CPUDIR=/opt/rtems/powerpc-rtems/include
cd $BSPDIR
find . -name "*.h" | while read f
do
if [ -r ${CPUDIR}/${f} ] ; then
echo Conflict on ${f}
fi
done
* intr_NOTIMES.t: Per PR70 incorporate the posting by
Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* tverstions.texi: Updated to reflect newer versions.
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression
schemes including bzip2.
* preface.texi, procenv.t, process.t, signal.t, stamp-vti,
version.texi: Updated as part of starting a sweep on the POSIX
User's Guide.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* doc/user/userext.t: Per PR138, updated the documentation to show
how to obtain an extension table index. Also provided some extra
background on the user extension API.
* VERSION, bootstrap: Removed as unneeded.
* bootstrap: Remove.
* VERSION: Remove.
* Makefile.am:
Remove bootstrap.
Add ACLOCAL_AMFLAGS.
* configure.ac: Add RTEMS_TOP.
* io.t: Fix typo @sybsection.
* intr.t: Per PR165, now correctly states that passing a NULL
pointer for the return argument is an error.
* Ctags/Makefile.am: Remove AUTOMAKE_OPTIONS.
* FreeBSD/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ctags-emacs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pictures/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* PR137
* buildc.t: Now provides more explicit requirements on $PATH
after building binutils.
* rtmon.t: Correct example and correctly used ensure not insure.
* .cvsignore: New file.
* configure.ac: New mips supplement.
* mips: New supplement.
* bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t,
fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi,
preface.texi, stamp-vti, timeBSP.t, version.texi: New files.
* .cvsignore: Reworked.
* Makefile.am: Remove texinfo/texinfo.tex
* bootstrap: Removed.
* configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir.
* main.am: Remove TEXINFO_TEX.
* project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir.
Remove commented out make-variables.
* configure.ac: Autoupdate to 2.52.
Remove pdl2texi.
* Makefile.am: Remove pdl2texi.
* .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing,
mkinstalldirs, texinfo.tex.
* Makefile.am: Add main.am to AUTOMAKE_FILES.
* configure.ac: Add AC_CONFIG_AUX_DIR([.]).
* project.am: Remove custom .texi and stamp-vti rules.
* main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* project.am: Reworked.
* main.am: New.
* configure.ac: New.
* configure.in: Removed.
* bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
* ctags-emacs/Makefile.am: Ditto.
* FreeBSD/Makefile.am: Ditto.
* Ctags/Makefile.am: Ditto.
* Makefile.am: Include main.am, require automake-1.5.
* pictures/Makefile.am: Require automake-1.5, fix +=.
* VERSION: Updated to rtems-doc-ss-20010117.
* VERSION: Updated to rtems-doc-eng-20010816b-d1.
* configure.in: Changed the version to eng-20010816b.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
* VERSION: New file.
* Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
not that of _ISR_Manager_initialization.
