* | Added information about the new build scripts. | Joel Sherrill | 1998-10-20 | 1 | -56/+86 | |
| | | | | Added host OS specific notes. | |||||
* | Added sections and had to change build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -1/+1 | |
* | Increased required disk space along with information about the required | Joel Sherrill | 1998-10-20 | 1 | -3/+23 | |
| | | | | | | disk space. Added information about GNU makeinfo minimum version. | |||||
* | Added information about the bit_gdb script. | Joel Sherrill | 1998-10-20 | 1 | -3/+35 | |
* | Added information about the new build scripts. The biggest thing was | Joel Sherrill | 1998-10-20 | 1 | -59/+73 | |
| | | | | | | describing the user.cfg file. Added a section on Solaris 2.x. | |||||
* | Added sections so had to change the build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 | |
* | Enhanced times() with copy from the other chapter. | Joel Sherrill | 1998-10-19 | 1 | -13/+16 | |
* | Removed times() since it is duplicated. | Joel Sherrill | 1998-10-19 | 1 | -31/+0 | |
* | Updated to reflect the longer list of libraries. | Joel Sherrill | 1998-10-19 | 1 | -3/+3 | |
* | Removed node information. | Joel Sherrill | 1998-10-19 | 1 | -28/+1 | |
* | Removed node information now that it is automatically generated. | Joel Sherrill | 1998-10-19 | 1 | -42/+0 | |
* | Changed version and date strings. | Joel Sherrill | 1998-10-19 | 1 | -5/+5 | |
* | Changed KA9Q to Networking. | Joel Sherrill | 1998-10-19 | 1 | -2/+2 | |
* | Cleaned up list of docs. | Joel Sherrill | 1998-10-19 | 1 | -3/+3 | |
* | Removed KA9Q issues. | Joel Sherrill | 1998-10-19 | 1 | -60/+0 | |
* | Changed version. | Joel Sherrill | 1998-10-19 | 1 | -1/+1 | |
* | Moved things around so html and clean were above stanzas which generate | Joel Sherrill | 1998-10-19 | 7 | -113/+107 | |
| | | | | chapters. | |||||
* | All of the Supplemental manuals are now generated as automatically | Joel Sherrill | 1998-10-19 | 22 | -511/+159 | |
| | | | | as possible. | |||||
* | No node info | Joel Sherrill | 1998-10-19 | 1 | -45/+1 | |
* | Renamed. | Joel Sherrill | 1998-10-19 | 3 | -645/+0 | |
* | Renamed memmodel.texi to memmodel.t. | Joel Sherrill | 1998-10-19 | 1 | -119/+0 | |
* | Renamed fatalerr.texi to fatalerr.t. | Joel Sherrill | 1998-10-19 | 1 | -47/+0 | |
* | Renamed cputable.texi to cputable.t. | Joel Sherrill | 1998-10-19 | 1 | -119/+0 | |
* | Renamed cpumodel.texi to cpumodel.t. | Joel Sherrill | 1998-10-19 | 1 | -171/+0 | |
* | Renamed callconv.texi to callconv.t. | Joel Sherrill | 1998-10-19 | 1 | -447/+0 | |
* | Renamed bsp.texi to bsp.t. | Joel Sherrill | 1998-10-19 | 1 | -106/+0 | |
* | Renamed a lot and got as much as possible automatically generated. | Joel Sherrill | 1998-10-19 | 11 | -349/+91 | |
* | Renamed. | Joel Sherrill | 1998-10-19 | 1 | -215/+0 | |
* | Renamed | Joel Sherrill | 1998-10-19 | 3 | -1671/+0 | |
* | Renamed memmodel.texi to memmodel.t. | Joel Sherrill | 1998-10-19 | 1 | -125/+0 | |
* | Renamed fatalerr.texi to fatalerr.t. | Joel Sherrill | 1998-10-19 | 1 | -62/+0 | |
* | Renamed cputable.texi to cputable.t. | Joel Sherrill | 1998-10-19 | 1 | -171/+0 | |
* | Renamed cpumodel.texi to cpumodel.t. | Joel Sherrill | 1998-10-19 | 1 | -223/+0 | |
* | Renamed callconv.texi to callconv.t. | Joel Sherrill | 1998-10-19 | 1 | -280/+0 | |
* | Renamed bsp.texi to bsp.t. | Joel Sherrill | 1998-10-19 | 1 | -95/+0 | |
* | Much renamed, most stuff automatically generated now. | Joel Sherrill | 1998-10-19 | 11 | -357/+31 | |
* | Renamed a lot of files. | Joel Sherrill | 1998-10-19 | 8 | -764/+41 | |
* | Nearly everything that can be is now automatically generated. | Joel Sherrill | 1998-10-19 | 18 | -1183/+92 | |
* | All files as automatically generated as possible. | Joel Sherrill | 1998-10-19 | 7 | -218/+18 | |
* | Renamed. | Joel Sherrill | 1998-10-19 | 1 | -0/+0 | |
* | New file. | Joel Sherrill | 1998-10-19 | 1 | -0/+86 | |
* | Removed. | Joel Sherrill | 1998-10-19 | 2 | -241/+0 | |
* | More automatically generated. Many files renamed behind the scenes. | Joel Sherrill | 1998-10-19 | 10 | -872/+45 | |
* | Makefiles in much better shape even though not all files have automatically | Joel Sherrill | 1998-10-19 | 22 | -102/+223 | |
| | | | | generated menus yet. | |||||
* | Timing Chapter is now shared and menu structure generated. | Joel Sherrill | 1998-10-19 | 4 | -32/+47 | |
| | | | | Cpumodel.texi is now generated. | |||||
* | Renamed so the menu structure can be built on the fly. | Joel Sherrill | 1998-10-19 | 1 | -65/+2 | |
* | Now completed generated with build menu. | Joel Sherrill | 1998-10-19 | 2 | -37/+51 | |
* | New file | Joel Sherrill | 1998-10-19 | 1 | -0/+108 | |
* | Worksheets now generated from a common file and the node info structure | Joel Sherrill | 1998-10-19 | 8 | -85/+194 | |
| | | | | is generated automatically. | |||||
* | Added chapter. | Joel Sherrill | 1998-10-19 | 3 | -6/+123 | |
