* user/clock.t: Refactored rtems_clock_get into 5 methods which
are single purpose and more strongly typed. They are:
rtems_clock_get_tod - Get TOD in Classic API structure
rtems_clock_get_tod_timeval - Get TOD in struct timeval
rtems_clock_get_seconds_since_epoch - Get TOD as seconds since 1988
rtems_clock_get_ticks_since_boot - Get ticks since boot
rtems_clock_get_ticks_per_second - Get ticks per second
* shell/general.t: Add sleep and echo commands.
* shell/.cvsignore, shell/Makefile.am, shell/memory.t,
shell/preface.texi, shell/shell.texi: Added much information the
Preface. Created initial version of Configuration and Intialization
chapter. Links are now complete from start to end of manual.
* shell/confinit.t: New file.
* shell/file.t, shell/network.t: Document more commands and provide
more examples.
* shell/file.t, shell/general.t, shell/memory.t, shell/network.t,
shell/rtems.t, shell/shell.texi: Many commands now have real
descriptions with examples.
* shell/file.t, shell/general.t: More commands documented.
* shell/.cvsignore, shell/file.t: Add most of file commands.
* porting/interrupts.t: Formatting.
shell/rtems.t: More descriptions and examples added.
shell/rtems.t: Add mount and cp command information from Chris Johns.
Reformat some things.
shell/rtems.t: A bit of clean up on the script.
shell/rtems.t: Change configure messages per Chris Johns suggestion.
* Makefile.am, configure.ac, index.html.in: Add initial version of
RTEMS Shell Manual. This is largely a starting point but has most of
the required structure.
* shell/.cvsignore, shell/Makefile.am, shell/file.t, shell/general.t,
shell/memory.t, shell/network.t, shell/preface.texi, shell/rtems.t,
shell/shell.texi: New files.
* networking/networkapp.t: Add configuration parameters for network
stack efficiency multiplier and default socket buffer sizes.
* user/object.t: Added some examples.
* user/object.t: Add Ada binding for Object Services.
* index.html.in: Update copyright year.
* ada_user/Makefile.am, ada_user/ada_user.texi: Now builds.
* user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t,
user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t,
user/userext.t: Add new Object Services collection. Tidy up some
configuration documentation from earlier changes.
* user/object.t: New file.
* rtems_footer.html.in, common/cpright.texi: Update copyright. Fix
spacing.
* user/task.t: Add manual page for rtems_task_self().
* bsp_howto/clock.t, bsp_howto/init.t: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* base.h: Remove Lines, Verbose, EXTERN.
* menu2.c: Add Lines, Verbose. Remove EXTERN.
* base.h: Remove BlankAsWarnings.
* base.h: Remove NumberOf*.
* address.h, address.inl, chain.c, chain.h, system.h:
Eliminate unsigned8, unsigned16, unsigned32.
Use size_t, ptrdiff_t, intptr_t for 64bit compliance.
* chain.c: Reflect removal of isr.h.
* isr.h: Remove.
* Makefile.am: Remove isr.h.
* cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, porting/cpuinit.t,
user/conf.t, user/init.t: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, user/conf.t: Moved
most of the remaining CPU Table fields to the Configuration Table.
This included pretasking_hook, predriver_hook, postdriver_hook,
idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* develenv/direct.t, develenv/sample.t: Corrected various errors.
* cpu_supplement/powerpc.t: Eliminate PowerPC specific elements from
the CPU Table. They have been replaced with variables named bsp_XXX
as needed.
* user/barrier.t, user/clock.t, user/concepts.t, user/conf.t,
user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t,
user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t,
user/task.t, user/timer.t: Corrected various errors in the
documentation.
* develenv/develenv.texi, develenv/direct.t, develenv/intro.texi,
develenv/sample.t, develenv/utils.t: Update directory tree.
* user/conf.t: Add CONFIGURE_APPLICATION_EXTRA_DRIVERS.
* cpu_supplement/sh.t: Eliminate the clicks_per_microsecond field in
the SuperH CPU Table and define another mechanism for drivers to
obtain this information.
* cpu_supplement/i386.t, cpu_supplement/m68k.t: Pick up changes missed
earlier.
* cpu_supplement/mips.t: Eliminate the clicks_per_microsecond field in
the MIPS CPU Table and define another mechanism for drivers to obtain
this information.
* cpu_supplement/i386.t: Eliminate the interrupt_table_segment and
interrupt_table_offset fields in the i386 CPU Table since they are
never read.
* cpu_supplement/m68k.t: Eliminate the interrupt_vector_table field in
the m68k CPU Table since it is never read.
* user/rtmon.t: Fix report output.
* user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t,
user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t,
user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the
Ada documentation to reflect the current binding.
PR 1262/filesystem
* posix_users/io.t: Add support for readv() and writev() including
documentation and test case.
* Makefile.am, configure.ac, develenv/direct.t: Remove RDBG.
* rgdb_specs/.cvsignore, rgdb_specs/Makefile.am, rgdb_specs/comm.t,
rgdb_specs/conclusion.t, rgdb_specs/daemon.t,
rgdb_specs/gdbinternals.t, rgdb_specs/interfacing.t,
rgdb_specs/intro.t, rgdb_specs/layers.eps, rgdb_specs/layers.jpg,
rgdb_specs/layers.txt, rgdb_specs/objectives.t,
rgdb_specs/process.eps, rgdb_specs/process.jpg,
rgdb_specs/process.txt, rgdb_specs/revision.t,
rgdb_specs/rgdb_specs.texi, rgdb_specs/seqbreak.eps,
rgdb_specs/seqbreak.jpg, rgdb_specs/seqbreak.txt,
rgdb_specs/seqdetach.eps, rgdb_specs/seqdetach.jpg,
rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.eps,
rgdb_specs/seqinit.jpg, rgdb_specs/seqinit.txt, rtems_gdb/.cvsignore,
rtems_gdb/Makefile.am, rtems_gdb/commands.t, rtems_gdb/example.t,
rtems_gdb/intro.t, rtems_gdb/rtems_gdb.texi, rtems_gdb/started.t,
rtems_gdb/swarch.t, rtems_gdb/trouble.t: Removed.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* relnotes.texi: Print table of contents in front of manual where it
should be when you print.
* new_chapters.texi: Print table of contents in front of manual where
it should be when you print.
* user/io.t: Fix typo.
