* user/msg.t, user/sem.t, user/task.t: Update to new parameter types.
Emphasize that you can use a pointer for task arguments.
* user/datatypes.t: Add rtems_name. Add comment about
rtems_task_argument changing from simple unsigned thirty two bit
integer to being derived from a C99 uintptr_t in 4.8 and newer.
PR 1263/doc
* user/part.t: Improve discussion of alignment and minimum buffer
sizes.
PR 1288/doc
* user/intr.t: Update callable from ISR section.
* user/msg.t: Parameter is size not count. Spotted by Sebastian Huber.
* porting/idlethread.t: Correct prototype of Idle threads.
PR 1291/cpukit
* posix_users/semaphores.t: Update to reflect absolute time.
* shell/Makefile.am, shell/rtems.t: Add pthread command.
* posix_users/mutex.t: Add ETIMEDOUT.
* shell/confinit.t: New argument sequence for rtems_shell_init().
* user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t,
user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t:
Correct documentation typos noticed and thankfully reported by
FabrÃcio de Novaes Kucinskis <fabricio@dea.inpe.br>
* user/.cvsignore: Add chains.texi.
* doc/user/chains.t: New.
* doc/ada_user/ada_user.texi, doc/user/Makefile.am,
doc/user/c_user.texi, doc/user/dirstat.texi: Updated for the
chains documentation.
* user/io.t: Fix typos for IO unregister reported by Catalin Morosan
<catalin.morosan at gmail.com>.
* user/conf.t: Add CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS.
* user/conf.t: Add CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION and
CONFIGURE_MAXIMUM_PRIORITY.
* user/conf.t: Add CONFIGURE_MINIMUM_STACK_SIZE.
* user/bsp.t, user/conf.t, user/task.t: Add ability for application to
configure minimum stack size. Add RTEMS_CONFIGURED_MINIMUM_STACK_SIZE
constant so user can clearly indicate they want the configured as
opposed to the recommended minimum stack size.
* started/buildc.t: Add paragraph on see CVS for latest patches.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE and example
of how to compute message CONFIGURE_MESSAGE_BUFFER_MEMORY using it.
* user/rtmon.t: Change to using new types.
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/arm.t, cpu_supplement/bfin.t,
cpu_supplement/cpu_supplement.texi, cpu_supplement/i386.t,
cpu_supplement/m68k.t, cpu_supplement/mips.t,
cpu_supplement/powerpc.t, cpu_supplement/preface.texi,
cpu_supplement/sh.t: Remove duplicated text from each CPU specific
chapter. This text was necessary when each CPU was a separate manual
but now only needs to be one place and that is in an introductory
chapter.
* cpu_supplement/general.t: New file.
* user/bsp.t, user/init.t: Rework initialization and BSP chapters to
account for changes to initialization framework.
* user/conf.t: Add baseline interface for Watchdog Driver.
* user/conf.t: Fix text on CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER.
* user/conf.t: Fix typo on
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* user/conf.t: Add CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* user/bsp.t, user/conf.t, user/init.t, user/intr.t, user/overview.t,
user/timer.t: Correct default values. Make it clear that confdefs.h
calculates the memory required for you.
* networking/testing.t: Cleaned up the patch from Ian.
* networking/testing.t: Patch from Ian Caddy to document the
routes debug information.
* user/clock.t: Refactored rtems_clock_get into 5 methods which
are single purpose and more strongly typed. They are:
rtems_clock_get_tod - Get TOD in Classic API structure
rtems_clock_get_tod_timeval - Get TOD in struct timeval
rtems_clock_get_seconds_since_epoch - Get TOD as seconds since 1988
rtems_clock_get_ticks_since_boot - Get ticks since boot
rtems_clock_get_ticks_per_second - Get ticks per second
* shell/general.t: Add sleep and echo commands.
* shell/.cvsignore, shell/Makefile.am, shell/memory.t,
shell/preface.texi, shell/shell.texi: Added much information the
Preface. Created initial version of Configuration and Intialization
chapter. Links are now complete from start to end of manual.
* shell/confinit.t: New file.
* shell/file.t, shell/network.t: Document more commands and provide
more examples.
* shell/file.t, shell/general.t, shell/memory.t, shell/network.t,
shell/rtems.t, shell/shell.texi: Many commands now have real
descriptions with examples.
* shell/file.t, shell/general.t: More commands documented.
* shell/.cvsignore, shell/file.t: Add most of file commands.
* porting/interrupts.t: Formatting.
shell/rtems.t: More descriptions and examples added.
shell/rtems.t: Add mount and cp command information from Chris Johns.
Reformat some things.
shell/rtems.t: A bit of clean up on the script.
shell/rtems.t: Change configure messages per Chris Johns suggestion.
* Makefile.am, configure.ac, index.html.in: Add initial version of
RTEMS Shell Manual. This is largely a starting point but has most of
the required structure.
* shell/.cvsignore, shell/Makefile.am, shell/file.t, shell/general.t,
shell/memory.t, shell/network.t, shell/preface.texi, shell/rtems.t,
shell/shell.texi: New files.
* networking/networkapp.t: Add configuration parameters for network
stack efficiency multiplier and default socket buffer sizes.
* user/object.t: Added some examples.
* user/object.t: Add Ada binding for Object Services.
* index.html.in: Update copyright year.
* ada_user/Makefile.am, ada_user/ada_user.texi: Now builds.
* user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t,
user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t,
user/userext.t: Add new Object Services collection. Tidy up some
configuration documentation from earlier changes.
* user/object.t: New file.
* rtems_footer.html.in, common/cpright.texi: Update copyright. Fix
spacing.
