provided to allow easy dumping from application code.
* libmisc/shell/main_mwdump.c: Obsolete file.
* libmisc/Makefile.am: Removed main_mwdump.c
* libmisc/shell/shellconfig.h: Added "ldump" command.
* shell/memory.t: Added documentation for the "ldump" command
Signed-off-by: Ric Claus <claus@SLAC.Stanford.edu>
* project.am (MOSTLYCLEANFILES): Remove index.html.
* ada_user/Makefile.am (CLEANFILES): Fixup image handling.
PR 1984/doc
* user/conf.t: Change CONFIGURE_MINIMUM_STACK_SIZE to
CONFIGURE_MINIMUM_TASK_STACK_SIZE.
* user/conf.t: Move @findex for CONFIGURE_MICROSECONDS_PER_TICK to
where it should be.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
PR 1793/doc
* Makefile.am, configure.ac, bmenu/bmenu2.c: Convert from texi2www to
texi2html.
* texi2www/ChangeLog, texi2www/Makefile.am, texi2www/dir-arrow.gif,
texi2www/missing-arrow.gif, texi2www/next-arrow.gif,
texi2www/prev-arrow.gif, texi2www/texi2dvi, texi2www/texi2www,
texi2www/texi2www.texi, texi2www/up-arrow.gif: Removed.
PR 1793/doc
* .cvsignore, install.texi, intro.texi, probrep.texi, relnotes.texi,
status.texi: Convert from texi2www to texi2html.
PR 1793/doc
* .cvsignore, new_chapters.texi: Convert from texi2www to texi2html.
* ada_user/version.texi, bsp_howto/version.texi,
cpu_supplement/version.texi, develenv/version.texi,
filesystem/version.texi, networking/version.texi,
porting/version.texi, posix1003.1/version.texi,
posix_users/version.texi, shell/version.texi, started/version.texi,
user/version.texi: Update to match when files in directory where last
touched.
* version.texi: Update to match when files in directory where last
touched.
* user/conf.t: Added a bsp override option for MAXIMUM_DEVICES.
PR 1947/doc
* started/buildrt.t: Make note that native toolset is needed to
configure and build RTEMS.
Petr Benes <benesp16@fel.cvut.cz>
PR 1912/doc
* user/conf.t, user/schedule.t: Rework to add scheduler specific
information.
* user/Makefile.am, user/c_user.texi: Reorder chapters to put
scheduling earlier. Also put Barrier and Rate Monotonic Manager where
they logically belong. They appear to have just be added toward the
end.
PR 1864/doc
* user/conf.t: Add missing documentation for
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS,
CONFIGURE_MAXIMUM_POSIX_BARRIERS , CONFIGURE_MAXIMUM_POSIX_SPINLOCKS,
CONFIGURE_MAXIMUM_POSIX_RWLOCKS.
PR 1851/doc
* user/conf.t: Fix typo in CONFIGURE_MESSAGE_BUFFER_MEMORY example.
* user/mp.t: Avoid obsolete notation.
* user/part.t, user/sem.t: Typos.
PR 1824/cpukit
* bsp_howto/init.t, bsp_howto/support.t, user/init.t: Return
exit/shutdown status back to boot_card().
* bsp_howto/support.t: Update copyright.
* bsp_howto/support.t: Add section describing configuration macros
which may be defined at the BSP level to alter defaults in
rtems/confdefs.h.
* user/conf.t: Fix typos.
* user/conf.t: Add SMP Configuration parameters.
* user/conf.t: Slight rework to deemphasize not using confdefs.h
* index.html.in, common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New dates.
PR 1782/cpukit
* porting/taskcontext.t: Disable deferred FPU context switches when SMP
is enabled. Per code tracking of deferred contexts is not
implemented.
* rtems_footer.html.in, common/cpright.texi: Update dates in copyright.
* ada_user/.cvsignore: Add missing files.
PR 1743/cpu
* user/conf.t: Add Simple Priority Scheduler as complement to existing
Deterministic Priority Scheduler. This scheduler serves both as an
example and as a lighter weight implementation for smaller systems.
PR 1752/doc
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Remove TI C4x CPU Supplement
chapter.
* cpu_supplement/tic4x.t: Removed.
* ada_user/Makefile.am: Add ObjectId pdf files.
* configure.ac: Rename RTEMS_API into _RTEMS_API.
PR 1744/doc
* user/clock.t: rtems_clock_time_value type uses changed to struct
timeval.
* setup.def, shell/preface.texi: Bump to 4.10.99.0
* user/conf.t: Document changes to Scheduler configuration.
* posix_users/posix_users.texi, posix_users/signal.t: Review and
improve as part of Google Code-In 2010.
* started/buildc.t, started/buildrt.t, started/nt.t, started/require.t,
started/sample.t: Review and improve.
* develenv/direct.t: Remove Getting Started with GNAT/RTEMS.
* started_ada/.cvsignore, started_ada/Makefile.am,
started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t,
started_ada/require.t, started_ada/sample.t, started_ada/stamp-vti,
started_ada/started_ada.texi, started_ada/tversions.texi,
started_ada/version.texi: Removed.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
