* | Converted from DOS to UNIX filemode. | Joel Sherrill | 1999-11-09 | 3 | -1630/+1630 |
* | Corrected lines that were too long. | Joel Sherrill | 1999-11-09 | 2 | -8/+8 |
* | Fixed formatting error. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Corrected manual name. | Joel Sherrill | 1999-11-09 | 1 | -8/+8 |
* | Integrated into main tree. | Joel Sherrill | 1999-11-09 | 1 | -26/+15 |
* | Update from Jennifer. | Joel Sherrill | 1999-11-09 | 1 | -30/+54 |
* | Added more status information. | Joel Sherrill | 1999-11-09 | 1 | -0/+80 |
* | Added Status chapter. | Joel Sherrill | 1999-11-09 | 4 | -4/+1059 |
* | Corrected flaws which prevented formatting with texi2pdf since it | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
| | | | | is stricter on node names. | ||||
* | Changed version timestamp. | Joel Sherrill | 1999-10-28 | 2 | -4/+4 |
* | Added information to fstat handler. | Joel Sherrill | 1999-10-28 | 1 | -14/+21 |
* | Reformatted. | Joel Sherrill | 1999-10-28 | 1 | -359/+395 |
* | Cleaned up spacing on function prototypes. | Joel Sherrill | 1999-10-28 | 1 | -56/+56 |
* | Added lstat(). | Joel Sherrill | 1999-10-28 | 1 | -3/+57 |
* | Added shell of chapters on implementation of miniIMFS and TFTP client | Joel Sherrill | 1999-10-28 | 5 | -6/+50 |
| | | | | | filesystems. Moved system call chapter to before filesystem implementation requirements. | ||||
* | Added information on the evaluate and evaluate for make routines. | Jennifer Averett | 1999-10-26 | 2 | -21/+115 |
| | | | | Added details on how generic code starts the pathevaluation process. | ||||
* | Corrected spacing problem. | Jennifer Averett | 1999-10-26 | 1 | -1/+1 |
* | Fixed line too long problems. | Joel Sherrill | 1999-10-25 | 3 | -14/+22 |
* | Updated copyright year and corrected image path. | Joel Sherrill | 1999-10-25 | 1 | -4/+4 |
* | Updated copyright year. | Joel Sherrill | 1999-10-25 | 2 | -2/+3 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 5 | -33/+56 |
* | Added descriptions of the mount table entry elements. | Jennifer Averett | 1999-10-25 | 1 | -0/+97 |
* | Modified url references to be dynamic links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Added definition of DDD. Modified url references to be | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
| | | | | dynamic links. | ||||
* | + Filled in information on IMFS_freenod and IMFS_freenodinfo | Jennifer Averett | 1999-10-25 | 1 | -13/+58 |
| | | | | + Filled in information on the imfs_fsunmount and imfs_unmount methods. | ||||
* | + Cleaned up lines that were too long. | Jennifer Averett | 1999-10-25 | 1 | -129/+19 |
| | | | | | + Removed subheading File - This is not valid for the callback descriptions. + Filled in information on freenod | ||||
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 9 | -50/+54 |
* | Added information on how the directory is stored for future referance | Jennifer Averett | 1999-10-25 | 1 | -2/+3 |
| | | | | during a mount. | ||||
* | Formatting improvements. | Joel Sherrill | 1999-10-25 | 3 | -12/+80 |
* | Enabled Ada95 interrupt support chapter and reformatted a | Joel Sherrill | 1999-10-25 | 6 | -35/+48 |
| | | | | bunch of stuff to avoid line wrappings. | ||||
* | Made html links browsable. | Charles Phillips | 1999-10-25 | 1 | -4/+3 |
* | Made urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
* | Made html urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Made html urls browable links. Updated the reference to the | Charles Phillips | 1999-10-25 | 1 | -6/+48 |
| | | | | | U.S. Army Missile Command to show the merger with the Aviation Command | ||||
* | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1999-10-25 | 1 | -11/+10 |
| | | | | backwards. | ||||
* | Reorganized a lot per Jennifer's suggestions. | Joel Sherrill | 1999-10-13 | 4 | -120/+120 |
* | Updated copyright date. | Joel Sherrill | 1999-10-13 | 6 | -5/+7 |
* | More manuals and a little reorganization. | Joel Sherrill | 1999-10-13 | 1 | -5/+25 |
* | First commit of miscellaneous tools and documentation for a procedure | Joel Sherrill | 1999-10-13 | 8 | -0/+343 |
| | | | | that can be used to produce an online bookshelf of the GNU tools. | ||||
* | Made many changes to turn the outline into something more like a manual | Joel Sherrill | 1999-10-12 | 9 | -448/+1854 |
| | | | | and less like a collection of notes. | ||||
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -35/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -324/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -339/+0 |
* | New file. | Joel Sherrill | 1999-10-12 | 1 | -0/+34 |
* | Fixed random cut and paste problem. | Joel Sherrill | 1999-10-11 | 1 | -23/+23 |
* | Added files generated by index process to clean stanza. | Joel Sherrill | 1999-10-11 | 3 | -1/+5 |
* | Changed link for bad PDF files to BAD.html. | Joel Sherrill | 1999-10-11 | 1 | -2/+2 |
* | Changed version information. | Joel Sherrill | 1999-10-11 | 2 | -2/+2 |
* | Changed release information. | Joel Sherrill | 1999-10-11 | 1 | -5/+5 |
* | New files. | Joel Sherrill | 1999-10-11 | 4 | -0/+0 |
