* Makefile.am, configure.ac, develenv/direct.t: Remove RDBG.
* rgdb_specs/.cvsignore, rgdb_specs/Makefile.am, rgdb_specs/comm.t,
rgdb_specs/conclusion.t, rgdb_specs/daemon.t,
rgdb_specs/gdbinternals.t, rgdb_specs/interfacing.t,
rgdb_specs/intro.t, rgdb_specs/layers.eps, rgdb_specs/layers.jpg,
rgdb_specs/layers.txt, rgdb_specs/objectives.t,
rgdb_specs/process.eps, rgdb_specs/process.jpg,
rgdb_specs/process.txt, rgdb_specs/revision.t,
rgdb_specs/rgdb_specs.texi, rgdb_specs/seqbreak.eps,
rgdb_specs/seqbreak.jpg, rgdb_specs/seqbreak.txt,
rgdb_specs/seqdetach.eps, rgdb_specs/seqdetach.jpg,
rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.eps,
rgdb_specs/seqinit.jpg, rgdb_specs/seqinit.txt, rtems_gdb/.cvsignore,
rtems_gdb/Makefile.am, rtems_gdb/commands.t, rtems_gdb/example.t,
rtems_gdb/intro.t, rtems_gdb/rtems_gdb.texi, rtems_gdb/started.t,
rtems_gdb/swarch.t, rtems_gdb/trouble.t: Removed.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* relnotes.texi: Print table of contents in front of manual where it
should be when you print.
* new_chapters.texi: Print table of contents in front of manual where
it should be when you print.
* user/io.t: Fix typo.
* user/io.t: Added error cases to rtems_io_register_driver.
* user/conf.t: Eliminate maximum_drivers configuration parameter since
it was used to configure a no longer used feature. Device names are
now part of the filesystem not in a table. This also eliminated the
variables _IO_Number_of_devices and _IO_Driver_name_table from RTEMS
as well as the memory allocation used to populate
_IO_Driver_name_table.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFER_MEMORY. Use
rtems/confdefs.h instead of old confdefs.h.
* user/conf.t: Fix typo -- should have read kilobytes.
* user/Makefile.am, user/concepts.t, user/rtmon.t: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* Makefile.am, gen_section: Integrate Rate Monotonic Statistics and
Period Usage into Rate Monotonic Manager. Added the following
* rtmonuse.t: Removed.
* user/.cvsignore, user/cpuuse.t, user/stackchk.t: Stack checker and
CPU usage chapters are now OK in the manual.
* porting/miscellaneous.t: Remove subsection on "Optional
Endian Conversion Routines", CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* user/example.texi: Change all obsoleted CONFIGURE_TEST_NEEDS_XXX
configuration constants to CONFIGURE_APPLICATION_NEEDS_XXX.
* user/task.t: Add rtems_iterate_over_all_threads.
* user/clock.t: Add clock_get_uptime().
* user/Makefile.am, user/clock.t: Add support for a handler to obtain
the number of nanoseconds since the last clock tick. The primary
interface for this is rtems_clock_set_nanoseconds_extension.
Subsequent commits from Joel will redo the TOD support to use this
capability.
PR 1226/cpukit
* user/conf.t: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE not
CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE.
* user/Makefile.am, user/stackchk.t: Change dump usage to report usage.
* ada_user/Makefile.am, ada_user/ada_user.texi: Ada API manual now
builds again.
* user/Makefile.am, user/barrier.t, user/c_user.texi: Update barrier
documentation.
PR 1221/doc
* user/rtmon.t: Add missing exponent operator in RMS CPU Utiliziation
formula.
* setup.def: newlib-1.15.0.
* common/rtems.texi.in: Use bugzilla for RTEMSBUGS.
Remove RTEMSGNATS.
* started/binaries.t, started/buildc.t, started/tversions.texi.in:
Various update to reflect current toolchains.
* configure.ac: Reflect having moved setup.def.
Eliminate gcc3*.
Eliminate gcc3*.
Eliminate gcc3*.
* setup.def: New (Formerly in ../scripts).
* posix_users/thread.t: Correct spelling error.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* posix_users/.cvsignore, rgdb_specs/.cvsignore, rtems_gdb/.cvsignore,
started/.cvsignore, started_ada/.cvsignore: Add more generated files.
* user/.cvsignore: Update.
* ada_user/Makefile.am, ada_user/ada_user.texi,
cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi,
cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get
everything building from previous breakages.
* cpu_supplement/bfin.t: New file.
* porting/interrupts.t: Fix bogus _CPU_ISR_Get_level.
* user/barrier.t: New file.
* new_chapters/Makefile.am, new_chapters/gen_section,
new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi,
user/dirstat.texi: Promote CPU Usage to first class citizen. Rename
to start with rtems_ and include documentation in user guide.
* user/cpuuse.t: New file.
* new_chapters/cpuuse.t: Removed.
* new_chapters/Makefile.am, user/Makefile.am, user/c_user.texi,
user/dirstat.texi, user/task.t: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
* user/stackchk.t: New file.
* new_chapters/stackchk.t: Removed.
PR 1171/doc
* user/timer.t: Correct documentation for rtems_timer_initiate_server.
* cpu_supplement/cpu_supplement.texi: New file.
* Makefile.am, configure.ac, develenv/direct.t: Remove gnu_docs. Now
included with RPMs.
* gnu_docs/.cvsignore, gnu_docs/ChangeLog, gnu_docs/Makefile.am,
gnu_docs/Tool_Doc_Instructions, gnu_docs/gen_docs,
gnu_docs/gnu_footer.html, gnu_docs/gnu_header.html,
gnu_docs/index.html, gnu_docs/mk_install_dir, gnu_docs/refcard.html,
gnu_docs/rtems_tools_index.html: Removed.
* Makefile.am, configure.ac, index.html.in: FAQ should now be
completely in the Wiki.
* FAQ/.cvsignore, FAQ/FAQ.texi, FAQ/Makefile.am, FAQ/basic.t,
FAQ/bsp.t, FAQ/build45.t, FAQ/concepts.t, FAQ/debug.t,
FAQ/endoftime.t, FAQ/entry, FAQ/freesw.t, FAQ/hwdebugaids.t,
FAQ/projects.t, FAQ/stamp-vti, FAQ/tools.t, FAQ/version.texi,
common/timemac.texi, common/timetbl.t, common/timing.t: Removed.
